Hello all,
Could someone please provide me with modified BIOS for my T400?
Lenovo T400 6475-1R9 (Currently running BIOS:7UET82WW)/Windows 7(64bit)
Card: Qualcomm GOBI 2000 FRU 60Y3183
Thanx!
Thanx!
“Bad sex better then good work day”
I see from recent posts that Zender isn't around anymore to reply to PMs. If someone has a modified T61 BIOS, could I trouble you to send it?
I've tried building one myself and find myself stuck at the same:
phnxmod bios.flh bioscod5.mod.old bioscod5.mod
Loading data...Old module (without header) not found in the ROM file. Quitting.
that another person got hung up at.
Thank you very much.
-Dan
-Dan
Nub here looking for R500 BIOS so my new Atheros card can work and disable the 1802. Since I see that zender isn't available these days for PM, could someone point me in the direction for getting the fixed BIOS? I'm trying to learn how to do it on my own, but it's a long process, and I have a class coming up in less than 2 weeks. Any help would be appreciated.
Regards,
Natalie
Regards,
Natalie
could someone PM me a patched Bios for T43.
thank's
thank's
Check the T43 forum for the No Error 2010 thread: http://forum.thinkpads.com/viewtopic.php?f=2&t=92115Nibker wrote:Hi,
thank's
As per first posting, I PM'd Zender over a week ago, so is it possible someone has a modded bios for a IBM Lenovo T500 (2241-V7N)? I'm looking to put a non IBM WWAN card in this.
Many thanks for any help.
Zender is not responding to PM anymore...
Any chance that somebody have his version of bios for R61i 15.4" WITHOUT Firewire poret Machine Type 7650?
PM with link would be appreciated.
With best regards
With best regards
Blue Thunder
[EDIT: I've recently had to replace a faulty RAM module, so it may have been the root cause of my problems outlined below rather than the modified BIOS]
Not sure if this problem has already been addressed (couldn't find it using the search) but I installed a non-IBM/Lenovo WWAN into a T60p awhile ago and was able to boot thanks to one of Zender's modified bios roms. [EDIT: It was actually Lenovo branded Sierra Wireless MC8775 WWAN card. But that card was only available in the T61, so it was still blacklisted on my T60p].
However just recently I decided to set power-on, supervisor and hdd passwords. After saving the settings and rebooting, the computer hung at the bios splash screen. The computer wasn't frozen or unresponsive (pressing the blue ThinkVantage or F1 button made the text change and ctrl+alt+del worked) but it wouldn't proceed further. At first I thought I had somehow bricked it. Removing the hard drive from the computer didn't help, but then I remembered that I had flashed a modified bios to allow me to use a non-IBM/Lenovo WWAN card. So I removed the WWAN card and the computer booted up normally, prompting for all three password types that I had set.
I was so glad I hadn't bricked my computer but I'm not sure why the it hangs with the WWAN card installed. After a little experiment I've determined that only two of the three password types seem to cause problems.
1. Setting a power-on password prevents the computer from proceeding past the bios splash screen.
2. Setting a supervisor password prevents the computer from proceeding past the "Startup Interrupt Menu" screen (if the blue ThinkVantage button is pressed) or gives a blank black screen if F1 is pressed to enter the bios setup utility.
3. Setting a hdd password (user only or user+master) will allow the computer to boot normally and allow access to the bios setup utility without any apparent problems.
Perhaps the two passwords types that are causing problems rely on hardware checks that were disabled/corrupted when the code was modified to allow our Thinkpads (or at least the T60p) to boot with "unauthorised" WWAN cards.
Zender might already known about this issue (can't remember since I installed the modified bios awhile ago) and may have fixed it already.
Oh and DanijelM, hoppinbob, darkfrog, bolverk and caleb2 - check your PM's.
(Not sure if you guys still needed help).
BT - R50, T60p, X60T.
"Freshman"!? I ain't fresh...
Trying to install a Verizon WWAN card card from my old Z60t into my new T410
Could someone please PM me a patched bios for the T410? Thank you!
Sorry, no just animal!r0bi wrote:... patched bios for the T410 ...
If someone has the modified Bios for the Thinkpad x60 (Type 1706-8DU) could you please PM to me? I am trying to get a Broadcom BCM94321MC Wlan PCI card working in my x60.
Thanks in advance.
Jon
Thanks in advance.
Jon
Meaning it doesn't exist yet? or not doable?EOMtp wrote:Sorry, no just animal!
Does not exist. Remains to be seen whether or not anyone capable of making the mods will undertake the task. I remember vaguely some discussion of how the new BIOSs are encrypted somehow, and that renders them nearly impossible to alter ... but I can't recall if that "discussion" was reality or my imagination!r0bi wrote:Meaning it doesn't exist yet? or not doable?
bill bolton
That is my understanding as well, so its probably not your imagination.EOMtp wrote:....but I can't recall if that "discussion" was reality or my imagination!
Bill B.
There is indeed no Zender-BIOS version for the T410/T510/W510.
The following infos have not been declared as "classified" by Zender.
Use them at your own risk/peril.
The BIOS-mod Story
Guide for ThinkPad BIOS hacking
The BIOS-mod Story
... and X201[/s] -- Not from Zender, and not from any of the other sources that have produced similar patched Thinkpad BIOSs.RealBlackStuff wrote:There is indeed no Zender-BIOS version for the T410/T510/W510.
Thank you. I've had some experience with this sort of thing in the past, figured I'd ask before going through the effort. I'll let you know if I'm successful.
thinkpad4me
Does anyone have the zender bios for a X61s? (type: 7666-AG6)
TIA
TIA
X61s Type:7666-AG6, 2GB RAM, 100GB HD, Apple AR5BXB72 Mini PCI-e 802.11N Wireless Wifi Card in WAN slot with Modded Bios 2.21.
Does anyone have zender bios for T60p 2613-CTO? And how it works, any bugs? Could someone send it, please?
greetings
greetings
currently: T60p 2613-CTO,
past: T61, T41, T30, T21
Can someone please pm me the hacked bios for x200? Thanks.
hello
i need bios for t60 type 2007 fvg to work with mc5725(not lenovo branded)
please send me an link or something
sorry for my bad english
thank you
thank you
Hi Guys,
I'm looking for the most recent modified BIOS for the T60 Type 2623-D7U so I can add an Intel 5100. Lenovo-branded if I have to go with that, but I already have a spare 5100, so if I can get around things completely, I'd like to.
If anyone could PM me with where I could get this, preferably based off the 2.26 BIOS, I'd greatly appreciate it.
"I think politicians should be painted/decaled/stickered like NASCAR, that way you know who owns them at a glance." -Crackhead Johnny, TR Forums
ThinkPad T420, 2520M, 8GB, mSATA SSD, 500GB Scorpio Black, HD+, Intel 6300, running Win7 x64 Ent SP1
I don't mean to post to this thread so much, but according to other posts zender isn't responding to pms?? If anyone is wandering the thread with access to the X200 ZENDER BIOS could you kindly pm me?
My laptop is in pieces right now as I wait for the bios. Thank you so much in advance.
Help with Fn+F5.
Thank you so much EOMtp!
I've installed the bios on my x200 and have my Option GTM378 WORKING. I couldn't get it to work with Access Connections though. I kept getting this error that another utility was using the card but there was nothing else I could find using it. I finally downloaded the official Option Connection Manager from there website called GlobeTrotter connect at that works!
The only thing left to get working is the Fn+F5. Which is unfortunately not working. When I had AC installed, after modifying the Dlls it would show up. but when I tried to use Fn+F5 to change the status it would then disappear. Note: it would still show up in AC though (although non-functional giving the error mentioned above).
Since I'm using the Option connection manager I have un-installed AC and am now using Tpfnf5.exe. However, even after adding my DEVID to with hexeditor it does not even show up at all. Does anyone have any hints how I can get FN+F5 working with the Option GTM378? I would really like this to work since the Option util has no control for on/off.
I am also looking for the x200 (actually an x200s) whitelist removed BIOS. I've tried a few PMs, but if anyone has it, please PM me. Thanks!
Dan,bolverk wrote:I see from recent posts that Zender isn't around anymore to reply to PMs. If someone has a modified T61 BIOS, could I trouble you to send it?
-Dan
middleton from forums.notebookreview.com has also modified the bios for T61 to remove the whitelist issue, among other things. You could use that BIOS if it suits you and you are also OK with all the other modifications that come with it.
Be sure to note that this is a hacked BIOS and as such, I don't think you can blame the author if by flashing it all hell breaks loose
http://forum.notebookreview.com/lenovo- ... ost6501443
All the best,
Panagiotis
Currently own:
X41 Tablet
T601 FrankenPad
X201 Tablet
X220
Previously owned:
X61 (x4), X61F (T8300, AFFS SXGA+), X61s (x3), X61 Tablet SXGA+, X201 with ultrabase+DVDRW, T60 XGA, T500
I am so broke, I can't even pay attention.
X41 Tablet
T601 FrankenPad
X201 Tablet
X220
Previously owned:
EOMtp wrote:Does not exist. Remains to be seen whether or not anyone capable of making the mods will undertake the task. I remember vaguely some discussion of how the new BIOSs are encrypted somehow, and that renders them nearly impossible to alter ... but I can't recall if that "discussion" was reality or my imagination!
Not entirely true. I know of another place you can go to get the BIOS "made up" custom. They can hack it in a few hours. They call the modding process for the BIOS, the "endeer"/"ender" method. Guy seems to be using Zender's tutorial to make them. He is pretty adept at doing it... Any who, please reference this post to see what I mean.
LINK: http://forum.thinkpads.com/viewtopic.ph ... &start=120, last post on page five by me.
Does anyone have tutorial for bios modyfication? I think that is already no one here who have T60 zender bios
The place seems abandoned by Zender.
for those who want's error 1802/1804 removed, follow the link http://forum.thinkpads.com/viewtopic.ph ... 48#p603448 and make a request.
regards
TTAV134
regards
TTAV134
- 800 Views
Sun Apr 23, 2017 11:47 am
- 751 Views
Last post by TPFanatic
Thu Apr 27, 2017 6:28 pm
x60 whitelist bios link
- 1889 Views
Mon Jan 30, 2017 7:09 am
- 914 Views
Sun Feb 12, 2017 7:41 am
