Your missing a key point here. OEM and Retail media are now exactly the same. I won't know for sure until I actually get my t61p, but like I said before I'm confident there is a totally legal way to do what the OP wants to do without buying a new license.ryengineer wrote:Please see this thread about the implementation of lenovo license key. This key will work with only oem installation media regardless of 32 or 64 bit disk but since the license determines the version so it will only allow you to install 32 bit version. Again this strictly applies to lenovo oem licenses.kelchm wrote:The real test is whether the license key will work with a standard disk or not. I'm confident that if it will work with a standard 32bit disk, it will work with a standard 64bit disk.
Also, in that link you provided, I found this post very interesting.
I've never seen this before, but it might explain why using the key from the sticker on normal Vista media does not work.furrycute wrote:The real Vista key is not the one printed on the bottom of your notebook. You need a program called "Magical Jellybean Key Finder" to find your real Vista key.
There is also a Lenovo offline activation license you can find on the net, that allows you to offline activate a fresh install of Vista (after you've put in the key you found with the key finder).
This is not exactly illegal, since you are doing a fresh install using the key you legally purchased along with your computer. And the offline activation file just saves you the hassle of having to activate Vista online or having to make a phone call to MS.
