Hi all,
i am very sorry, but some pm's are hanging.
They are still in the outbox..
I have no idea why...!?!
Still trying.
wengi
Still trying.
wengi
(Sent) PMs will remain in your Outbox, until the recipient reads them, then they'll move to "Sent messages".
If the noobs don't check their PM (new messages at the top of each page), they won't get them!
networkdawg
Could someone send me the latest url?
I need one for an R32, and the URL I got a couple years ago doesn't work anymor
Thanks.
Thanks.
Hi, anybody can send me the modified BIOS for X300? I PM zender days ago but seem he is busy to reply. Thanks!
@networkdawg
@axii
PM sent
@axii
PM sent
T60p 2007-CT0 15" UXGA, ATI V5250, INTEL T7600, 3GB RAM, NMB Keyboard, HP Broadcom 4322AGN 802.11n Wireless Card, Sierra Wireless MC8775 WWAN, 250GB Momentus XT Hybrid drive
Could someone send me a link of modded bios for R52 (model 1860) ?
Thanks in advance.
Thanks in advance.
Thanks Zender, Thanks Worzy, it works perfectly!l
Worzyl wrote:@networkdawg
@axii
PM sent
bibinskariah
I'm having an X200 Tablet, I'm trying to use an Ericsson F3507g 3G/HSDPA WWAN card and it is giving Error 1804: Unauthorized WAN Card.
Following are the details of the machine.
Bios Version - 3.11
Bios Date - 16-11-2009
Controller version - 1.04
OS is Windows 7.
Can you please send me the modded bios for X200 Tablet please.. Should I remove the card and do the update?
Bios Version - 3.11
OS is Windows 7.
@bibinskariah, ljb473
PM sent
PM sent
Falkenborn
Hello everybody,
I tried to run my Lenovo Thinkpad T60 (1955 A13) with a Intel WIFI Link 5100 (Model 512AN_MMW) from a Lenovo T400 but I got a 1802 error.
So I'm in need of a patched BIOS for my T60.
Please, can somebody send me a link to Zenders patched BIOS?
Thanks in advance!
Falkenborn
Thanks in advance!
Falkenborn
silvrcloud2003
@Falkenborn - PM sent.
Thinkpad T60 2623-KEU: Core 2 Duo T5600@1.83Ghz, 2GB RAM, Seagate 250GB HD@7200RPM, ATI X1300, Intel WiFi Link 5300, Zender's modded BIOS 2.25
I'm in the process of upgrading my 3 ThinkPad's WiFi cards, so i need modified BIOS's for my T43, T60 and X61 Tablet (also getting a new WWAN).
Many thanks in advance.
JameSoft
JameSoft
ThinkPad T60 2007-FUG: Core 2 Duo T5600@1.83Ghz, 3GB RAM, Toshiba 120GB@5400rpm, 14.1" 1400x1050, ATI X1400
ThinkPad X61 Tablet 7767-B8G: Core 2 Duo L7500@1.6GHz, 1GB RAM, 120GB@5400rpm, 12.1" 1024x768 Touchscreen, Intel X3100
I am replying to myself here just to add one more data bit to the common knowledge. I got another card with the same chipset and it works nice so the first atheros card that I got was faulty. Things work great now. Thanks to the modders!hki wrote:I just tried the modified bios on my T60 to install an ATHEROS AR9280 based card, but with no luck. I chose this card because it does wifi N with two antennas and my T60 does not have the third one.
With the card installed and the modified bios there was no error whatsoever, but the card does not show up in the device manager. It is as if it was not installed. I tried taping the pin 20 as well, but that did not have any effect. I also removed the hotkey driver just in case as it may interfere with switching the card on and off. My T60 does not have the second PCIe slot so I cannot try the card there. My existing Intel based card works fine still if I put it back.
So if there are any other ideas to try I'd be grateful for your suggestions.
It could be that the card is dead too and I should just get another one. So if anyone has got AR9280 based card to work let me know how you did it.
hki
PS. maybe I should get Broadcom 4322AGN card as it seems to work for some as I can see from the signature of the previous post.
T40
T60
X301
x220
T60
X301
x220
silvrcloud2003
@JameSoft - PM Sent.
Falkenborn
thanks a lot for the fast response, silvrcloud2003silvrcloud2003 wrote:@Falkenborn - PM sent.
Works great!
Thanks to Zender for his great job!
Regards
Falkenborn
Hello all,
I'd appreciate getting the link for the X200 BIOS, as my Ericsson F3507g is not accepted...
@mi-k-l
PM sent
PM sent
hi all,
I sent PM to Zander last week but I still dont get answer :/ meaby somebody could help me get modified BOIS for x61 tablet??
ideal-pc
Hi all,
Please could I get a link to a modded BIOS for an R60e? I have two of them which just wont take my Intel Wi-fi's
Type no's are 0658 if that helps!
Many thanks
Anthony
Many thanks
Anthony
Some people are like Slinkies................... they are really good for nothing, but they still bring a smile to your face when you push them down the stairs!
can someone please send me a link to the x60 bios? tried to patch it myself but the 'instructions' are incomplete :/
thanks
david.
thanks
david.
@djonline, ideal-pc, stukov
PM sent
PM sent
I would too appreciate T60 2.26 bios. Hoping it to resolve connection issues.
I'm looking for ThinkPad Z61m TYPE 9450-3HG bios.
Can somebody help me?
@Capzzzz, KitBam
PM sent
PM sent
I need a patched bios for X100e 3508-2DG , I need WWAN and the only one possible is the gobi2000 which cost a lot !
Thanx in advance.
Thanx in advance.
R32 mod BIOS
Can anyone share me R32 mod bios to accept following wifi card
BROADCOM BCM4318E mini-PCI wireless adapter
Thank you
Thank you
Could you forward the link for a T400s
Many many thanks.
Many many thanks.
@Harryc
many thanks for your help.
I've got the Ubiquity SR71-E installed with success in my Thinkpad T60p.
With best regards
Phil
With best regards
Phil
I update my bios and 1804 error was gone
thx for help but I can't see wwan in access conection... I have X61t and Sierra MC8775 HS2300.
meaby is some diffrent way to connect??
edit:
everything works perfectly:)
edit:
Hi all,
Please could I get a link to a modded BIOS for a X60s ?
- 809 Views
Sun Apr 23, 2017 11:47 am
- 757 Views
Last post by TPFanatic
Thu Apr 27, 2017 6:28 pm
x60 whitelist bios link
- 1897 Views
Mon Jan 30, 2017 7:09 am
- 919 Views
Sun Feb 12, 2017 7:41 am
Users browsing this forum: ac12 and 8 guests
