Thank´s for your reply. With any conlusion
Mod to force t42 (and possibly earlier versions) to 133fsb.
Re: Mod to force t42 (and possibly earlier versions) to 133f
Hi, i have this wonderful machine T42p with 745 and dead T43P with 770, a lot of DDR2 1GB RAM to try but i don´t know hot to make the PIN MOD because images are dead
X301 - "WKS"
T42p - Old-school gaming machine... (not moded yet)
past: X220,T420,T400,X60,X31....
the ddr2 rams are not compatible with the t42
leave the 745 in your t42 and made the fsb mod
770= 2,13ghz
745@133mhzfsb=2,39ghz
for the fsb mod you have to shortcut the second and third pin (starting counting from up left) of the pll chip (it is located under the wifi card, at the left of the southbridge)
770= 2,13ghz
Sounds very good
Thx a lot.
X301 - "WKS"
Re: Mod to force t42 (and possibly earlier versions) to 133fsb.
hey im new here.
i got ibm thinkpad t42, i855pm(A3) chipset, dothan 1.7(735).
i follow about 3 guides from the internet(they all the same), but with no success.
my pll is CY28346-2.
here what i did.
use spdtl too change to ddr266 and ratio of 3:4.
connect pins 54 55.(with wire).
when i turn on pc i got blank screen.(even with speed fixed slow!)what can it be?
if i disable speed step from bios, it boot, but not loading windows. it just blank again.
tnx again forr your time.
here what i did.
- 3346 Views
Last post by jaspen-meyer
Fri Apr 14, 2017 9:34 am
X230 + UltraBase mod => USB 3.0 ?
by notik » Mon Jan 30, 2017 2:19 pm » in ThinkPad X230 and later Series - 3 Replies
- 937 Views
Last post by notik
Mon Feb 13, 2017 7:27 pm
BUYING: Willing to buy Nitrocaster X230 FHD mod board at over 2x cost
by TheChuckster » Fri Feb 24, 2017 2:01 pm » in ThinkPad X200/201/220 and X300/301 Series - 0 Replies
- 1782 Views
Last post by TheChuckster
Just a new Cooling Mod for the T43 type 2668
by cluca_alex » Tue Feb 28, 2017 6:31 am » in ThinkPad T4x Series - 6 Replies
- 1326 Views
Mon Mar 06, 2017 5:47 pm
