Trying to get 108mbps w/DLink DI-624 router and IBM a/b/g
ssdaytona,
did you enable TX-Bursting on the Router?
Netgear Super G:
Prosafe(tm) 802.11g AP - Model WG102 Access Point 802.11b/g -G Super G: AR5002AP
108 Mbps Wireless PC Card - Model WG511T PC Card 802.11b/g Super G: AR5002G
108Mbps Wireless PCI Adapter - Model WG311T PCI Card 802.11b/g Super G: AR5002G
108 Mbps WLAN Firewall Router - Model WGT624 Router 802.11b/g Super G: AR5002AP-G
108Mbps Wireless Storage Router - Model WGT634U Router 802.11b/g Super G: AR5002AP-G
Netgear Super AG:
108Mbps WLAN Firewall Router - Model FWAG114 Access Point 802.11a/b/g Super AG: AR5002X
802.11a/b/g Dual Band PC Card - Model WAG511 PC Card 802.11a/b/g Super AG: AR5001X+
Dual-Band WLAN PCI Adapter - Model WAG311 PCI Card 802.11a/b/g Super AG: AR5001X+
Double 108Mbps Wireless Firewall Router- Model WGU624 Router 802.11a+b/g Super AG: AR5002AP-X
Cheers
Netgear Super G:
Netgear Super AG:
Cheers
Thank you very much ssdaytona,
Just want to figure out which Atheros router chipsets those of you who got 108Mbit working have.
Would be great if eriqesque, dpb, dmcgibbo, kjarrett could post it.
Also interesting would be which Super G mode you are using. Pls see below. It looks like Super G features names differ from vendor to vendor.
Disabled - Standard 802.11g support, no enhanced capabilities.
Super G without Turbo - Capable of Packet Bursting, FastFrames, Compression, and no Turbo mode.
Super G with Dynamic Turbo - Capable of Packet Bursting, FastFrames, Compression, and Dynamic Turbo. This setting is backwards compatible with non-Turbo (legacy) devices. Dynamic Turbo mode is only enabled when all devices on the wireless network are Super G with Dynamic Turbo enabled.
Super G with Static Turbo - Capable of Packet Bursting, FastFrames, Compression, and Static Turbo. This setting is not backwards compatible with non-Turbo (legacy) devices. Static turbo mode is always on and is only enabled when all devices on the wireless network are Super G with Static Turbo enabled.
Cheers
Cheers
Netgear WGT624's have had issues with Auto 108 and such in the past. Make sure you have the latest firmware on your router also.
I can't try this myself with my Intel card, so no help there. I have had a WGT624 since they first came out and have seen a lot of bugfixes since.
Also, definitely avoid SMB for this kind of test. Lots of wireless drivers have SMB bugs too. Bad performance, BSOD (that was with Netgear's driver for their WG511T card though)...the whole spectrum of problems.
-Daver
-Daver
I too wonder about this... I've just ordered a 2373-HVU and have found that it uses the first generation IBM a/b/g wireless card... (I think the Atheros AR5001X+?)
I've just looked on Atheros' website ( http://www.atheros.com/pt/ar5001X+.html ) and have found that for 11a & 11g the chip supports a raw data rate of 108mbps - Since Atheros provides most of the other 108mbps chips should this stuff be compatible? And if so, does the newer IBM A/B/G II (Based on the Atheros AR5004X chipset) offer better performance and/or lower power consumption?
I am concerned that I may want to spend the extra money and purchase the newer card... But I don't fully understand the differences - Anybody from Atheros maybe wanna shed some light on this
Edit: I've also just noticed that there are two different technologies mentioned: Turbo Mode supported by the 5001X+ and Super AG supported by the 5004x... Are these two compatible? Are they just marketing jargon or actually different technologies?
-Moogle
-Moogle
fbrdphreak
- **SENIOR** Member
fbrdphreak
- **SENIOR** Member
brundlefly76
I tried a bunch of Aethos drivers here:
http://www.phoenixnetworks.net/atheros.php
And all I can say is 'thank god for System Restore!!'
The very latest beta drivers really screwed up the system.
Of all the other ones, many worked, but only at 54 mbps with my netgear on auto 108mbps.
I want to point out to everyone that when I first installed this card, windows handled the connection and reported 108mbps - this was *not* the case however - when I timed an FTP transfer over the unloaded network, I observed 54mbps speeds (or, in real terms, 22mbps+)
If you are being told by windows connection manager that you are connected at 108mbps, take that with a huge grain of salt....
fbrdphreak
- **SENIOR** Member
Anyone thinkin' about maybe having IBM (or Lenovo for that matter) replace out a/b/g 108 cards with a "fixed" model when it comes out? I'm assuming a new mini-PCI card would help alleviate these difficulties, as it might be more compatible & easier to have working drivers for.
My $0.02
My $0.02
atct86
Will any cards get me 108mbps with my Linksys WRT54GS?
Check this out!!!!!
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... eName=WDVW
Check this out!!!!!
2.2ghz MacBook Pro
320b Lacie Triple Interface Extreme Drive
Dell 20.1" Widescreen - 2007WFP
brundlefly76
Dont hold your breath - none of the SuperG vendors are marketing/supporting SuperG interoperabilty except between paired devices of the same manufacturer.fbrdphreak wrote:Anyone thinkin' about maybe having IBM (or Lenovo for that matter) replace out a/b/g 108 cards with a "fixed" model when it comes out? I'm assuming a new mini-PCI card would help alleviate these difficulties, as it might be more compatible & easier to have working drivers for.
My $0.02
Becuase of this, you wont see IBM marketing SuperG because they would have to support interoperability with other vendors SuperG equipment, and I wouldnt blame them for not wanting to, since the AP vendors arent on board with supporting other brands.
Remember, for every one of us who are willing to screw around with their system to get things working, there are 100 people who arent and will tie up IBM support, which potentially would cost IBM more then they make on the card sales.
fbrdphreak
- **SENIOR** Member
fbrdphreak
- **SENIOR** Member
Can't seem to get it to work
Well, I really have tried to get 108Mbps but can't seem to get it to work
The setup
Netgear WGU624 (double 108mbps)
Thinkpad t42p
Thinkpad X40 both with the new IBM A/b/G II cards with drivers 4.0.100.140 and otherwise standard Winxp pro from IBM.
Have tried with windows zero config and access connection uninstalled, the router set in auto 108 and a (respective g) only, but it only connects with 48mbps to 54 mbps. Don't get me wrong, range, stability and overall speed are great, I seem to be maxing my Internet connection (10mbps, getting 9,6 in TCP transfers) but win zcfg shows only 54mbps in both a and g networks. Have tried fooling around with HP's atheros utility with no major improvement in speed, even though Super-G and super-A are enabled.
Once again, the ones that have got it working, what did you do?
The setup
Thinkpad t42p
thinkpad X40, T42p
blackomegax
Herr Yunta
Stop! You do not need to install or uninstall anything. This works perfectly with the IBM software and driver.
1. Start-run-regedit
2. enter \hkey_local_machine\system\currentcontrolset\control\class
3. find atheros
4. add
1) Name=abolt type=string value=1
2) Name=disableTurboG type=string value=0
You can verify the 108 speed in Access Connections while associated to an equipped access point.
3. find atheros
4. add
3508-CTO 4GB X25-M 80GB 60Y3183 bluetooth Win 7 Pro 32bit (60Y3195 soon)
Herr Yunta,
Y've got an atheros 11 abg wireless lan mini pci adapter in my T42, and, even if the 'abolt' and 'disableTurboG' registry entries are there, I am not able to connect at 108Mbps w/a dlink DI-824+ wireless router. I am able to do it from another desktop w/ an USR adapter, so I know the router can do it...
So I am guessing it may be another thing. My current registry looks like :
"ssid"="randomssidtoshutoffautoconnectib"
"gpioPinFunc1"="0"
"scanTimePreSleep"="60"
"capLinkSp"="1"
"Characteristics"=dword:00000084 <<<
"BusType"="5"
"ComponentId"="pci\\ven_168c&dev_1014&subsys_833117ab"
"extendedChanMode"="1"
"ignore11dBeacon"="1"
"radioEnable"="0"
"rateCtrlEnable"="1"
"roamRssiA"="15"
"scanTimeValid"="45000"
"shortPreamble"="1"
"sleepMode"="0"
"tpc"="0"
"TransmitRate11a"="7"
"TransmitRate11b"="3"
"TransmitRate11g"="11" <<<
"InfPath"="oem20.inf"
"InfSection"="XP_DEV_0013"
"ProviderName"="Atheros Communications Inc"
"DriverDateData"=hex:00,80,9f,ef,07,a9,c5,01
"DriverDate"="8-25-2005"
"DriverVersion"="4.1.102.1095"
"MatchingDeviceId"="pci\\ven_168c&dev_1014&subsys_833117ab"
"DriverDesc"="11a/b/g Wireless LAN Mini PCI Adapter"
"NetCfgInstanceId"="{70362C35-4AAA-443A-A1C9-9A2DAA5E3F1E}"
"CardCfgId"="d1c43147-26aa-41f3-9719-13603a271cab"
"abolt"="1" <<<
"disableTurboG"="0" <<<
"HardwareAddress"="00054E4ED6F1"
"NetBand"="15"
Can you please check if your configuration looks similar ? (specially values marked <<<)
Another thing would be that I'm using access connections ver. 3.81 (not 4.0 yet).
Thanks in advance...
"gpioPinFunc1"="0"
"capLinkSp"="1"
"BusType"="5"
"radioEnable"="0"
"roamRssiA"="15"
"shortPreamble"="1"
"sleepMode"="0"
"tpc"="0"
"abolt"="1" <<<
"NetBand"="15"
760CD -> 770X -> 600E -> T23 -> T40 -> T42 -> T400 -> T430
Thinkpad T430 i5 3320M 320GB HD, 8GB Mem
Hello: Has this issue been solved? It would be good to know the Atheros download location and the name of current Atheros Cient software that should be used with the IBM (atheros based) Wireless PCI cards, and confirmation of what to edit in the registry in order to enable 108Mbps with a D-Link AG Router. Thanks for clarifying.
in abg II, abolt should be 63FTC wrote:Herr Yunta,
"gpioPinFunc1"="0"
"capLinkSp"="1"
"BusType"="5"
"radioEnable"="0"
"roamRssiA"="15"
"shortPreamble"="1"
"sleepMode"="0"
"tpc"="0"
"abolt"="1" <<<
"NetBand"="15"
however, did you turn on dynamic turbo? try not using static/only turbo first.
mailww
FS: Dell TrueMobile 2300 Access Point/Router
by RealBlackStuff » Wed Feb 01, 2017 11:00 am » in Marketplace - Forum Members only - 0 Replies
- 233 Views
trying to install Android x86 (anything really!)
by Whitieiii » Tue Feb 14, 2017 1:28 am » in Off-Topic Stuff - 1 Replies
- 480 Views
Last post by jronald
Sun Apr 02, 2017 1:46 pm
Trying to connect my bluetooth speaker with my T430s
by vmqt » Sun Feb 26, 2017 9:14 am » in ThinkPad T430/T530 and later Series - 2 Replies
- 370 Views
Last post by UMPC2024
Sun Feb 26, 2017 4:35 pm
- 15 Replies
- 1506 Views
Last post by Dekks
Mon Mar 13, 2017 11:31 am
