How much is enough?awolfe63 wrote: I did - seems fine when I do it on a machine with enough RAM.
Maxing out the RAM on T42p
Depends what you try to runcynic wrote:How much is enough?awolfe63 wrote: I did - seems fine when I do it on a machine with enough RAM.
In my case - with 512MB - I could run streaming video with Windows Media Player and run Microsoft Word at the same time. With 2GB - I assume you could do more.
My point is - that I don't think the swap file comes into play until you start to run out of standard RAM - so reducing your available RAM to create a RAMDISK makes little sense for performance.
Andrew Wolfe
It could help to set your ramdisk to be your temp and internet cache folder - although you would lose everything on a reboot.JeffNT326 wrote:The whole point of having a RAMDISK is for the notebook to NEVER have to access the hd due to swapping. This method would increase battery life as the hd doesn't have to be accessed as much.
Also, you can set the ramdisk to be your temp and internet cache folder as well.
In may cases though - it will not. Windows uses excess RAM for a disk cache anyway and you should not be accessing the hard disk due to swapping until you run out of system RAM. Taking away system RAM just encourages swapping and swapping to ramdisk uses more power than using regular system memory.
Also - more DRAM sucks up power - even when it is not being used.
In general, having more RAM than you need wastes power. The problem is that having less ram than you need wastes a *LOT* of power and most of us don't know just how much we need - so it is better to err on the high side.
Andrew Wolfe
X1 Carbon (5th gen, 2017) : 8gb Ram or 16gb Ram , i5 or i7
by asterinex » Tue Apr 25, 2017 4:12 am » in ThinkPad X1/X1C - 26 Replies
- 1989 Views
Last post by w0qj
Sat Apr 29, 2017 11:22 am
How can I find out if I can run Win10 or Win 7 on this T60?
by Muse » Sat Jan 07, 2017 10:29 am » in ThinkPad T6x Series - 15 Replies
- 2230 Views
Last post by sebileis2017
Thu Mar 09, 2017 11:24 am
- 677 Views
Last post by Muse
Mon Apr 24, 2017 7:22 pm
T430 display freaking out
by zv45beta » Sun May 14, 2017 2:55 pm » in ThinkPad T430/T530 and later Series - 4 Replies
- 170 Views
Mon May 15, 2017 7:35 am
