Hi. I have the X60 1706-CTO, i tried to fit it with this Intel Link 5100 but no luck, must remove card and restart... can u send me some supported bios?
Kind regards
Arthur (y20)
Kind regards
Arthur (y20)
Wednesday I pm'd Zender looking for a t61p (6459-CTO) bios that would work with the Intel 5100 wireless card I got last week. After waiting beyond the requested 48 hours to post here i'm hoping somebody with a compatible bios can send it along to me.
I'm currently running Windows 7 Home Premium 64bit, so I know i'll need to create a bootable cd with the new bios. I'll be reading up on how to do that in the meanwhile. Many thanks, Zender for the great solution you've provided here to a very silly move by lenovo.
Thinkpad T61p 2GHz, WUXGA, 100GB 7200rpm, 1GB turbo cache, Bluetooth, nvidia quadro 570m
ukprometheus
just ordered up an intel 5300 for my t60 off ebay lets hope this bad boy works ok and the fn f5 and switch work
Does anybody have modified BIOS for X60? I asked Zender few days ago, but he didn't answer :/
ukprometheus
intel 5300 installed with zenders modded bios in t60 and running sweet
I could need some help getting my Intel Centrino 6300 Ultimate-N to work with my Lenovo ThinkPad T400s (2808-CVG) running BIOS v.1.12-1.02
Thanks all.
I was able to shift my BIOS backwards to 3.11 with as I loaded Zender's patched BIOS then install the Lenovo Gobi 2000 card. Both WWAN and GPS are working well now using Access Connections in Win7 Pro with Lenovo drivers. Both Hardware Switch and F5 menu also work; Cheers!
X200t, R61, R50, iPhone, Edge 705, Nuvi 255w, Nuvi 255
There's still no luck for my X100e
Thanks to Zender, it's smooth sailing on my t61p and intel 5100! Although now i'm thinking a 5300 would've been a better choice for max speed... Newegg only had the 5100...tmuka wrote:Wednesday I pm'd Zender looking for a t61p (6459-CTO) bios that would work with the Intel 5100 wireless card I got last week. After waiting beyond the requested 48 hours to post here i'm hoping somebody with a compatible bios can send it along to me.
Is there anyway to get my old Ericcson F3507g WWAN card to work on my new Thinkpad X201? Is there a whitelist Bios for the X201?
patch bios t400 2768-bb1 fixed wwan f3507g (remove from toshiba A600) ?
Hi all. I have Zender and he probably is busy and hasn't respond yet. Anyone has the T60 2007-D58?
It is a T60 14.1" 1024x768 screen.
Thanks and appreciated.
TheRunner789
Hi! PM'd Zender looking for updated bios for T61 7659-12U and a Intel 4965AGN that are not playing well together. Waited the 48 hours , but no reply. Can anyone help with compatible updated bios? Thanks!
Sorry for the post. I sent the required PM on Wednesday. If someone has a copy of the modded T61 BIOS, they can PM it to me and I would be very grateful.. Otherwise I'll wait for Zender. It is not that important. I am trying to get a MC8765 working in my laptop. I could not see paying 75+ dollars on everyone's favorite online auction site for a MC8775, even if its data rates are faster and it is on the whitelist.
Thanks!!!
EDIT: Thanks to those who replied to my request. Installed BIOS, installed drivers, installed carrier's connection manager. It connected fine and I can now enjoy internet on-the-go!
Also, mine T61 has the 15.4" screen.
Thanks to Zender for the hard work in developing a workaround to the whitelist!
Thanks!!!
Anyone got it working on a x60s? Please let me know by PM, thanks!
EDIT:
To all interested in using none-whitelisted wireless cards, check out theise BIOSes:
http://forums.mydigitallife.info/thread ... y-Thinkpad
The one for X60 worked just fine on my X60s and it now accepts my new Atheros AR9280 300M.
EDIT:
djphunknasty
If anyone happens to have a modified bios for the IBM T60 offhand they can send me, I'd also be greatly appreciative. Thanks guys!
has anyone BIOS for T60 and R60e ? ==> have now a solution!! thanks for your hints!
THANKS!
Michael
THANKS!
Michael
Hi. I'm getting a T61 and thinking about the Gobi 2000. Did install a Gobi 2000 in a T6x using Zender's bios? If so, do you think a Gobi 2000 card that's not Lenovo branded will work?kspear wrote:Thanks all.
thanks
Hi all.
I received Zender's BIOS and it work correctly!
Thinkpad T60 20074AJ Windows 7
+ Intel 4965AG
thanks.
+ Intel 4965AG
thanks.
Sorry to report, but the latest patched T500 BIOS failed to allow a Dell 5530 WWAN card to work in my T500.
Current laptop: X1 Carbon 3
Current workstation: noneRe: ThinkPad BIOS whitelist (error 1802/1804) *READ 1st MSG*
Hi. I want to use MC8775 on Lenovo T510 but there is no whitelist mod founded. Can you help me?
Hello Dear Members,
I've send PM to Zender with request for modified bios for T400. I'm sticking to the rules in first post of this topic, so I've waited for 72h.
I would like to ask here, maybe someone has a copy and is willing to share with me.
waliak
waliak
I have an x301 and removed the Ericson WWAN, replaced it with a Gobi 2000. I get:
"ERROR 1804: Unauthorized WAN card is plugged in - Power off and remove the WAN card."
I’m running on BIOS Version 3.10-1.05. Can anyone help?
I've PM'd.
I've PM'd.
Tnx for the PM guys. Works perfect with my Sierra. Couldn't get the Gobi to activate, but there aren't many ATT 7.2 locations for it to matter right now.
Gobi 2000 in X301 - 2777 CTO.
Thanks Zender! Just Got the PM and installed modified BIOS. I had 3.10 -1.05 and downgraded to patched 3.09 – 1.05.
Got the driver package for the X201. Access Connections works.
Gobi 2000 works and I can swap back and forth from AT&T and Verizon networks back and forth. Will try Vodafone in GB next week.
GPS also works but only in standalone mode. No A-GPS option is available. I feel it’s a driver issue since I’m using the ones for the X201 instead of the ones for the X301?
I too have waited the requested 48 hours, and completely appreciate that Zender is a busy fellow. I am looking for a z61e bios. Any help is appreciated.
Hi folks. I rent a PM to Zender as well and haven't gotten a response yet. I assume he has quite a bit on his plate! If anyone can send me a patched/modded BIOS for a 6459-xxx T61p, I'd appreciate it. I'd like to get around the whitelist issues mainly, but I do have one other question: has anyone unlocked the "performance" and "advanced" features present in the T61p BIOS- recent Sony and HP hacked BIOS' have exposed all kinds of new settings. Wondered if any of this has made its way to the Thinkpads.
Thanks in advance,
Noghri
Thanks in advance,
Noghri
Hi Zender and everybody,
Ive a several problem with my w500, Ive bought a qx9300 and it wont run [remainder of message deleted]
Admin Message: This thread topic is NOTabout CPUs.
Hi everyone,
I PM'd Zender and will wait for moded BIOS for Lenovo 3000 v200.
I'm very happy i found this forum and this topic.
Thank you Zender for you hard work about this issue.
I wish you the very best.
I can't believe how fast you are. Flashed my 3000 v200 with Zender's BIOS and everything is OK. I had to tap pin 20 just to be sure. Didn't test without tapping.
Thank you Zender, thank you all for this for giving me freedom to choose.
silvrcloud2003
PM sent to Zender yesterday requesting T60 2623-KEU modded BIOS...Let's hope it works!
UPDATE - Thanks to the kind person who sent me the needed information! Had to downgrade from 2.26 to 2.25 but all seems great so far....now to get my hands on an Intel 5300...
FINAL UPDATE ~ Just installed a HP-branded Intel 5300, running flawlessly! Zender, you are a GENIUS! Thanks so very much!
Last edited by silvrcloud2003 on Fri Apr 23, 2010 5:17 pm, edited 1 time in total.
Thinkpad T60 2623-KEU: Core 2 Duo T5600@1.83Ghz, 2GB RAM, Seagate 250GB HD@7200RPM, ATI X1300, Intel WiFi Link 5300, Zender's modded BIOS 2.25
- 812 Views
Sun Apr 23, 2017 11:47 am
- 759 Views
Last post by TPFanatic
Thu Apr 27, 2017 6:28 pm
x60 whitelist bios link
- 1899 Views
Mon Jan 30, 2017 7:09 am
- 921 Views
Sun Feb 12, 2017 7:41 am
