T40P is not on the list
Hi, need a Bios for my Lenovo ThinkPad T60 (200763G) so that i can use a Sierra Wireless MC8775 WWAN Card
Many Thanks for help
Pleased to report that the install of modded BIOS 2.23 on my R60 (9461-HRG) running Windows 7 64-bit with a newly installed Intel 5300AGN works flawless.
Thx
Thx
Synthetickiller
I have both an X200 & SL500. The X200 has an 802.11n card while the SL500 has only a b/g card. I purchased this card from mono-price:
img]http://images2.monoprice.com/productmed ... /64171.jpg[/img]
http://www.monoprice.com/products/produ ... 1&format=2
Name of wifi card: WS-WNP672N Wireless-N Adapter
Specs:
img]http://i50.tinypic.com/sdoa6r.jpg[/img]
I'd prefer to keep the x200 stock and simply not touch it. I'd rather try my luck with the SL500 since if that bricks, I can more so afford to replace that laptop.
Any helps is MOST appreciated!
Specs:
Thinkpad: x200 p8600 2.4ghz (probably won't OC) / 2x2gig ddr3 1066 / HDD = ? / WIN 7 (adding OSX & Ubuntu later)
Desktop: MSI K9A2 Plat / PII 945 @ 3.75ghz / G. Skill 2x2gig ddr2 1000 / 120gb ocz agility / gtx260 core 216 / IBM trackpoint keyboard
SL machines are not on the list of available BIOS's. PM sent...and we don't allow inline pics on the forum without a warning in the subject line. Breaking .img tags.
Synthetickiller
Thanks.Harryc wrote:SL machines are not on the list of available BIOS's. PM sent...and we don't allow inline pics on the forum without a warning in the subject line. Breaking .img tags.
Sorry for the inline pics, just doing stuff in a hurry.
I moved my intel 5300 from my x200 to my sl500 and I still get the error. I thought you could transfer from lenovo to lenovo. I was wrong.
hi,
i need a bios for my r61 (8918-deg) so i can use my atheros n card
thx
luke
thx
luke
checkcheck
could someone please send me the link? I have a WAN card that I want to make work in my T400s.Thanks a lot!
@luke666s & checkcheck, PM sent.
Hi all,
Is there anyone who could let me know where I can get a patched Whitelist BIOS for X200s?
thanks
thanks
X200s BIOS is not on the list, so you'd have to ask Zender unless it is compatible with X200 or X200t.
PM sent
PM sent
Hello all,
I have successfully updated my T400 with Zender's modified BIOS. I would like to thank Zender and everyone who collaborated with him for such a great job.
That being said, I need some help with another thing: I use Lenovo's Access Connections, but I am unfamiliar with hex editors. I don't know how to look for the "ID of a supported card and replace it with the ID of my own card". I'm using an unlocked Sierra MC8775 WWAN card. If anyone knows the code for this card and/or knows the hardware ID of a supported card to replace it with, and could indicate me the steps to follow, that'd be really appreciated.
Thanks in advance,
Eliyahu.
Thanks in advance,
Eliyahu.
Help for Thinkpad T60p :
Hello @ all
Hello Zender.
I read your review of the modified bios. great work.
My question : . I have Thinkpad T60p 2007-FE2 and wants to buy a Wificard from Company Ubiquiti Model SR71-E. In order to use it I need another Modifie Bios.
Can anyone PM me the bios for T60p, please?
can anyone help me?
thank you
Phil
Hello @ all
Hello Zender.
can anyone help me?
thank you
Phil
Hi Guys,
I have a X61T (7764). I would like to be able to use a Sprint 3g card (sierra 5725 card).
Do I need to flash the BIOS also to use it?
It currently has a verizon 5725 card. I need to unlock the WWAN card so I can convert it to sprint I guess. Is that possible? How do I do it?
If anyone could give me the BIOS I need to flash the system with, I would greatly appreciate it.
@HarrycHarryc wrote:PM sent
Thanx and best regards
Phil
@iamneo, PM sent. @zapplphil, you're welcome.
Is anyone willing to take up Zender's work? My stock wireless card is broken and I'm currently running a modded BIOS but it's based on an older version. The newest version fixes a graphical corruption issue I'm experiencing.
I followed his instructions to modify it myself but I'm getting stuck on phnxmod.exe.
If I can't get this update I'll have to spend $45 on a new Intel 5300 and go back to stock BIOS.
Thanks.
phnxmod.exe BIOSC6.rom old.mod new.mod
PhnxMod 0.1 2008-02-19
(c) Ender
Okay, all files open.
ROM size 8000h, old module 8882h+1Bh, new module 8882h+1Bh.
Loading data...Old module (without header) not found in the ROM file. Quitting.Thanks.
Kamika007z
Yes, it would be awesome if someone could pick up from where, it would seem, Zender has left off.
Zender if you are still around PLEASE RESPOND!! WE MISS YOU!!!!
I too have issues on my T60p that can be addressed only by upgrading to the newest BIOS, 2.26. The older, 2.25 has keyboard and HDD0 detection errors which I have both experienced.
T61p [8891-CTO]: Intel X9000 (2.8GHz) CPU, 8GB RAM, 128GB OCZ Vertex 2 SSD, 14.1in 1400x1050 (4:3) Modified Symmetrical LCD cover & bezel, nVidia FX 570M, DVDRW, Intel 6300 WiFi, BT, FR, Windows 7, SLIC2.1, Unlocked SATA II middleton BIOS, WLAN Whitelist Modified. Mint Condition.
qazwsxbots
Hi
May I have the modded bios for T61p to be used with Intel 5300? Thanks
pangalactic
Can I, too, please get a bios for a T400s ? Thanks in advance!
pangalactic
I have sent a handful of PMs over the past few months requesting a BIOS update for a T60 but I've received no response. What is the proper method to request a BIOS?
W530 Windows 7, T60 Windows XP, 390X Windows XP
@ Paulag, are you looking for a normal BIOS update for a T60 or are you trying to install a non-IBM/Lenovo card and are getting an 1802 error?
Can you please send me the bios for X301 which would let me install intel 5150 with winmax.
I bought the card from china via ebay, getting error 1805 unauthorized wireless usb card at bootup
Thanks in advance for your help.
Jay
Jay
c0dej0ckey
I'm looking for a BIOS to allow me to run my X200 with a Dell 5720 WWAN card.
- 812 Views
Sun Apr 23, 2017 11:47 am
- 759 Views
Last post by TPFanatic
Thu Apr 27, 2017 6:28 pm
x60 whitelist bios link
- 1899 Views
Mon Jan 30, 2017 7:09 am
- 921 Views
Sun Feb 12, 2017 7:41 am
Users browsing this forum: ac12 and 3 guests
