Just ordered a T61p from Lenovo with HUGE savings
nurio
#61 Post by nurio » Sat Jul 28, 2007 2:26 pm
erik wrote:
nurio wrote:
The address space (4GB) split for 2GB application and 2GB for kernel is correct for 32 bit applications regardless of PAE. with the /3GB switch the that split changes to 3GB Application vs. 1GB Kernel and it is not always recommended, as the kernel space becomes more limited.
Here is a good article to read on this subject:
http://technet2.microsoft.com/windowsse ... x?mfr=true
GarryF
#62 Post by GarryF » Sat Jul 28, 2007 3:46 pm
barrywohl wrote:I know that the cost of Vistal Ultimate from Microsoft allows either 32 or 64 bit. I wonder if that is true for OEM Vista Ultimate.
I managed to install 64 bit on my new T61P, someone has written a small tool called ABR that backups your 32 bit vista key. You need a retail 64 bit disk, install vista then restore the key. I ended going back to 32 bit for the meantime, but it's good to know in a year or so time when things settle down I can go to 64 bit.
T61P (6460-6XG) T7500-2.2G 100GB WUXGA 15.4"
retired T43P 2668F8G, A31P P4-1.8
erik
moderator
moderator
#63 Post by erik » Sat Jul 28, 2007 4:24 pm
nurio wrote:The address space (4GB) split for 2GB application and 2GB for kernel is correct for 32 bit applications regardless of PAE.
that's correct, however the 3GB-to-4GB address space is only available on 32-bit OSs using /PAE and BIOSs supporting memory hoisting.   your average notebook BIOS running a 32-bit OS will not see 1GB of a 4GB total system without using the /PAE switch.
nurio wrote:with the /3GB switch the that split changes to 3GB Application vs. 1GB Kernel and it is not always recommended, as the kernel space becomes more limited.
the purpose to my post was simply to point out different ways the kernel can be split among a 4GB total system.   i'm well aware of what the /3GB switch does and its positives and negatives.   i read that very same article three years ago when i was debating between buying a T42p or building a desktop.   but, thanks anyway. :)
