We had X60 and X61 (Tablets) coming in, both had zero issue.flypenfly wrote:Any way to confirm this because I need to cancel my order if this is not the case.
X61 Tablet SXGA Screen Coming Unglued From Bezel
ryengineer
- Moderator Emeritus
new2tablet
I have an X60T. I have the bezel issue. Build: July '07 C2D1.5Biggs wrote:Is it a safe assumption that X60T's with SXGA+ don't have this bezel problem?
The more I use the computer, the better it gets... meaning the less noticeable it appears. I do about 50/50 tab /type. I was outraged when I first found it, now the less I care the less its noticeable.
new2tablet
auchenberg
possibly resolved
This is possibly resolved, a thread over at tabletpcreviews shows that lenovo is posting a fix, and that they are now shipping the SXGA+ again.
"From lenovoblogs
Tim Supples Says:
October 12th, 2007 at 2:58 pm
Hello everyone,
I am happy to report that we do have a solution for the bezel separation. The most detail I have on the fix right now is that it is actually a revised bezel part. It will take several weeks for the parts to become available through our various service organizations. I would recommend waiting to request service until the parts are in ready supply to reduce the time your notebook is out for service. When the new bezels are available, we will do a formal announcement with more details. We appreciate the patience of those experiencing this issue and the help and support of those customers who aided in gathering facts, including those who provided their systems for analysis.
Andrew - the horizontal lines issue can be fixed currently by engaging service.
Let's hope for the best."
Cut-and-pasted for your convenience. Hopefully there will be a Thanksgiving sale and the X61t will be fully fixed by then.
Tim Supples Says:
Hello everyone,
X61 7675-CTO Merom 2.0GHz 4GB RAM, 7K200 HDD
Fix announced on Lenovo blog
What does everyone think about this?
"We have released a fix in the form of a revised bezel, with thicker adhesive tape designed to compensate for the somewhat thinner SXGA+ display. These parts are now in stock, and are being applied through normal service routes. Additional information including service part numbers may be found here http://www-307.ibm.com/pc/support/site. ... MIGR-68984."
andyP
- **SENIOR** Member
I think that is a big PLUS POINT for Lenovo. It shows that they have listened to their customers and come up with a solution. OK it wasn't solved overnight, but I can understand that finding the proper cause and cure isn't necessarilly easy.
Lenovo
T61p 6460-67G; 15,4 WSXGA+ W7P x64, no hairdryer.
T43p 2668-G2G, 14,1 SXGA+, XP Pro, internal hairdryer
T23 2647-9LG, 14,1 SXGA+, XP Pro, no hairdryer
andyP
- **SENIOR** Member
It's about 6 months since Lenovo announced the "fix" for the bezel separation problem.
I would be interested to hear from anyone who has had this problem fixed, but has experienced that the antenna cover on the right side of the screen seems to be loose. By loose I mean as if there is no support behind it to the front side of the screen.
My reason for asking is that I have a customer whose tablet was repaired in January and is now complaining that the right antenna cover isn't a clean fit to the front bezel, as if there is no support behind it or it's not properly attached.
If I can get a picture of what I mean; I will post it.
Thanks in advance
Thanks in advance
My x60 tablet had this and was fixed with what look slike an extra rivet to hold the screen together on the bottom middle of the bezel. Works fine, but I have another issue which is driving me up the wall involving flickering of the video.
IBM Thinkpad T61p on Vista Ultimate x64 [home rig]
IBM Thinkpad Z61t on Vista Ultimate x64 [work/school]
crashnburn
My tablet arrived and I have to pick it up from brothers house. How do I check to see if this might have the BEZEL issue?
mtbiac
quick question: I'm looking at buying a used X61T. The guy stated that it had the bezel separation issue, and that he had it fixed by Lenovo under warranty, but the problem still remains although much less severe. It will be out of warranty in about 2 weeks. It's a pretty good deal, do you think I should pick it up? Are there more permanent fixes for this problem that I could perform after purchasing it?
thanks for the quick response!
T61 2.5ghz T9300, 14.1" WXGA+, 3gb, 160gb 7,200rpm, X3100, 4695AGN, Bluetooth, DVD-RW, 6 cell
mtbiac
If it's that much of a good deal, buy the machine and extend the warranty immediately, not because of the bezel, but because you don't want to be without it...
My $0.02...
My $0.02...
mtbiac
alright well I just bought it. He said the issue is very minor, only aesthetic, and only occurs when the laptop is "warm." Hope I got a good deal...
X61T
1.66ghz
2gb RAM
100gb 7200rpm
802.11a/b/g/n
bluetooth
SXGA+ Superview screen
1gb Turbo Memory
Fingerprint
8 cell battery
docking station with DVD+- RW
Vista Ultimate
looks to be in great condition. All for $1100 + ship
decent deal?
X61T
1.66ghz
2gb RAM
100gb 7200rpm
802.11a/b/g/n
bluetooth
1gb Turbo Memory
Fingerprint
8 cell battery
Vista Ultimate
decent deal?
crashnburn
not covered under warranty, says CR rep
Well, I have an X61T and have had the bezel problem for almost a year. I have it taped but decided it's time to get it fixed. I have the 3-year depot/pick-up warranty. I called today and the CR rep said, "You don't have the Thinkpad plus protection (or something like that) plan so it will be $350 to fix the bezel."
I told her this was a well-known problem that should be covered under warranty. She said I could talk to a supervisor and she put me on hold to talk to one but I had to get off the phone before I got the supervisor on the line.
So what gives? Anyone have any idea why a CR rep would tell me this?
I'm p.o.ed. I already spent 45 min on the phone and AM NOT HAPPY about this at all.
Any ideas?
Any ideas?
crashnburn
Seriously!
How do I check if my X61t is susceptible to this issue?
Can you please take some pictures or describe your experience of the Bezel issue so that I may check.
If yours is affected, where the bezel contacts the screen on the bottom will be separated from the LCD (more so than the other edges). If you put your laptop in 'tablet mode' then the bezel should come off even more. Mine was separated by a millimeter or two before I got it fixed.crashnburn wrote:Seriously!
crashnburn
So many people talking about it and mentioning it and I have yet to see a picture of this issue online. Anyone got any?
http://lenovoblogs.com/connections/?p=6
I have the 1024x768 screen and while I don't have the bezel problem on the bottom, the bezel hs detached from the antenna. Currently, it's not causing any problems.andyP wrote:It's about 6 months since Lenovo announced the "fix" for the bezel separation problem.
Can someone confirm that this issue has been fixed in the new X61t that are being manufactured?
X22 - 800mhz - 640MB RAM - 60GB Hitachi 7200rpm 7k100
X40 - 1.4ghz - 1.5GB RAM - 8GB Transcend 300x CF on Addonics CF/IDE Adapter
T42p - 1.8ghz - 15" UXGA - 1GB RAM - 160GB HDD
X61t - C2D 1.6ghz - 12.1" SXGA+ - 8GB RAM - Intel G3 300GB SSD
X60 Tablet, SXGA+ screen display issue (vague white blobs - adhesive)
by topramen » Mon Jan 23, 2017 10:55 pm » in Thinkpad X6x Series incl. X6x Tablet - 1 Replies
- 1302 Views
Last post by ajkula66
Tue Jan 24, 2017 7:50 am
LF: A31 or A31p Screen Bezel/Assembly
by jeffbaichina » Sun Mar 12, 2017 3:03 am » in Marketplace - Forum Members only - 18 Replies
- 2003 Views
Last post by Saucey
Tue Mar 21, 2017 10:31 pm
Sleep sensor under screen bezel issues T530
by Brandon0623 » Fri Jun 02, 2017 9:11 pm » in ThinkPad T430/T530 and later Series - 4 Replies
- 155 Views
Last post by Brandon0623
Fri Jun 16, 2017 5:35 pm
- 2 Replies
- 907 Views
Last post by J Walker
Tue Mar 21, 2017 10:18 am
