I was planning on adding both the 5100 and upgrading to the core 2 duo on my T60p. Does this combination upgrade cause problems? You mentioned "you fried it"Feraturion:
Yeah I have a WiFi link 5100 working with zenders Bios on a T60 so it works.
And i think you earlyier fry your cpu than something go's wrong while updating your bios.
Yeah i fried it en replaced it by a core 2 duo (bright side is it runs windows 7 64-bit)
Thanks.
-Roy
