stand by/ hibernation problem
Support for your LENOVO branded Laptop.
For those on the road to ThinkPad ownership..!
dim
#1 Post by dim » Mon Dec 10, 2007 7:53 am
Hi, has anyone had troubles going in and out of stand by or hibernation on Lenovo 3000 c100 laptop.
I recently got this issue but I don't remember of making any significant changes to the system - no new software, hardware, drivers are up to date...
Any ideas what can be the cause of that?
ryengineer
#2 Post by ryengineer » Mon Dec 10, 2007 6:57 pm
Folks here will better help you if you mention your Operating System. If you've Windows Vista installed then disable Hybrid Sleep to see if that makes any difference. Also consider looking at the following Knowledge Bases from Microsoft in GomJabbar's post.
T61p: Hibernation does not work.
dim
#3 Post by dim » Tue Dec 11, 2007 3:19 am
Sorry, the OS is Windows XP Home Edition with SP2. I tried almost everythng including disabling services,third party programs, updating drivers, etc.
I reinstalled SP2 and still no luck, so if someone had similar problems...any clue will be appreciated!
ryengineer
#4 Post by ryengineer » Thu Dec 13, 2007 9:31 pm
I found the following tip from CNET that you might need a patch from Microsoft:
Lenovo 3000 V200.
Also look into:
How to troubleshoot hibernation and standby issues in Windows XP.
Microsoft Knowledge Bases on Hibernation Problems.
By the way I saw you posting on Microsoft TechNet, I wish you had better explained the specific hibernation problem here too, so look into the following kb from Microsoft as well, based on your description from that post:
"Preparing to hibernate", Computer Stops Responding When You Stand-by or Hibernate More Than One Time.
dim
#5 Post by dim » Tue Dec 18, 2007 8:46 am
Thanks for the replies. It hasn't been me in MS TechNet :-)
I tried everithing I could find on the Internet...with no luck. Next I'll try reinstall the OS.
One more question. Do you happen to know a way to reinstall Windows without the recovery CD. The problem is that I don't have Windows CD(the laptop came with the OS installed by Lenovo) and I was stupid enough not to make recovery cd's.
So if I use for example another copy of Windows with the key found in the bottom of the machine will it work?
rnem170
#6 Post by rnem170 » Tue Dec 18, 2007 7:25 pm
If you left your system partition alone, you'll be ok, as i believe you can re-install from there. I've got a N100, and although I've got a 80Gb disk, I only have 70, as the rest is a recovery partition.
The key on the bottom of the box 'should' work, but trying using the recovery partition first.
ryengineer
#7 Post by ryengineer » Tue Dec 18, 2007 9:19 pm
dim wrote:Thanks for the replies. It hasn't been me in MS TechNet :-)....snip
Surprising thing is the user was having the same problem with exact same machine and your user name (well not exact but "dimcho"). :shock: :
Stand by/Hibernation problem.
dim wrote:snip.....and I was stupid enough not to make recovery cd's....snip
Sounds like you've already blown up your service partition.
dim wrote:snip....So if I use for example another copy of Windows with the key found in the bottom of the machine will it work?.....snip
The key on the back of your machine will work only with oem copy of Windows CD.
Return to “3000 Series Laptops”
