If you are installing the Broadcom card in the left hand side PCIe slot (WWAN slot - nearest to the single USB socket/below the Fan Heatsink) - then unfortunately the card will not function. This slot supports USB devices with the PCIe interface.darkmagicmge wrote:I have tried installing a broadcom wifi card in second slot with pin 20 taped, doesn't even show up
The top slot (near the LCD connector) supports PCIe signals which are usually WiFi cards like your Broadcom - I currently am using an HP Broadcom BCM94322MC and can confirm it is working a-ok with modified BIOS - (Pin20 not taped).
