x60s => L7400 vs L2400 : silence and autonomy
Justintoxicated
X61S has 2 fans inside according to the picture I looked at here
http://forum.notebookreview.com/showthread.php?t=141875
gunston
2nd FAN will only be installed for the model equipped with WWAN only.Justintoxicated wrote:X61S has 2 fans inside according to the picture I looked at here
2. X60s 1703-CA3 powerful
It's a shame X61s runs hotter, consumes more energy and so runs the fan often than X60s.
Progress...
I was thinking of replacing my beloved X31 by a X61s but with the fan running often: NO WAY
Why Lenovo/Intel don't manage to have a fanless C2D solution
( more powerfull that the Atom )
Progress...
Proud and happy X31 owner. In quest of the successor, X61s?!
Nickolai
Hey, why not Atom.. That would be enough to make a person like me happy! But from what I've seen in the past I doubt there is enough demand for laptops with yesterday's hardware (I think that's how they see ULV processors, Geode, Atom).krumli wrote:Why Lenovo/Intel don't manage to have a fanless C2D solution( more powerfull that the Atom )
Thanks. This is very educating.gunston wrote:2nd FAN will only be installed for the model equipped with WWAN only.Justintoxicated wrote:X61S has 2 fans inside according to the picture I looked at here
Is the second fan also there in the X60s models with WWAN?
The second fan was something new that was introduced in the X61/s series, to address complaints of the warm right palm rest.Nickolai wrote:Thanks. This is very educating.
No X60/s units have the second fan, not even the WWAN models.
IvanAndreevich
Re: x60s => L7400 vs L2400 : silence and autonomy
I'd like to share my experience in this area.
In general, Core 2 Duo is MUCH hotter under load than Core Duo. I don't care what Intel puts in its TDP numbers - the actual difference is much larger than 2W. I ran a heavy CPU stress test (Prime95 or linpack) on a C2D L7400 X60s and it was pulling 35W from the battery. In fact, the battery couldn't hold this load and the machine would shut down. You better believe that the CPU was sucking way more than 17W. Depends on your luck of the draw too - some CPUs just use more power than others.
I had the motherboard replaced under warranty because this thing was getting to 94C in a 22C room _AFTER_ the CPU fan has been replaced. Remember, this is no ordinary load - it's the ultimate CPU torching stress test left to run for a few hours. The new CPU runs 20C cooler under load, so guess how much less power it uses. That's the same same CPU - L7400. Batch, and production date (i.e. revision and even what wafer it came from - a good one or a crappy one) can make a HUGE difference in power consumption.
L2400 vs L7400 - there is no clear winner. L7400 is faster, L2400 runs cooler and uses less power. The difference is not huge either way. Personally I would opt for the L2400 because silence and battery life is more important to me. I use an X61s now with the L7500. These suckers tend to be in the middle between the "old batch" L7400 CPUs from X60s and the coolest running L2400 Yonah chips. It's better in idle because it supports SLFM which the older chipset in X60 does not.
Owned Thinkpads: X300 X201T X200,T X61,s,T,T+ X60,s,T,T+ X41 X40 X31 T510 T500 T410 T400 T400s T61,p T60,p T43 T42 T41,p T40 W500 W700 - favorites in bold
To do list: X301 X220 X220T X201 X201s X200s X201i T420s T410s T420 T520 W510 W701 and future models
I can share my experience with x60t tablet. I replaced the motherboard on used rather cheap x61t one from eBay with Santa Rose and L7400 C2D mainly to get the second PCI slot to install Broadcom HD decoder. Immediately I saw dramatic increase of CPU temp, up to 90+C under stress load. I then removed CPU fan and place Arctic MX-3 thermal paste instead of stock one and saw temp drop up to 10C or even more. Just to mention I removed thermal rubber on second chip (northbridge?) and apply paste on it also, though there is a hole between cooler and chip so it will be better to try to modify cooler somehow.
Even after modification system runs hotter than x60t both idle and under load. Undervolting with PMClock finally gave me approximately the same effect as x60t mainly because L2400 does not allow drop VCore practically at all and L7500 have some room, though I would like to have much lower limit (it is 0.850v on my chip).
CPU fan on x61t runs much louder than on x60t because of higher speed. With TPFanControl it is possible to adjust it but without fan running the system quickly become hot and though the minimal spin is acceptable I can say that x60t fun runs on less FRM than x61t with the same minimal level 1 (there are 3 or 4 real levels of fan speed adjustments).
- 2 Replies
- 215 Views
Last post by tipo33
Sat Jun 10, 2017 4:40 pm
Low Intel X25-M G2 SSD read speed in X60s with AHCI
by dandreye » Wed Feb 08, 2017 5:59 am » in Thinkpad X6x Series incl. X6x Tablet - 19 Replies
- 1962 Views
Last post by dandreye
Mon Mar 06, 2017 7:35 pm
Swapped X61s motherboard into X60s, questions on BIOS version / computrace
by thewanderer » Sun Feb 12, 2017 3:01 pm » in Thinkpad X6x Series incl. X6x Tablet - 10 Replies
- 1627 Views
Thu Feb 16, 2017 9:14 am
FS: X60s, Good Oldie, $60 Shipped OBO
by BobA » Mon Mar 13, 2017 3:16 pm » in Marketplace - Forum Members only - 1 Replies
- 1264 Views
Last post by BobA
Fri Mar 24, 2017 2:03 am
