Mtron Pro 32GB SSD in X61S
Yes. Windows XP needs the Microsoft Hotfix below:
http://support.microsoft.com/kb/934428
I just cloned my drive to an SSD I got for review but the system will not boot. Possibility that the clone was bad but did you have to change any BIOS settings to get it to run? My R61e has AHCI and compliant modes for HDD's in BIOS. Also, are you running FAT 32 or NTFS? I formatted the drive to NTFS prior to the clone.
Desktop: Modded Lian Li PC 7077A/Dual Watercooling Loops/Asus P5K Deluxe/Core 2 Q6600 G0 (3400MHz@1.40v)/1 x XFX 8800GTX XXX/8GB Corsair DDR2-1066/PC-P&C 750 Silencer, Win 7 64b, Laptop: Modded Thinkpad R61e/T7300(ES)/2GB PC5300 VS-Corsair RAM/100GB 7.2k RPM HDD, Intel 4965 wireless mPCIe
formatting the drive first makes no diference as the clone process will format it again.
Eitherway - just slip in your Windows CD and do a repair (Vista will just do a quick 5 min boot repair) and you can boot again.
This is XP Pro. It stalled on the first clone so I tried formatting and the clone took. I can't do a repair as the R61 doesn't come with a windows disk. I have a key and may try slipstreaming of the 386 file on the Laptop with the key imbedded. I'll play around in BIOS a bit and have some tips from the company to try before i resort to the more labor intensive things. Thanks!
jketzetera
Re: Mtron Pro 32GB SSD in X61S
Could you elaborate a bit more on the energy consumption? I went from a 5400 rpm drive to a Mtron (6000 series) 32 GB SSD. The drive is very fast but it also does consume more power than I anticipated. With my 5400 rpm drive both idle and peak power consumption in battery optimized mode was several watts lower than with the Mtron.levimax wrote:I just replaced the 100 GB 7200 RPM drive in my X61S with a new Mtron Pro 32 GB SSD (120 GB/S Read, 100 GB/S write) and here are my impressions.
Battery life is better but not improved as much as the responsiveness. It appears about 10% better.
What type of power consumption do you get with your Mtron Pro?
WTB: W540 w/ 32GB RAM or a decenty priced P50 w 64GB
by Farro » Wed Jan 25, 2017 10:58 am » in Marketplace - Forum Members only - 0 Replies
- 275 Views
Last post by Farro
SOLD: ThinkPad T420s, 240GB SSD, UltraBay battery, Win 10 Pro, etc.
by Edward Mendelson » Sat Mar 11, 2017 8:54 am » in Marketplace - Forum Members only - 1 Replies
- 327 Views
Last post by mpcook
Sat Mar 11, 2017 10:05 am
[Solved] Yoga 2 Pro Model 20266 with Windows 10. Botched SSD upgrade (screen no longer works)
by prophetic » Wed Mar 29, 2017 12:39 am » in IdeaPad Series Laptops - 2 Replies
- 1266 Views
Last post by prophetic
Wed Mar 29, 2017 9:26 am
SOLD!: Plextor M6 Pro 2.5" 256GB SATA III MLC SSD, barely used
by ajkula66 » Sun Apr 30, 2017 8:35 am » in Marketplace - Forum Members only - 1 Replies
- 262 Views
Last post by ajkula66
Mon May 15, 2017 9:08 pm
