Jasperlinh
Hi all,
I have the ROM file for the T43 Bios upgrade to fix 1802 error but not sure how to use it.
I have never dealt with ROM file. Can anyone help me.
Hi all! Please, give me patched BIOS file for my X60s
friedrich-eugen
- thinkpads.com customer
silvrcloud2003 wrote: Any possibility of an update for the T60 to 2.26?
bump
I'll join the the queue ... (PM posted some days ago)... If anyone allready has the specific modified Bios file for the T60(p) of that T60-Version (2007-fbx), I'll be glad to use it and spare Zender the mailing...
Edit: Thanks to Harryc got a link to Version 2.25, nevertheless I should still hope for a PM/link on/to Version2.26 ...?
Thanks in advance
Last edited by friedrich-eugen on Thu Jun 03, 2010 4:22 am, edited 1 time in total.
__friedrich-eugen__
started with IBM-XT (80186) and AST-Ascentias NB (910N) in the 90ties, relying on Thinkpads (770X, A31Ps) until 2012,
now using an upgraded T60-61P "Frankenpad" (15"UXGA-LED Penryn 8GB 500GB/7200), and an X201/X230T (i7 8/16GB/500GB) Windows10
mindsweeper
OK, I have found a way around the BIOS-lockout of the Ericsson F3507G wwan card on my x201 without alteration to the BIOS.
My system:
3626-FBG
X201 i5 520M
4GB RAM
BIOS 6QET45WW (1.15)
WWAN Upgradeable with the Gobi card
Win 7
Now, I have two SL300's that came with the Ericsson card. My son ripped off a lot of the keys on one of them,
and I haven't replaced the keyboard yet so I robbed the wwan card to try it on the x201 even if I read all about the trouble to expect.
With a normal restart / boot on the system the wwan is not available in my Access Connections, also I have no option to enable / disable it in the BIOS. I can't see the card in the device manager, BUT - by using System Information I can see the card under Components -> Network -> Adapter.
To make it short - this is the procedure I use to enable my unauthorized wwan card
1. Shut down system completely
2. Switch off wireless (hardware switch).
3. Power on while holding F1
4. Enter Settings in the BIOS
5. Press F10 to save and exit (no changes made)
6. The startup will sometimes halt after this, then I just hold the power button to turn off and power up again
7. Let the pc boot till the first windows logo
8. Enable the wireless (hardware switch) BEFORE windows loads completely
Thats it. Works every time.
My system:
3626-FBG
X201 i5 520M
4GB RAM
Win 7
discoscience
Hi everyone,
I'm in need of a modified BIOS for a Z61t. I believe the Z61 bios listed on the first page should be fine too.
I've been unable to use my new intel 5300 wifi card for 2 weeks now because of this ridiculous 1802 error.
Also, i've PM'd Zender over a week ago but unfortunately still no response.
PM me if you can help with the BIOS. Much thanks in advance.
EDIT: Got it, thanks!
Hi all,
i was following Zender's instructions (great job btw) over my "old" T61 and it worked great. and now i want to try it over my T400 and i am stuck with the new Tools replacing the prepare.exe. the FI\FP.exe. i am not sure what to do after i have the Biosdode.rom.patched file. can anyone assist?
Thanx
Thanx
@Tafrik:
I would suggest you burn a CD from the ISO file instead, and use the CD for the update.
Don't update from within Windows!
Hi Realblackstuff
i am affraid you didn't understand the problem i am facing - i don't have issue burning the bios - i have issues replacing the patched white list module. maybe i didn't explain myself good enough. with Zenders process - after patching the White list rom module you have to replace it with the original module ( with old versions like T61 we used a tool called prepare.exe which created a MOD files from the ROM files (zipped) the new tools don't create a mod file thus i can't replace it in the whole bios file.
i know i am missing something - but i am stuck!
can anyone help?
Tafrik
can anyone help?
Tafrik
Like I said, burn the ISO from Zender, then do the update using that CD.
It includes the modified/bypassed whitelist.
No need to mess around with modded files.
I use his files on a T43, an R52 and a T60. Just burned the CD from his ISO's, and installed from CD. Child's play really
Hi everyone,
I'm in need of a modified BIOS for a X61. I've been unable to use my new Sierra MC8775 3G card because of the 1804 error.
I have a new lenovo x200s
Model type: 7466-5YG, BIOS: 6DET63WW (3.13)
WWAN card type: Sierra MC8781
I now have to modify the BIOS to add this PCI card to the "whitelist".
How I can do it?
How I can do it?
thnax Realblackstuff, but still i whould preffer to do this myself over the latest bios version from Lenovo. does anyone know how do i use fi\fp.exe tools to catenate the new patched module (replace) to the whole bios?
Thanx
Tafrik
Thanx
Tafrik
Am I to understand that you are trying to modify the T400 BIOS with the T61 whitelist?
FYI, there is a separate T400 Zender-BIOS!
No - i have already modified the T61 and catenated it and it works great (the T61 procedure is using a Prepare.exe tool), i am trying to modify the T400 but this model uses the FI\Fp.exe tool which works different. the Preapare.exe yields a mod files, while the Fi\FP outcome is different and i am not sure of what to do. i have already sent Zender a PM but up till now i didn't get any replay.
Tafrik
Tafrik
Afraid you got me lost there completely. Hope that Zender can help.
OTOH, why try to invent the wheel twice...
lenovoR60e
Hi I want to ask is there any way to get Intel 4965AGN working on Lenovo R60e 0657 KGG? I cannot find any modified bios on google
i wrote pm to zender about 2 months ago but no answer. thanks
sorry for bad en.
sorry for bad en.
Lenovo R60e 0657 KGG 3GB DDR2,320GB 7200RPM BlueScorpio 32MB cache /Ubuntu 10.04 / Snow Leopard 10.6.3
Jasperlinh
Hi RealBlackStuff,
Previously you said you got your T43 working. Any chance you can send me a copy of that file.
I tried PM Zender but he hasn't replied. Been waiting for over a week. Can you help me. Thx
Hi guys,
I'm one of the unlucky ones trying to update my T61 6459-CTO (http://www-307.ibm.com/pc/support/site. ... MIGR-67853 ) with a SparkLan WPEA-110N wireless-N card.
I recently updated to BIOS 1.08 from that site above and was hoping that someone of you could hook a brother up with a patched BIOS that removes the wireless card restrictions.
For any help, I'd be very very grateful.
Best,
Peter
Best,
Peter
Anyone? Would be very very much appreciated ;*(
Philipp
Philipp
Still no reply from Zender. Pls help. Thksjohntcy wrote:Hi everyone,
opticalmouse
Hi folk and specially Zender
Can pm to me moded bios for R32. I get the same code when I tried to plug wireless card from an x41 to my R32.
Thanks in advance
Have a nice day!
Thanks in advance
Have a nice day!
IBMX60s L2400 1.6Ghz, 3 RAM, 250 Gb, Win7
DELL PRECISION T7400 Intel Xeon x5472, 8 RAM, nVIDIA Quad FX5600, 2x146, Win x64
TOSHIBA A100 Intel C2D T7400, 3 RAM, 250 Gb, Win7
IBMX41 MLV 758 1.5GHz, 512 RAM, 40Gb, WinXP
IBMR32 1.8-GHz Pentium4, 1 RAM, 60Gb, WinXP
hp nc4010 1.6GHz Pentium M, 1 RAM, 40Gb, WinXP
Zender seems to have disappeared and I need a modded version of the latest W500 BIOS since it fixes the graphics issues I'm having ("Fixed an issue LCD showing moving slant lines looking from some direction."). The 5300 card that came with my laptop died about a year ago so I need the modded BIOS to use my older 4965AGN. If anyone has managed to replicate Zender's BIOS mod method on the 3.13 BIOS I'd be very grateful.
I "need" a modified BIOS for a Lenovo z61m, BIOS 2.27.. is Zender still active?
Does someone has this BIOS? I need it for an Intel 5100AGN, instead of the standard 3945ABG card. The 1802 patch doesn't work, so you guys are my only hope )
Link sent via PM
Thanks A LOT!!!!!! Works perfectly!!!Harryc wrote:Link sent via PM
I have a T60 8741-HAM and have successfully installed a WWAN Card Huawei EM770W. Even though the notebook boots into windows and I have successfully installed the drivers I am unable to get the card to power on, I have tried a few software methods to no avail. I am suspecting this may be caused by the BIOS. Can you Help?
Thank You in Advance,
Daniel
Daniel
I too was hoping I could get a patched bios for 1802/1804 error. Though Zender seems to have disappeared, if anyone out there could send me a link (by PM) for modified t60 bios it would be greatly appreciated.
{thanks, got it}
{thanks, got it}
Hello -
I have sent several PMs to Zender with not response and looking for a patched BIOS for my lenovo x200 (7454-2GU) notebook - cannot use either sierra wireless MC8775 or MC8790 due to BIOS lock - can anyone help me, direct me to where I can find a BIOS that will allow me to install and use these modems?
thanks, sub.
thanks, sub.
friedrich-eugen
Hello everyone,friedrich-eugen wrote: Any possibility of an update for the T60 to 2.26?
bump
Thanks in advance
it should not be a surprise to anyone, that Zender - having spent lots of time on modifying diverse lists in Bioses and having had obviously lots of PM - just needs a rest or even more probable will not be able to spend all his free time locked up with a/some notebook(s)... It is a formidable achievement that with his help useful and efficient life of Thinkpads may be extended further!
All the same, we probably all would like to know, whether Zender just takes some time out or whether he just had enough of it... .
Bios Version 2.25 (T60P), which is almost the latest will do for the time being. But to stay update would be nice...
May be there are other able and interested community-members that may pick up...?
__friedrich-eugen__
friedrich-eugen wrote: Hello everyone,
Did anybody even bother to see what the difference between 2.25 and 2.26 bios is?
Version 2.26
[Important updates]
Nothing.
[New functions or enhancements]
Nothing.
[Problem fixes]
- Fixed an issue where extermal USB keybard may not work fine after BIOS update.
- Fixed an issue where POST error 2110 may occur.
- 816 Views
Sun Apr 23, 2017 11:47 am
- 761 Views
Last post by TPFanatic
Thu Apr 27, 2017 6:28 pm
x60 whitelist bios link
- 1902 Views
Mon Jan 30, 2017 7:09 am
- 925 Views
Sun Feb 12, 2017 7:41 am
Users browsing this forum: ElusiveRoberto and 29 guests
