Locked
fitzcarraldo
Re: T6x BIOS device whitelist (error 1802/1804) [solved]
#481 Post by fitzcarraldo » Sat Sep 05, 2009 6:41 am
Just wanted to inform you, that there's an eBay seller from Hong Kong "goezshopping" who sells brandnew Sierra MC8775 3G-MiniPCIe cards for <$40 including worldwide shipping. I have bought one of these and it arrived within 2 weeks in perfect, brandnew condition.
What the seller "hides" is, that you can update it easily to support HSDPA with 7.2 MBit/s. Details on firmware updates etc. can be found at http://3g-modem.wetpaint.com/page/Sierr ... 26+MC8775v
That's a real bargain in my eyes!
EOMtp
#482 Post by EOMtp » Sat Sep 05, 2009 10:24 pm
fitzcarraldo: Thank you for the information. Did the MC8775 card you received have 1 or 2 antenna connectors?
fitzcarraldo
#483 Post by fitzcarraldo » Sun Sep 06, 2009 3:42 am
The MC8775 I received is actually the OEM-version for HP (HP Hs2300) and it only has 1 antenna connector (like the Asus OEM-version, too), but I haven't observed any difference in signal quality compared to my Huawei USB-modems, that have diversity (2 antennas). I think the bigger antenna in the laptop compensates the lack of a second antenna.
EOMtp
#484 Post by EOMtp » Sun Sep 06, 2009 4:36 am
I thought that 7.2Mbps required "diversity", i.e., at least 2 antennas, and it was not possible to get there with a single antenna. I am curious if you know for a fact that the MC8775 with the newest firmware can -- and actually does -- operate as high as 7.2Mbps, or if you simply assume that it does because the firmware is supposed to support that speed.
fitzcarraldo
#485 Post by fitzcarraldo » Sun Sep 06, 2009 5:43 am
I have successfully updated my card to 7.2 MBit/s, which reached up to 4.5 MBit/s downstream afterwards. As you can see from the chart below diversity improves throughput, but it's not obligatory:
For HSDPA with 7.2 MBit/s either QPSK- or 16-QAM-modulation is used, source: http://www.mobilehandsetdesignline.com/howto/189800068
But having used many HSPA-enabled 3G-networks across Europe, I learned that in practice you will very rarely reach data rates above 4 MBit/s, which is mainly caused by the lack of capacity of the backhaul and of the air interface.
For further discussion on 3G and the MC8775 in particular we should move to http://forum.thinkpads.com/viewtopic.php?f=30&t=61677
Mahdi
#486 Post by Mahdi » Sun Sep 06, 2009 6:01 am
Hi all,
I'm new here and I'm also looking for a modified BIOS. I've pm'ed Zender 1,5 week ago but he isn't responding. If anyone could help me with a modified BIOS it would be much appreciated. My BIOS version is 2.26-1.08 (2009-05-11).
Edit:
Thanks guys, it works like a charm
iwacemaker
#487 Post by iwacemaker » Sun Sep 06, 2009 6:36 pm
Hi everyone....
Is Zender back here yet? I've been waiting for him to pm me back about a T60 mod BIOS but it's been 2 weeks... :(
Can someone PM me if you have a copy on hand? Much appreciated!
samex
#488 Post by samex » Tue Sep 08, 2009 7:27 am
Me too pls I need a patched BIOS for T61.
cesaer
#489 Post by cesaer » Tue Sep 08, 2009 11:29 am
me to..
x300, 6476CTR with the sierra mc5720
Faebu
#490 Post by Faebu » Tue Sep 08, 2009 6:19 pm
...And one more over here..
I sent Zender a PM regarding the modifed Bios for a T43 two weeks ago. Unfortunately he didn't respond until now, so if sombody could send me the modified T43 Bios I would very much appreciate.
EDIT: Thanks to all. Works absolutely fine with a T43 Mainboard and a Intel Pro/Wireless LAN 2100 Mini-PCI Card originaly from a T40. Only the Fn + F5 combination isn't working yet, but I'm confident that I will be able to fix that soon.
Best regards
parleyp
#491 Post by parleyp » Thu Sep 10, 2009 10:35 am
Zender is back...I have been pm'ing these out as I see the requests but I did get a PM from him this morning. I have subscribed to the thread so if you post the request in the thread, I will send you the link.
It is helpful that once you install, that you report back to the thread by editing your request and saying if you were successful.
From my view, Zender can't be thanked enough. He has given us freedom to use the cards of our own choice which are always less expensive than the lenovo/ibm option and usually work better. Thanks again Zender.
Parley
Zender
#492 Post by Zender » Thu Sep 10, 2009 10:54 am
Hello everyone. I'm sorry for just disappearing, everyone should have received their link by now, if they haven't already :)
@yak: The only thing that I think could help is somehow delaying the powerup of the card, so that it does not respond when the test takes place. The test only takes place after power up, not on subsequent restarts/sleeps (and if I remember well even hibernation didn't trigger the error - you can test by connecting the card when computer is hibernated, worked for me on WinXP).
0zouri
#493 Post by 0zouri » Thu Sep 10, 2009 1:09 pm
Hello, new user here. I am trying to upgrade my trusty R32 (2658 G3G) which still works like a dream.
Does anybody has a modified BIOS to send me ? I sent a message to Zender but I dont know if he is around, so i am letting everybody know.
I just got an Intel Pro/Wireless 2200BG and I would like to use it on my R32. Hopefully the modified BIOS will work.
I also downloaded a bios image from the thread found here: http://forum.thinkpads.com/viewtopic.ph ... 02#p407228
Did anybody have any luck with this file ?
bobbytan
#494 Post by bobbytan » Sat Sep 12, 2009 2:51 am
Had anyone tried successfully having Lenovo Intel 5300AGN in their X61 series, do you need the modified bios from Zender or just by tapping pin 20 will do the trick?
ThinkPad X220 IPS / Windows 7 PRO 64bit / i7-2620M / 8GB Samsung PC3-10600 / (WLAN) Intel 6205 Advanced-N / (WWAN) Sony Ericsson F5521GW / OCZ Vertex 3 120GB (Main) + OCZ Vertex 2 200GB (Ultrabay)
fuxxi
#495 Post by fuxxi » Mon Sep 14, 2009 3:03 pm
its a lil bit oot but:
Did anybody made a BIOS-MOD for the T40-T42 and R50-R51 series? Nothing on Zenders BIOS-Mod-Site :(
I know we can use 1802 there, but i need this hard mod, so nobody can reset and disable it again via setting up default values in BIOS.
Im really curious, since there are soo much modded bios' already, that only t40-t42 is missing.. shouldnt be that hard for the geeks to mod it? :?
Thanx for any help!
Zender
#496 Post by Zender » Mon Sep 14, 2009 9:44 pm
I'll try to make one with the next batch later this week.
fuxxi
#497 Post by fuxxi » Tue Sep 15, 2009 12:45 am
Zender wrote:I'll try to make one with the next batch later this week.
Nice one, Thank You!! :mrgreen:
yak
#498 Post by yak » Tue Sep 15, 2009 5:02 pm
Zender wrote:The only thing that I think could help is somehow delaying the powerup of the card, so that it does not respond when the test takes place. The test only takes place after power up, not on subsequent restarts/sleeps (and if I remember well even hibernation didn't trigger the error - you can test by connecting the card when computer is hibernated, worked for me on WinXP).
Seems like a good idea. This essentially means delaying the +5V line. The problem is, I don't have enough electronics knowledge to do it. The simplest circuit would probably consist mainly of a capacitor but delaying for couple of seconds could require quite a big capacitor. But I'm not sure. Do you know more about this stuff?
And thanks for the PM, I did missed your reply.
ThinkPad™ X201 / AFFS-120
j212
#499 Post by j212 » Thu Sep 17, 2009 1:29 am
can someone foward a t60 image that zender has already modded.
I haved PM'ed him but i have no reply.
j212
#500 Post by j212 » Thu Sep 17, 2009 2:22 am
Zender
thank you very much.
i just want to add my 2 cents
I did not use the ISO to burn an image, i did it from windows without the need of a restart.
1. I used the lenovo provided 79uj30uc (utility not ISO)
2.I extracted the setup.exe with winrar by right clicking and extracting to a directory
3.replaced the FL1 and FL2 files form what is provide by lenovo with your stuff
4. open a command prompt, navigated to the directory in which i extracted and replaced the files and typed
WINUPTP.EXE -s
-s will ignore that the bios version is the same as the one being installed.
what is really neat it that i found out what WINUPTP.EXE is doing with WinPhlash.exe
winphlash /mode=2 /mb /vcpu /remote2 /cs /vbld $01A3000.FL1
winphlash /mode=2 /remote2 /cs /vbld $01A3000.FL2
you can make a bat file and completely forget about WINUPTP.EXE -s
This may be harmful of course, take the same precautions lenovo provides on there site.
but it's a nice quick hack
thanks again.
ukprometheus
#501 Post by ukprometheus » Thu Sep 17, 2009 5:32 am
can someone suggest a wireless N card for my t60, also do the newer N cards still need the third antenna
Duney
#502 Post by Duney » Fri Sep 18, 2009 10:07 am
I used the modified bios to perform a biosupdate on my T60p and that worked perfectly.
Now i can use the speed of wireless N with the intel 5100 card.
Nice work!
@ukprometheus the intel wifi 5100 uses two antenna's
duhwane
#503 Post by duhwane » Fri Sep 18, 2009 1:51 pm
I'm game...I have a new T400 that needs to run an ex-Dell Cingular mini-PCIe 3G card. (you have PM)
gnychis
#504 Post by gnychis » Fri Sep 18, 2009 11:42 pm
just in case someone has the BIOS for this before Zender gets back to me:
X300 6477CTO
that is either a 'o' or a zero on the end, i can't tell
Zender
#505 Post by Zender » Sat Sep 19, 2009 6:15 am
Please stop posting BIOS requests here.
@gnychis: I have received no message from you?
Admin Edit: Message text size increased for appropriate emphasis.
As previously indicated numerous times in this long topic thread, you need to PM Zender with a BIOS request, and he will respond when he is able to!
jonglo
#506 Post by jonglo » Fri Sep 25, 2009 11:10 pm
bios is the only thing that worked for me, I tried everything else.
X60s and Sierra MC5725
no pin 20 mods, in their normal slots, with zenders bios.
Everything works, thanks Zender!
Why dont you put the bios's up on rapidshare or something, why go through the PM process 2 years after you made the bios's?
mastermo
#507 Post by mastermo » Mon Oct 05, 2009 3:05 am
Hello guys!
Today I received the link to the bios page and already flashed my T43 (2669-44G) with it.
It worked great and now I don't have any 1802 error while booting.
My question is: Do I have to performe any pin taping?
Zenders pages states, that the bios for my T43 only skippes the error and will most likely need some tape...problem is: Which pin to tape? I know, that you are supposed to tape pin 20 on miniPCI express card, but mine is not an express card but a usual miniPCI card. Which pin to tape? or don't I have to tape any pin?
I currently can't test if wirless already works, as there is no Windows installed on the device (playing around with Mac OS X :mrgreen: )
Thanks guys
and @Zender: Keep up the GREAT work :bow:
lobonet
#508 Post by lobonet » Tue Oct 06, 2009 5:26 pm
i have the problem 1802 whit my wifi atheros and send a pm to zender for the bios mod for my lenovo T61 i hope soon sendme a file jejeje
regards
boogieman28
#509 Post by boogieman28 » Wed Oct 07, 2009 9:03 am
Hi guys,
I just installed Zender's bios fix and it bypassed the infamous error just fine (Thanks Zender!) but now the Windows7 won't detect the wifi card. I'm running a T60 with an intel 5100 wifi card.
Any help would be appreciated.
AA666
#510 Post by AA666 » Tue Oct 20, 2009 1:05 pm
Hi all,
Can someone share Zender's modded BIOS for x200.
P.S. PM to Zender sent week ago
Locked
