Will QXGA (2048x1536) screen option be available for T42p?
Antioch
#31 Post by Antioch » Wed Jul 11, 2007 11:21 pm
What is the inverter for? Why can't you use the old one?
I was wondering if it's possible to buy a Toshiba 12.1" 1400x1050 LCD
(here). However, as I said, what is the inverter for? Is the specific to the LCD? Meaning, I couldn't go grab an X61T inverter (which supports 1400x1050) res and use it with the other panel?
Past: T42, T60
Present: X61s, Y450
Future: X302?
wearetheborg
#32 Post by wearetheborg » Wed Jul 25, 2007 9:27 pm
So how much does a QXGA screen cost ?
HP NC8000 UXGA; Dell Precision M90 WUXGA; R50P UXGA
Please PM me if you've had experience with SquareTrade warranties
#33 Post by pianowizard » Thu Jul 26, 2007 7:45 am
wearetheborg wrote:So how much does a QXGA screen cost ?
$315 shipped on eBay. Just do a search for the part number.
crashnburn
#34 Post by crashnburn » Tue Jul 31, 2007 5:35 pm
Raising the dead. Anyone do anything QXGA with a T series?
erik
moderator
moderator
#35 Post by erik » Wed Aug 22, 2007 12:32 am
crashnburn wrote:
pianowizard wrote: $315 shipped on eBay. Just do a search for the part number.
raising the dead again. after comparing the UXGA and QXGA panel specs, i found that the QXGA panel is 1mm thicker (7.5mm vs. 6.5mm).   this is likely enough of a difference to make installing the Q panel in a 15" T42p/T43p.   the R50p lid/bezel assembly is thick enough to compensate for the extra millimeter where the T-series is not.
EDIT: after looking at R50p photos again, it might be possible to install a complete R50p panel assembly (lid, bezel, and screen) onto a T42p.   if this works then the only downsides are that the T42p would be thicker when closed and it would lose the "thinkpad black" finish on the lid.
#36 Post by pianowizard » Wed Aug 22, 2007 7:41 am
erik wrote:EDIT: after looking at R50p photos again, it might be possible to install a complete R50p panel assembly (lid, bezel, and screen) onto a T42p.
I am pretty sure that works because such a mod has been reported on some Chinese and/or Japanese sites.
xyz
#37 Post by xyz » Wed Aug 22, 2007 6:48 pm
Sounds cool does any one have pics of a completed mod ..
