T61 is not as good as the T42
Search the forum for "T60 noise" and almost all of the posts are complaints; search it for "T42 noise" and most posts say it is quiet.
According to IBM/Lenovo, the T42 is about 5oz lighter and 0.1in shorter and thinner than the equivalent T61.
T61 8897 14.1in SXGA+; 150nits, 4:3, 200:1; Intel X3100
12.3x10.0x1.1--1.3; 5.3lbs.
T42 2378-FVU 14.1in SXGA+; 150nits; ATI Radeon 9600
12.2x10.0x1.0--1.2; 5.0lbs
Work: T42p (XP, UXGA IPS); T60p (XP, UXGA IPS); T60/61 FPad (Win 7, UXGA IPS).
Play: X1 (first gen, Win 7); T450s (Win 7).
The weights I gave in my last post (T42=5.17lb, T60=5.22lb) were obtained with a very accurate scientific balance in my lab, and I used that same balance for both my T42 and T60. The difference was only 0.05 lbs. The weights provided by IBM/Lenovo are usually off by several percent. I know because I've owned over 30 Thinkpads and I weighed each and every one of them, carefully.exTPfan wrote:According to IBM/Lenovo, the T42 is about 5oz lighter and 0.1in shorter and thinner than the equivalent T61.
Incidentally, I had a 14.1" SXGA+ T43 that weighed 5.17 lbs, exactly the same as the T42.
Dead1nside
[censored], I love the thinklight, it lights up the whole keyboard as well as to the sides of it, really makes working in the dark possible.Paul Unger wrote: You could work with the T4x thinklight; you can only avoid mistakes with the T6x thinklight. That's my take on the difference.
The thinklight on my T42p always shined right in my eyes until I masked it a bit with some black electrical tape. The thinklight on my T61p is perfect for me without needing any mods. I find it produces enough light to see the keyboard in a completely dark room. Good enough for me.
T7TrainingSystems
In my Thinkpad experience...
600x - Tank.
T23 - Beautiful tank.
T41 - Beautiful.
T60 - Modern tank.
I'd marry a T60, but I'd have an affair with a sexy T41...
600x - Tank.
T41 - Beautiful.
T60 - Modern tank.
Main: T60 -- 500gig 4gig Win7/Vista dual
1 x T42, 2 x T41, 4 x T40, 2 x T30, 1 x T23, 1 x T22
Ex-main: T23 1.13Ghz, 20gig, XP SP1
Ex-ex-main: 600X - 10gig 256mb Win98 - very fast on Win98!!
http://www.T7.net.au
mattbiernat
Paul Unger
Ah, but affairs are so fleeting. Aim for stability--get "married".T7TrainingSystems wrote:I'd marry a T60, but I'd have an affair with a sexy T41...
I think ugly depends on whether you have one of the big boys or the old 14.1 non wide screen size. The smaller version is not ugly at all imo. It is a little beefier, but for good engineering reasons.
carbon_unit
- Moderator Emeritus
Yeah, they get really quiet after the GPU comes loose, because there is no reason to turn it on anymore.exTPfan wrote:Search the forum for "T60 noise" and almost all of the posts are complaints; search it for "T42 noise" and most posts say it is quiet.
So far the T6x series is not suffering from that. I'll take a little noise and a thicker look if it is more durable.
T60 2623-D7U, 3 GB Ram.
Dual boot XP and Linux Mint.
Registered linux user #160145
carbon_unit
Time will tell.
I never abused mine either but laptops are not designed to ride a desk their whole life, they are mobile devices. As they move around they get flexed, and then eventually....
If you buy a used one you have now way of knowing how it was treated and there are very few new, unused T4x's out there now. Nothing lasts forever.
Actually, there are quite a few used ones ....
That are in VERY good condition. Many corporate laptops lead a docked life, not being carried around very much at all. I have been buying used T42's off lease with docks that seem to fall into this category. They have almost universally been in very good condition, and have shown no signs of failure. As you say, though, time will tell. You could buy 3 or more of them for what you will pay for a new T61 though, so you could have built in redundancy!carbon_unit wrote:Time will tell.
TP T61 | 7664-1KU | T7500 | 160GB HD | 3GB DDR | NVIDIA QUADRO NVS 140M
Hi, kind of jumping in late, but my take on this...
I went from T42p UXGA 2.1GHz XP from 2004 to the current T61p WUXGA 2.4GHz Vista. I absolutely loved the T42p, and love the T61p even more.
I agree that T42p with WinXP was a solid machine but my need simply grew out. I do a lot of computational programming running VMWare all the time. T42p had tough time keeping up but thanks to the dual core, T61p is so much better in handling my tasks. Computation times have improved slightly but the biggest benefit is being able to do other things while I let my programs run.
Vista has been very stable for me, although I refreshed twice to get the right apps and config in place.
Perhaps the only things I miss with the T42p is the Flexview screen and the keyboard. When doing graphics work and for general pleasure of looking at the screen, Flexview was much better. I'm getting used to the WUXGA though. The real estate is so large that I don't have to look at the whole screen that often. The keyboard is just cheap on T61p but hey, I'm happy for the performance I'm getting for the price!
Just another view on this
T61p 6457-5KU: C2D T7700, 4GB RAM, WUXGA Vista and CentOS
DesertSilver
I would describe the T42p keyboard as having a more "dense plastic". I had the so called ALPS keyboard for T42p and my T61p came with Chicony and replaced it with ALPS. Perhaps they were thicker plastic or something... it felt more solid under my finger. The general stroke feel is still good on T61p. No so much of a complaint but I notice it every once in a while
I believe Thinkpad keyboards are made by three different companies and they feel different, and it's just luck of the draw which one you get. My T42's keyboard is terrible whereas the T60 I used to have had a much nicer keyboard.
lithium726
Because people like me believe even that resolution is too large. Hell, I wish I could get 1600x1200 in a 14.1" 4:3 panel. I would be in heaven.Frankly, I'm wondering why Lenovo even sells a screen like this.
Mine is TONS faster. I went from a T40 with a 1.7 Dothan and 2GB of ram to this thing and it screams in comparison... I am a power user though, and notice any amount of lag. I'm even using a slower chip and Vista, it's faster. noticeably so. It's not going to faster if you're just having an IE window with a few tabs open, though.5. It’s not faster. A lot of that is probably due to Vista, but I went from a 1.4ghz Pentium M with 768mb of DDR and and integrated gpu to a 2.2ghz Core 2 Duo, 2gb DD2, and a discrete video card with 128mb of ram, plus intel’s new turbo cache thing and it feels slower if anything.
My T40 actually did this more than my 60 does... in fact, I haven't heard any sounds in a long time. I think it did it when it was new, but I can't remember.6. There’s a strange high pitched noise that sometimes happens in sync with movements of the mouse. The computer will be quiet and then I’ll move the mouse and it will sound like the hard drive is whirring really fast. I don’t know if this is unique to my machine and for whatever reason it seems to be happening less frequently.
and if you thought the T42's keyboard was nice, you should use an NMB T23 keyboard >_>... best keyboard i've ever used.
Thinkpad T60 2613-CTO (2\4m\667, 3GB, 200GB 7200, DVD-RW DL, SXGA+, 3945ABG, 128MB x1400, GBe, BT IV)
Thinkpad T40 2373-PU7 (1.7\2m\400, 2GB, 120GB 5400, DVD\CDRW, SXGA+, Intel 2915ABG, 32MB MR7500, GBe, BT II)
Thinkpad T23 2648-PS1 (1.2, 512mb, 2915ABG)
Yeah, the old NMB's were really nice.
The one I have now is OK, but a shadow of the former greatness.
You can certainly put one on your T40. See my signature and this thread.lithium726 wrote:Hell, I wish I could get 1600x1200 in a 14.1" 4:3 panel. I would be in heaven.
lithium726
That's awesome, I didn't even know those panels existed. Any idea if it'll work on my T60 though? Not a fan of spending a lot of money on something I'm not going to use daily.pianowizard wrote:You can certainly put one on your T40. See my signature and this thread.lithium726 wrote:Hell, I wish I could get 1600x1200 in a 14.1" 4:3 panel. I would be in heaven.
Camera LED does not work? Make sure it's not taped over. :)
by dr_st » Sat Feb 18, 2017 12:00 pm » in ThinkPad X200/201/220 and X300/301 Series - 0 Replies
- 805 Views
Why does the T60 have a centered LCD but the T61 and T500 not?
by Thinkpad4by3 » Fri Jun 30, 2017 9:59 pm » in ThinkPad T6x Series - 5 Replies
- 126 Views
Last post by ajkula66
Sat Jul 01, 2017 11:31 am
- 0 Replies
- 967 Views
Last post by AVN6293
Wed Feb 22, 2017 5:31 pm
WTB 770 in good condition - UK/Europe only
by akebia » Tue Jan 03, 2017 6:39 pm » in Marketplace - Forum Members only - 5 Replies
- 432 Views
Wed Jan 04, 2017 2:18 pm
