Sleep hangs Leopard on my X61 without EFI. Haven't gotten EFI booting working yet.adrian.chung wrote:Anyone with a leopard install with or without EFI try sleep?
Have anyone successfully install Leopard on Thinkpad ?
mfbernstein
Re: Sleep?
Thinkpad X61 (7675) 2.0GHZ/500GB/4GB/XP Pro
adrian.chung
With Tiger, and the power management patches I'd always get the Error 192: Embedded Security Hardware Tamper detected.Sleep hangs Leopard on my X61 without EFI. Haven't gotten EFI booting working yet.
Just wondering if Leopard had changed this behaviour.
I'll try and get EFI working and see if it makes a difference.
Mississauga, ON, Canada
X60 (1706-86U)
X60 (1706-86U)
pseudo sleep works. Get EFI working. It makes your life easieradrian.chung wrote:With Tiger, and the power management patches I'd always get the Error 192: Embedded Security Hardware Tamper detected.Sleep hangs Leopard on my X61 without EFI. Haven't gotten EFI booting working yet.
cheers - jl
Leopard on my T42p
I got it installed using KALYWAY's disc...Running pretty darn smooth...still working on wireless and video drivers though...so far im stuck
vim_commando
Re:
in4m8ionman wrote:mfbernstein!
YOU ROCK!
Well Folks - I have Ethernet and the Atheros Wireless working on Leopard on my T60!!!
mfbernstrein is exactly right in how to do this.
Edit /System/Library/Extensions/IO80211Family.kext/Contents/PlugIns/AirPortAtheros.kext/Contents/Info.plist
adding a line for your device ID under IONameMatch (the line is "<string>pci168c,1014</string>").
I then followed the guide that is here on how to load a kext.
http://forum.osx86scene.com/viewtopic.php?f=16&t=229
It DID NOT work until I rebotted with a -f.
Thanks again mfbernstein!
I will post a review of this here as I test.
j
I just wanted to say this was exactly what I needed. I have been working on my Vanilla Retail install for Snow Leopart 10.6.4 on my T60p. It had the Intel wireless adapter so I purchased an IBM "Whitelisted" Atheros Wi-Fi adapter off of ebay. After the install I couldn't figure out why my wireless wasn't showing up, even though everything I've read said it should work Out of the Box.
So all I ended up needing was:
1) Found my Device ID (168e 1014) from linux with lspci -nn
2) Added "<string>pci168c,1014</string>" to /System/Library/Extensions/IO80211Family.kext/Contents/PlugIns/AirPortAtheros21.kext/Contents/Info.plist
3) ran sudo touch /System/Library/Extensions and let the kext cache rebuild
After a reboot, it was good to go!
X31 - 1.6Ghz - 2GB - 60GB 7200RPM - Ultrabase - XP Pro SP3
600X - 450Mhz - 320MB - 30GB - DVD-RW - 2915ABG WiFi - Ubuntu 9.10
T20 - 900Mhz - 192MB - WiFi - Ubuntu 9.04 - Being a Wireless Bridge
Re: Have anyone successfully install Leopard on Thinkpad ?
I have been using snow leopard 10.6.4 and decided to go back to 10.5.8 OMG what a difference. I have tried kalyway 10.5.2 but ideneb lite 10.5.8 is spot on. Everything worked straight off I didn't tick azalia audio (will give you a kernel panic after reboot if you install) and no graphics drivers. My graphics look better in leopard than snow leopard also? Everything is 100% except PCMCIA which I unticked. I'll try and post a screen shot of my custom install. Aiport, ethernet and bluetooth all fine. Haven't tried sleep yet though.
crashnburn
Whats your hardware & other OSX86 distro install details?junoboy wrote:I have been using snow leopard 10.6.4 and decided to go back to 10.5.8 OMG what a difference. I have tried kalyway 10.5.2 but ideneb lite 10.5.8 is spot on. Everything worked straight off I didn't tick azalia audio (will give you a kernel panic after reboot if you install) and no graphics drivers. My graphics look better in leopard than snow leopard also? Everything is 100% except PCMCIA which I unticked. I'll try and post a screen shot of my custom install. Aiport, ethernet and bluetooth all fine. Haven't tried sleep yet though.
My spec is:
Lenovo T61 14" 2.2Ghz Core 2 Duo (shows up as 2.19 Core Duo)
Model: 7659
Integrated Graphics Intel 965.
4GB Ram.
Atheros Wireless card was already installed.
Distros - I have tried them all. Kalyway 10.5.2 is good. But ideneb lite 10.5.8 is the business.
I also got Snow Leopard working which was fine using a very easy method with the retail image and downloading and installing myhack - http://osx86.sojugarden.com/installer/
This is my main machine and I also use it for Music Production. I have bought many Macs over the years and this T61 feels faster than the 13" Macbook Pro I had recently. I am on a anti-apple crusade at the mo. Spent thousands and refuse to give them anymore dinero. Hackinosh is the way,
Model: 7659
4GB Ram.
AMD Catalyst Install Manager will not install video card driver on T60
by psun9999 » Mon Mar 13, 2017 1:33 am » in ThinkPad T6x Series - 1 Replies
- 1458 Views
Last post by zoltan87
Mon Mar 13, 2017 5:55 pm
Thinkpad E570 - seem to have dropped OneLink dock support.
by bblake » Mon Feb 20, 2017 7:09 am » in ThinkPad Edge - 1 Replies
- 1256 Views
Last post by Ibthink
Mon Feb 20, 2017 7:32 am
Does my Thinkpad 10 have a Wacom digitizer?
by sparta.rising » Sun Mar 26, 2017 10:38 pm » in ThinkPad/Ideapad Tablets & Convertibles - 1 Replies
- 588 Views
Mon Mar 27, 2017 5:54 am
Got a nice IPS x220t from ebay, realize I have Computrace woes now
by Digitalhorizons » Sun Jan 08, 2017 7:29 am » in ThinkPad X200/201/220 and X300/301 Series - 38 Replies
- 3718 Views
Last post by asgaard
Sun Jun 25, 2017 2:45 pm
