@Verlon,
Thanks for your blog entry. It really encouraged me to work on my Ericsson f3507g WWAN whitelisting for my beloved X201. I have started yesterday but hiting a wall so far. I thought that maybe i will ask you first before i start diging into this rabbit hole. Problem which i have is related to phnxmoding module back to original image. I have recreated the headers (using your script - thanks for that) and whenever i try to execute the phnxmod it is saying that old module was not found in the original image. What am i doing wrong? Here is my procedure.
1. phcomp /d bios.pl1
2. phnxsplit bios.plh
3. phnxpatch ../patches .
4. headers.sh BIOSCODE06.rom.patched BIOSCODE06.rom.new (this is your script)
5. phnxmod bios.flh BIOSCODE06.rom BIOSCODE06.rom.new
Additionally do you know how to disassembly the modules? I've tried several times but it seems i cannot find correct entry point as the computed instructions do not make much sense.
I have tried the phoenix bios editor 2.2 as well, but it is saying "invalid rom size" and fails to open but this could be related to editor being too old for that bios.
Any help will be much appreciated.
Can Someone pm me a modified T61 bios? Thank you.
Could someone send a PM with bios for x60 Tablet (6364-CTO)
Thank
Thank
Got it. Thank you Zender for all his hard work.
Anybody with a T60 BIOS that work with 4965AGN please send a pm. Please............
EDIT: Got it, thank you!
Could someone please pm me the modified BIOS for
T43, type 1871-4AG (latest BIOS is 1.29 at http://download.lenovo.com/lenovo/conte ... .html#bios)
T60, type 2007-68U (latest BIOS is 2.26 at http://download.lenovo.com/lenovo/conte ... .html#bios)
Thank you so much!
Thank you so much!
Present: T61 (UXGA FrankenPad, T9300@2.7, 6200 AGN), T43p (SATA mod, P-M 745a@2.4, TL-WN861N), X60T (SXGA+, 6300 AGN), X31 (TL-WN861N, IDE CF)
Past: W500, R61, T60, X60, T42, R50
Greetings to community!
I have two notebooks:
T60 (15" standard screen 4:3 type 2007-72U)
T61 (14,1" widescreen type 7665-VDE)
On both notebooks I wish to use Intel WiMAX/WiFi Link 5150.
Please, send me modified BIOS for these models.
Thanks in advance.
Thanks in advance.
kvanderlaag
If someone could PM me a modified BIOS for a ThinkPad X60 1706-5KU, that would be fantastic. I have a specific wireless card that I would like to use for specific things.
Does anyone have a patched bios (2.26) for T60 1952-CTO?
Plz PM!
Thx
/R
Plz PM!
Thx
/R
I would be more than grateful if anybody could send me a link to a patched bios for a t60 (1952).
can someone pm me a modified x200 (x200s) bios? Thank you.
JakobsenCPH
Hello All,
Could someone please send me a PM with modified bias for a W500 - 4063-CTO - I need the iso image as i do not own or run that windows tool chain.
Thangs
/jørgen
Virum - Denmark - W500 / T61p / T43 and now with a N900....
Thangs
/jørgen
Hello!
I have been patched BIOS v1.22 for Lenovo X201.
Tests showed, that all works fine. Particularly Intel WiFi/WiMax module 5150 works good.
Patched files, you can download from here http://www.mafet.ru/x201/Lenovo_X201_6q ... telist.rar
Close all applications, make sure you are running the same version (original bios) already, then apply the modded one.
Please note: A biosupdate should be applied when needed only.
Upon opening the WinPhlash, click "Advanced Settings" then check and uncheck the boxes so it looks like this:
("Flags" Tab):
[ ] Verify BIOS part number
[ ] Flash only if BIOS version is different
[ ] Flash only if BIOS version is newer
[ ] Verify BIOS image size
[ ] Verify BIOS checksum
[ ] Zero block before erasing
[x] Verify block after programming
[x] Disable Axx swaping automatic detection (if present)
[ ] Clear CMOS Checksum
("DMI" tab)
"Update": Select "Update the BIOS and not DMI"
Article with description of patch process (in original russian language), you can look here http://habrahabr.ru/blogs/DIY/107598/
Google-translated version is here http://translate.google.ru/translate?js ... F107598%2F
("Flags" Tab):
("DMI" tab)
Hi Mafet,
Thanks for link. Do you know if this patch solves the unauthorized WWAN cards as well?
Now i have been tested WAN module 3G with my patched bios, and got error
ERROR 1804: Unauthorized WAN card is plugged in - Power off and remove the WAN card.
Seems that there is another check function for WAN, that i didn't patch.
Dear all
I have recently bought Unlocked HS 2300 Sierra Wireless card Mc 8775 PCI-E 3G from e-bay.
But Lenovo Think Pad T 400 not allowing to insert WWAN card due to white list restriction.
Kindly help me getting modified Bios for T400 so that I could use the card .
It will better if some body sends PM with link addresses for modified bios for T400.
with regards
VSK
email vs.kush@gmail.com
with regards
VSK
dyleck,
I have been patched BIOS for WWAN cards and now, error 1804 disappeared.
Test with my unauthorised 3G Sierra Wireless MC8775 module on X201, passed successfully - after installing drivers, i can connect to 3G network.
I've uploaded new version of patched file at the same address http://www.mafet.ru/x201/Lenovo_X201_6q ... telist.rar
Please redownload file.
Thanks Mafet. I really appreciate your help. I have hex-edited the bios to include my card and i do not need any more work. However i am pretty sure there are many other who would like to use your bios. You are the men!
Update: I can see that you have updated your page as well. Really great work and much better then the zender's tutorial. Excellent work!!!
Best Regards
Best Regards
Does anybody have the BIOS patch for a X200T?
Much appreciated!
Nez
Much appreciated!
Nez
could someone PM me a patched Bios for T60.
X200s BIOS
Can someone please post me the patched BIOS for X200s?
Mafet,
I have installed your bios cause it was tempting to check how it works. And it works perfectly... almost. The whitelist at boot level is removed however the card is sometimes switched off by ACPI. I have tested on two cards: both Ericsson F3507g - one branded for Lenovo and other by Dell. On Lenovo card it is disconnected randomly (most of the times it is off, however sometimes the card works perfectly). Dell cards is always off and do not allow to be switched on using AT+CFUN=1 command. Both cards work perfectly when pin 20 is taped over (this pin is responsible for power off by RFKILL switch). I believe Zender mentioned about this on his page with tutorial. There is still some work to be done in order to make your bios mod perfect.
If i can help somehow please let me know.
Best Regards
Best Regards
dyleck,
It is strange, because on my X201 both cards works perfectly.
A have this problem, than notebook was with removed cover - wifi signal was unstable.
When i closed notebook - everythink was good. I think it is radio collisions, when notebook was with removed cover, which has a protective screen.
Mafet,
I believe different cards behaves differently. For me it does not matter if cover is removed or not - in both cases signal is ok. But without taping out pin 20 the cards either do not turn on at all or appear in the system on random basis. What cards have you tested?
Awesome, thanks EOMtp. Downloaded and sorted.
Just a note, whilst in DOS (booted form CD) I had to set "PATH=C:\flash", change the directory into the folder containing the .fl1 file then run the flash2 /u command. Easy to do, but for the unwary this should help. Youngsters using only Windows won't know what environment varibles are. ;O)
Regards,
Nez
Regards,
Nez
Respect!mafet wrote:dyleck,
Any body try this bios with X201i type 3626PN6?
IBM X201i, T61
sold: IBM TP 570E, HP\Compaq NC6000, R61, X22, X40 (ssd CF 8GB silicon 300x), X200s
Ntri,
Check if X201i and X201 have the same bios. You can do that by downloading both and compare files (the ones with FL1 extension) by using some checksuming tool. If they are identical then you can safely go ahead. BIOS moded by Mafet works (almost) flawlessly.
Yes, rightly.dyleck wrote:Ntri,
I flash this bios on my X201i. WiMax card 5150 startup immediately. But my 3G MC8775 not detected.
I enter to bios and load default settings, 3G modem detected and work perfect.
Again, big thaks to Mafet
IBM X201i, T61
Ntri,
Please make sure that your card is always detected. You might have the same problem what i have. Card appears on random basis. I have played with bios the whole day and it did not make any difference. Taping out pin 20 did the trick eventually. Let us know if your card stard disappearing.
Best
Best
WillieGizz
Does anyone have a patch for the T410 that will allow Centrino Advanced 6300 Wireless Card to work in the T410?
If someone can help please e-mail me at mjadams1@gmail.com.
Thanks,
Mike
Thanks,
Mike
- 800 Views
Sun Apr 23, 2017 11:47 am
- 751 Views
Last post by TPFanatic
Thu Apr 27, 2017 6:28 pm
x60 whitelist bios link
- 1889 Views
Mon Jan 30, 2017 7:09 am
- 914 Views
Sun Feb 12, 2017 7:41 am
