At least 1920x1200.lightlamp wrote:can this drive an external moniter? Up to what resolution?
Thinkpad X300 on paper
Regarding driving an external monitor, I was quite disappointed when I saw the X300s docking solution. Not only is there no DVI, it says max resolustion is 1280x1024. It would be a pain if you could only run 1900x1200 if plugged in directly to the X300 itself. You would then have to plug and unplug the unit each time you moved your unit.
I don't think anyone uses a 15" external monitor anymore so I think the video out on the USB dock is quite useless. Hopefully the spec sheet is wrong and it can output to something higher.
Too bad too that there is no native Ethernet on the dock either. Not sure how efficient a USB to Ethernet adapter would be if you wanted to run full Gigabit ethernet.
There may well be a touchpad-less palmrest created, just like the part that is available for T4x machines.mattbiernat wrote:it would be just nice if they had an option without touchpad.
Not at all - I have to say that my general pointer usage during a given day is about 65% external mouse, 35% touchpad, and I never find the trackpoint an inconvenience when I'm typing.bobdsmith wrote:BTW, im surprised there are guys out there that use both, sorry i misrepresented the population ^_^. As for the TrackPad people out there, does the Point get in your way? Even if its disabled? For me (I use the Point) the Pad just gets in the way and is annoying even if its disabled. Just wonderin...
X220 4291-46M
HP Pavilion dv7-2109tx
ryengineer
- Moderator Emeritus
1.2 GHz is not the maximum limit, thinkpad X300 is going to use SFF chip, rumour has it that it's the same chipset that apple used in Macbook Air and as Intel makes these chips more widely available; later refreshes of thinkpad X300 can be configured with faster processors.lightlamp wrote:can 1.2 ghz do good video conference, tv streaming, and occasional video editting?
K. Eng
Impressive.
The only improvement I can think of would be a discrete GPU, but that will probably have to wait until GPU makers create more energy-efficient graphics parts.
I have read that the price ($2600-2700) is as impressive as the specifications.
bobdsmith
Well actually, I didn't see an SD card slot in the specs...I've been moving away from flash USB to these things, and the slots on my X40 and X61s really helped. Don't want to have to buy a USB attachment....
And also, Whats with the slope into the keyboard on the bezel? Not only is that ugly, imo, but it seems to push stuff into the keyboard. Not fun if you spill liquid there...
Jane
I'm on Twitter
I'm on Twitter
mattbiernat
andyP
- **SENIOR** Member
This speculation is getting out of control, there will be afaik;
X200, X300 12" and 13,3" all wide
T400, T500 14" and 15,4" all wide
W500, W700 15,4 and 17" all wide
R400, R500 14" and 15,4" all wide
look here
small print:
I reserve the right to edit this post tomorrow re. R series.
Edit: added R (as threatened)
look here
small print:
T61p 6460-67G; 15,4 WSXGA+ W7P x64, no hairdryer.
T43p 2668-G2G, 14,1 SXGA+, XP Pro, internal hairdryer
T23 2647-9LG, 14,1 SXGA+, XP Pro, no hairdryer
Dead1nside
So the X T and W series. What distinguishes them?
mattbiernat
mattbiernat
Is the name that big a deal? If you ask me, using screen size to determine a computer's name (X300, 13", T400, 14", etc) makes more sense than an arbitrarily increasing number (X61, T42, etc), but it's the computer under the name that matters. Let's be thankful that Lenovo hasn't adopted the same gibberish as other companies--I don't want to have to remember what D45-G339XTi Ultra means.
X61 Tablet - 1.6GHz C2D, SXGA+, 1GB RAM, 100GB HD, Vista Business.
i have other laptops but i'll be honest i never use 'em
mattbiernat
but the X200 suppose to be 11.1" - that doesn't make sense either... it should be called X1110. by the way, name goes with reputation. try asking coke to change its name.j-dawg wrote:Is the name that big a deal? If you ask me, using screen size to determine a computer's name (X300, 13", T400, 14", etc) makes more sense
Dead1nside
I think they're trying to make it like car model names. Focus, Fiesta, Mondeo. They denote size and with size comes general performance. So W are very large powerhouses, T are your balance between size and weight and power, and X is as much power as they can fit into a certain screen size. Screen size denotes chassis size.
bobdsmith
Lets assume, then that the screen size is reflected in the numbering. What happens when they make the next wave of product? X310?
In my opinion, the best method (assuming we choose to ignore overlay due to nostalgia) would be:
[family (as in the 6 in X61s)] [model (the X)][revision (the 1)][screen size, subtract 10 inches, round (a 2 because of 12.1)][any special signifiers, such as T for tablet (the s)]:
so an X61s would be:
6X12s
an X40 would be:
4X02
I'm fairly new (first computer=X40 when it came out) and haven't checked historically, but ive noticed that products come in waves (X60 and T60, X40, T40) and therefore that would get a higher significance factor and get moved left.
But thats just me.
6X12s
an X40 would be:
4X02
But thats just me.
Dead1nside
I prefer the older numbering scheme.
In reference to my prior post, I meant as in you have the same name for the car but they're distinguished by year. That'll be shown in the serial number or model type.
ryengineer
X is a continuation of X-series and 300 could mean anything, remember former IBM PCD is owned by a Chinese company now and from the things I've learnt about their culture from reading and naming schemes of other lenovo products in China is that they mostly name their products after some emperors in history, an important date or century in their calendar, birth year/date of a king or queen and so on.
Some may also argue that lenovo stole it from Dell's ultraportable Latitude X300 series.
Well, maybe there are some discrepancies, or maybe I'm just wrong, but it seems to be based on screen size to me, by inches over ten. So an 11" X-series would be an X100, ignoring the digits after the decimal point. I dunno why they called it X200. Probably I'm just wrong.mattbiernat wrote:but the X200 suppose to be 11.1" - that doesn't make sense either... it should be called X1110. by the way, name goes with reputation. try asking coke to change its name.j-dawg wrote:Is the name that big a deal? If you ask me, using screen size to determine a computer's name (X300, 13", T400, 14", etc) makes more sense
BMW and Mercedes used to name their vehicles by series name and motor size, as well as some additional information; e.g., a 325i was a 3-series with a 2.5-liter motor, a 540i was a 5-series with a 4.0-liter motor, and a 323xi was a 3-series with a 2.5-liter motor and all-wheel-drive. A Mercedes 560SL was an SL-class with a 5.6-liter motor, etc. Some of these really packed the information in--a 500SEL, for example, was a 5.0-liter (500) S-class (S) with fuel injection (E, for Einspritzung) and a long wheelbase (L).
These days, BMW and Mercedes still more or less adhere to the naming system, but there's a little more wiggle room. For example, when BMW added twin turbos to its 3.0-liter six-cylinder engine, it saw fit to name the car 335i, though the displacement was still 3.0 liters. The present 330i has a 2.8-liter motor, and the 525i has a 3.0-liter engine. Mercedes also fudges the numbers sometimes; the new AMG "63" cars (SL63, CLK63, S63, etc) actually have 6.2-liter motors, but are names 63 in honor of the classic 300SEL 6.3, itself a self-acknowledged "violation" of the numbering system.
So anyway, now that I've explained something nobody cared about, I think Lenovo is sort of trying to do the same thing, though, as Matt has pointed out, this appears not to be true for the X200. Well, I think it makes sense, though as people have pointed out, it'll make it hard to increment model numbers for upgraded editions.
It's to unify the naming systems of the Thinkpad and the non-Thinkpad lines.bobdsmith wrote:Still...whats up with changing the naming system?
I like this new system much more than the old one. You just look at the name and know what the screen size is.
Jane
I'm on Twitter
I'm on Twitter
Very nice article, and nice photos. Great to see the battery returning to the front.
I guess the lack of clutter on the bottom was the motivation behind the USB dock. It occured to me this idea will be more feasible when USB 3.0 lands. Perhaps like with the SSD, the X300 is pushing the envelope for the future.
I really want to see launch pictures and then reviews about battery life and performance of the SSD.
X220/IPS, T60p/IPS
Nothing endures but change
GONE: ThinkPad X300 (TYPE 6478-1VU) +shipping
by cds.helpdesk » Tue Jan 17, 2017 11:31 pm » in Marketplace - Forum Members only - 3 Replies
- 705 Views
Last post by cds.helpdesk
Mon Jan 30, 2017 2:41 pm
ThinkPad T43 ATI X300 video-driver for Win98
by jinfeixibi888 » Tue May 02, 2017 9:35 am » in ThinkPad T4x Series - 5 Replies
- 622 Views
Last post by malch
Fri Jun 16, 2017 3:29 pm
X300: Problem w/ SSD, also can I use HDD?
by awebber » Fri Mar 24, 2017 12:48 pm » in ThinkPad X200/201/220 and X300/301 Series - 18 Replies
- 1513 Views
Last post by awebber
Tue Apr 04, 2017 2:05 pm
Cannot get TapAndDragGesture to work on X300 trackpad
by pelago » Thu May 25, 2017 10:59 am » in Linux Questions - 0 Replies
- 61 Views
Last post by pelago
