I'm looking for whitelist "mis-feature" disabled bios for t400, here is what I currently have:
Product Name: 2764CTO
Version: ThinkPad T400
bios:
Version: 7UET89WW (3.19 )
Release Date: 08/02/2010
bios:
http://forum.thinkpads.com/viewtopic.ph ... 75#p607775arekm wrote:I'm looking for whitelist "mis-feature" disabled bios for t400, here is what I currently have:
bios:
Bitlocker issue
Ok, I have Zenders BIOS for the T60. Finally got round to fitting an Intel 5100 card. When I try to flash the BIOS, I get an error message that the drive is Bitlocker encrypted, and will be unreadable after a flash (!). Odd, as I'm dual booting XP and Ubuntu (with ext3 and swap partitions), and of course the hidden (windows 2k?) restore partition...
Does anyone know how to force the flash? Its error code 99
Many thanks
edit: updtflsh.exe at the c> prompt and telling it to proceed despite the risks....
Many thanks
ist it a DOS based flash, have you tried flashing from windows using this method: http://forums.mydigitallife.info/thread ... post354748alewis wrote:Bitlocker issue
Many thanks
Running updtflsh.exe does the trick. You have to 'yes" a couple of warning dialogues. That said
On reboot there was a brief error message. Cant recall the details, and hasn't repeated.
The BIOS has entries for serial and parallel ports. I don't recall seeing them before (original BIOS was v2.something, dated early 2007). Or am I 'imaging' that there were no entries as the machine has no ports...?
All works ok. Didn't realise that the main difference between the Intel5100 and 5300 is the 3rd antenna access the 5GHz (a) band. Neither did I realise I had bought a mini-mini PCI-e card, its about 1/3 the lenght of the Atheros card, as a consequence the end of the baord cannot be screwed into the mounting holes. But it works. For now.
Cheers all - have a great Xmas and wish all the best for NY 2011
AlexeyTolstyh
Hello all,
Is there anyone who could let me know where I can get a patched Whitelist BIOS for R60 (9462-Y16) and X60 (1709-97U)?
http://forum.thinkpads.com/viewtopic.ph ... 75#p607775AlexeyTolstyh wrote:Hello all,
Geez, just answer here instead of redirecting to redirection to another thread about the same issue.TTav134 wrote: http://forum.thinkpads.com/viewtopic.ph ... 75#p607775
follow the links and make the request on the other forum, and i will do it immediately.arekm wrote: Geez, just answer here instead of redirecting to redirection to another thread about the same issue.
No need to do such silly things! No idea why it's so hard for you to respond directly and instead you are asking people to generate more and more duplicate posts.TTav134 wrote: follow the links and make the request on the other forum, and i will do it immediately.
Other respond here on PM anyway, so no need to waste bandwidth. Thanks!
What is the proper way to ask for an 1802 mod bios for the ThinkPad R61e?
Thaks very much in advance!
-SM
-SM
ThinkPad R61e with whitelist removedbsmeeler wrote:What is the proper way to ask for an 1802 mod bios for the ThinkPad R61e?
-SM
i need a bios for a thinkpad r500, i already wrote a pm to zender but there was no reply, can anyone help me? I wanted to build in a intel WiFi Link 5300 an got a massage that this card i wrong...
thanks
Markus
thanks
Markus
With Zender's permission The Board Room is now hosting his modified BIOS files.
Please note that I will NOT answer ANY questions about this under ANY circumstance!
Here is where you can find the Zender BIOS files
Once there, click on Zender-BIOS in the menu on the left.
Dear Proffesionals!
Could anyone instruct me....? I have X41T.. Trying to change my internal wi-fi card to one with Atheros chipset. And off course have 1802 issue message during booting... )))
So, ive made sure that for my X41T there is tested BIOS which was prepared by our Zender in Board Room web-site. Thanks to him! ))) Ive downloaded file for my laptop with extension like *.fl1. In Notes section there is the following message: FL1 file only, also available: uncompressed/wph and floppy. Could you kindly please instruct me what should i do with that file? Create boot disk with this file?
Thank you very much!
Is it possible that anybody send me a modified bios for de dammed 1802 error. I have T60.
Thanks a lot.
Thanks a lot.
Have you tried to quickly scan this page with your eyes? Answer is in Red just 2 posts above yours... :/
bodo130192
i need mod bios for Ibm r32 please if it's possible... if you can send it to bodo130192@hotmail.com ^:)^ thanks a lot
bodo130192
I got this error, 1802 on my IBM R32 and i need mod bios. Can someone help me? I'll apreciate it
Admin note: Deleted duplicate request post. The file can be downloaded from the post by RBS just above OR from the FIRST post of this thread.
bodo130192 - Look for forum member RealBlackStuff posting ON THIS PAGE a few posts back (Tue 04 Jan, 2011 20:53 50) - Click the the large blue lettering link: Zender BIOS files -
ferrari987
Firstly, I want to thank Zender for the great modded BIOS. I have a T60 (2007-VEH) with Intel Wifi 5300. The BIOS error does not occur anymore (thanks to the new BIOS) but I have a major issue:
The wifi card only works in Windows (7). If I start ubuntu 10.10 the card is somehow not activated (lspci finds the correct card), the LED is never blinking once while booting into linux.
Of course I tried the activation switch (both Fn and hardware) but nothing changed.
Any suggestions?
thanks,
ferrari987
Any suggestions?
thanks,
ferrari987
Hi all
I have read a lot about the BIOS problems.
Just 2 things:
Can anyone with t60 confirm the process is OK? I got the BIOS from the suggested page above and for t60.
In case of problems, is there a way of reverting back to old original BIOS?
I am planning to upgrade from the wifi below to a Intel 4965AGN which I believe is not lenovo branded since it comes from a sony laptop.
Just 2 things:
T60 8743-cto, 64 GB C300 SSD, UB HDD - 200GB 7200, ATI MR X1400 @ 1680x1050, 3 GB RAM, Core 2 Duo T7200 2 GHz, Atheros WIFI N, IntelPRO/1000 PL, DVDRW, Win XP pro/Ubuntu 10.10
silvrcloud2003
Worked flawlessly on my T60, which I upgraded to an Intel 5300 from HP.garnet wrote:Hi all
Just 2 things:
Thinkpad T60 2623-KEU: Core 2 Duo T5600@1.83Ghz, 2GB RAM, Seagate 250GB HD@7200RPM, ATI X1300, Intel WiFi Link 5300, Zender's modded BIOS 2.25
Would someone be so kind as to PM me the files needed to take away the 1802 error? I have the x200T and would like to use a different wireless card, thanks!
silvrcloud2003
Scroll up about 9 posts and look at RealBlackStuff's message.kobe_08 wrote:Would someone be so kind as to PM me the files needed to take away the 1802 error? I have the x200T and would like to use a different wireless card, thanks!
Thank you silvrcloud!silvrcloud2003 wrote:Scroll up about 9 posts and look at RealBlackStuff's message.
I did try and use the bios files that were within that post, but winphlash wouldn't flash (currupted bios file). There were no CD files, so I don't know what I'm doing wrong.
Hello everyone.
I want to use gobi2000 in my t400s.(already buy one...)
Could someone PM me a patched BIOS link?....
Thank you for advanced.
Welcome to the forum -
See previous posting on this page from forum member: RealBlackStuff - Please read his post carefully and click on the link: Zender BIOS files
There has now been several requests for links to the modified BIOS AFTER RBS has already posted where to get it. For anyone that is looking for a copy of Zener's BIOS, please read the FIRST post in this thread and you will find what you are looking for. I will be temporarily locking this thread and will delete these "request" posts.
To repeat, click in this link ---> http://forum.thinkpads.com/viewtopic.ph ... 12#p378212 to get the information on where to download the file.
edit Dec. 4, 2011: As of today, the Zender BIOS files are not longer available at The Board Room (due to the hosting policies in effect there). It has been suggested that you visit MyDigitialLife for any assistance. Thank you!
- 795 Views
Sun Apr 23, 2017 11:47 am
- 745 Views
Last post by TPFanatic
Thu Apr 27, 2017 6:28 pm
x60 whitelist bios link
- 1884 Views
Mon Jan 30, 2017 7:09 am
- 913 Views
Sun Feb 12, 2017 7:41 am
