Yet another sleeve discussion - X61t 8-cell
crashnburn
#31 Post by crashnburn » Wed May 21, 2008 7:41 pm
I need to find one for my incoming X61 Tablet. :)
Do you guys every carry it stand alone?
Anyone use something like this?
http://shop.lenovo.com/SEUILibrary/cont ... _area=true
Would this allow easy convertability from Tablet mode to laptop mode?
crashnburn
#32 Post by crashnburn » Wed Aug 06, 2008 7:29 pm
Anyone find the OLD version somewhere? on Ebay?
snots wrote:
noetus wrote:I rather like the Thinkpad sleeves of this type because they will fit:
(1) the bare X61 tablet with regular battery, or
(2) the X61t with 8-cell battery, or
(3) the X61t with BOTH the regular battery and extended battery at the same time, or
(4) the X61t with BOTH 8-cell and extended battery at the same time
due to the way the flap closes and the inherent flexibility of the material. This is an invaluable feature for me. Plus they have the Thinkpad livery. However, beware - it seems like only the OLD-STYLE cases of this type, which are slightly larger and have a thicker foam protection, will fit the X61t. These are very hard to find now. All the ones currently being sold on eBay are of the new type - and when I ordered one, it didn't fit. (I also have one of the older style ones, which does fit, but which is now slightly damaged and I would like to replace it.)
If anyone knows where these sleeves can be found (other than eBay), I would be very appreciative (I believe they may originally have been sold only in Japan).
Thanks for that info. I was about to jump on board and order one until you said the new ones don't fit.
Why is it so difficult to find a fitting sleeve that is not too big? I guess I could go for a zeroshock 14" sleeve, but that seems like it would be too loose.
aceo07
#33 Post by aceo07 » Sat Aug 30, 2008 11:56 pm
It seems like the waterfield is one of the few easy options. Most other choices are hard to find or not 100% fit.
The Zeroshock seems nice, but too bad apparently it doesn't fit.
X22 - 800mhz - 640MB RAM - 60GB Hitachi 7200rpm 7k100
X40 - 1.4ghz - 1.5GB RAM - 8GB Transcend 300x CF on Addonics CF/IDE Adapter
T42p - 1.8ghz - 15" UXGA - 1GB RAM - 160GB HDD
X61t - C2D 1.6ghz - 12.1" SXGA+ - 8GB RAM - Intel G3 300GB SSD
eclone
#34 Post by eclone » Mon Sep 08, 2008 7:27 am
Just got my Sumdex Impactguard 12.1".
cost me $19 :shock: including express shipping and tax (cdn) from pctoyshop.
perfect fit for the 8 cell!
http://www.sumdex.com/core/PUN-812.asp
aceo07
#35 Post by aceo07 » Mon Sep 08, 2008 9:37 am
eclone wrote:Just got my Sumdex Impactguard 12.1".
How's the protection around the zipper areas? I noticed that some sleeves with zippers don't really protect laptop from the zipper.
loyukfai
#36 Post by loyukfai » Mon Sep 08, 2008 10:51 am
Bother to take a few photos with the tablet inside and show us...? : ) BTW, is there much lateral free space...?
eclone
#37 Post by eclone » Mon Sep 08, 2008 11:43 am
Didn't bring the laptop to the office today. I'll check and take some pics tonight.
Don't recall there to be too much padding where the zippers are, but I'm not too concerned as it's the battery and handle end.
edit: padding around the zipper area is the same as rest of the sides. very protective.
Length wise, there's about 1/2 inch or less play on each end..width is maxed out...
My main purpose for this case is to protect from cosmetic damages..sfbag is waay too much for me...shipping alone is prob more then what i paid for the sumdex total...
cnelson
#38 Post by cnelson » Fri Oct 10, 2008 3:48 pm
Regarding the Sumdex PUN-812 ImpactGuard sleeve, does it really fit an 8-cell X61t? I have a Sumdex PUN-852 which fits the X61t perfectly except that the battery sticks out the top (so the zipper cannot be closed).
From the Sumdex web site, it appears that the only difference between these sleeves is that the PUN-812 is 12.75" wide and the PUN-852 is 11.5" wide --- I don't need the sleeve to be wider, I need it to be taller. Since there is no change in sleeve height, it appears that the 8-cell battery of the X61t would still stick out the top of the PUN-812.
Let me know if I am wrong as I really like the ImpactGuard sleeve and would like to get one that the 8-cell X61t can fit inside.
j-dawg
#39 Post by j-dawg » Sat Oct 11, 2008 4:25 pm
cnelson wrote:Regarding the Sumdex PUN-812 ImpactGuard sleeve, does it really fit an 8-cell X61t? I have a Sumdex PUN-852 which fits the X61t perfectly except that the battery sticks out the top (so the zipper cannot be closed).
I bought a different Sumdex sleeve recently and it's pretty great. Because it's got a flap and not a zipper, I can just wrap the flap over the edge and it still velcros shut. I'm glad I went with the Sumdex instead of the cheap soft ones from eBay because it feels really solid without being heavy; I feel confident that I'm getting some good protection out of it. I was also clumsy enough to accidentally test it recently; my computer took a ~3ft drop and there's no apparent damage, although it landed pretty flat.
Still, I can vouch for the Sumdex brand, and my sleeve will close. The battery is a tiny bit exposed but that doesn't really concern me.
I am stupid with it, though. I use the sleeve in a very small messenger bag which barely fits even an X-series, and I typically leave the sleeve open and use the velcro on the sleeve with a strip of velcro I attached on the inside of the bag to hold it secure. The sleeve doesn't deform so I can take the computer out with one hand. While this is convenient for inserting and removing the laptop, it means my entire battery sticks out, protected only by the very thin flap of the messenger bag. Unless I somehow manage to drop the bag upside-down, which seems impossible for even a klutz like me, it would be hard to damage much more than the battery, but it's your call on whether you'd do that. Still, that's me being dumb, not any flaw of the sleeve's.
For ~$15 with shipping, I'd say it was money well-spent.
X61 Tablet - 1.6GHz C2D, SXGA+, 1GB RAM, 100GB HD, Vista Business.
i have other laptops but i'll be honest i never use 'em
crashnburn
Re:
#40 Post by crashnburn » Mon Mar 02, 2009 6:00 am
Where did you buy it from?
