I haven't seen an option to turn that off, but it's just the sides of the button that are transparent enough to let the light show. It's a very dim blue glow that shows.k3davis wrote:if the blue LED in the thinkvantage button can be turned off
Thinkpad X300 taken apart for your viewing pleasure-pictures
Jane
I'm on Twitter
I'm on Twitter
OK, that was last night with everything running wide open. This morning, I've been using it with the Maximize Battery settings. I did turn the screen brightness up a little over halfway and kept wireless turned on.nonny wrote:With my normal workload, Rosetta@home running in the background and the screen very bright, the battery lasted 96 minutes. I'll try timing it in a more conservative mode tomorrow to see how many minutes I can eek out of it.
I've been listening to podcasts, intermittently reading RSS feeds, answering e-mails, letting it just sit while I worked - just my normal daily usage. Periodically, the screen would dim itself if it sat too long with no activity, but it didn't stay that way for long before I moved the pointer for something. I did turn rosetta@home off.
It hibernated itself at 3 hours 26 minutes with around 6-7% showing on the Power Manager Gauge.
Jane
I'm on Twitter
I'm on Twitter
experttease
that's ok, I'd probably get the extended battery anyway. does it run vista? thanks.nonny wrote:It hibernated itself at 3 hours 26 minutes with around 6-7% showing on the Power Manager Gauge.
edit: oh yeah, I forgot to ask, where are the system lights? I can see three on the outside of the screen, but not on the inside, and they're quite important.
They are on the keyboard:experttease wrote:edit: oh yeah, I forgot to ask, where are the system lights? I can see three on the outside of the screen, but not on the inside, and they're quite important.
http://www.notebookreview.com/assets/31209.jpg
Rules of the road
Rules of the road
experttease
I probably could have gotten more time out of the battery had I worked at it. I just did the obvious things to extend my time.experttease wrote:that's ok, I'd probably get the extended battery anyway. does it run vista? thanks.nonny wrote:It hibernated itself at 3 hours 26 minutes with around 6-7% showing on the Power Manager Gauge.
Yes, it's preloaded with Vista.
Jane
I'm on Twitter
I'm on Twitter
That really sounds like it is a fantastic notebook.nonny wrote:...They really did a good job with the keyboard on this one; the screen is bright and clear; there's almost no heat coming out the vents (and I'm running one of the @home projects on it 24x7).
It's so light that I have to be careful when I switch back and forth with the X61 Tablet. I told Mark I almost tossed it across the room when I first got it as I lifted it out of my lap to stand up - I was used to picking up the weight of the tablet, and it almost got away from me!...
As for the screen resolution, have you noticed anything using VISTA that seems too tiny, or is everything perfectly readable?
Also, Mossberg said that the larger battery did not stick out at all, just added more weight. Is this correct?
Andrew
I adjusted the DPI and the text size in IE7, and so far, I haven't run into any problems in being able to see any text.
This one apparently has the smaller battery, so I can't answer that question.
Jane
I'm on Twitter
I'm on Twitter
The big battery is not longer, like in the older models, but thicker. The battery compartment is underneath the palm rest. I think that with the large battery, the keyboard is paralell to the desk, while with the smaller one it slopes down like the X40/X60.aamsel wrote: Also, Mossberg said that the larger battery did not stick out at all, just added more weight. Is this correct?
How is the display (panel) connected to the main body?
R60 - 1.83Ghz Core Duo, 15" SXGA+, ATI Mobility Radeon X1400 (128mb), 2GB RAM, 80GB
Macbook - 2.1Ghz Core 2 Duo, 13.3" WXGA, Nvidea 9400M, 4GB RAM, 120GB (7200rpm)
Personal website (Dutch)
Do you think there would be any perceivable comfort difference in the typing angles created by either battery?pxa270 wrote:The big battery is not longer, like in the older models, but thicker. The battery compartment is underneath the palm rest. I think that with the large battery, the keyboard is paralell to the desk, while with the smaller one it slopes down like the X40/X60.aamsel wrote: Also, Mossberg said that the larger battery did not stick out at all, just added more weight. Is this correct?
Andrew
Mind you, I haven't actually seen a X300 in person. The sloping vs straight keyboard with extended battery was something I picked up on another forum. And it seems plausible enough, as I've seen a video with the extended battery that did extend downwards. Anyway, I don't think you'd notice any difference in ergonomics The X40/X60 series also had a slope, but it's so shallow that you don't really notice. Given its thinness, I think the X300 is similar.
This battery is under the palm rest, so I'm having a problem visualizing what the extended one would look like.
Jane
I'm on Twitter
I'm on Twitter
It extends downwards out of the case. You can see it on this vid
http://www.youtube.com/watch?v=eET4uS3Ybv4
right after around the 1 minute mark.
Too bad those 1.8" drives aren't compatible with the X40/X41 series of Thinkpads which were the first Thinkpads to incorporate a 1.8" PATA drive. Unfortunately those 1.8" mechanical drives have an even smaller form factor than the SATA 1.8" SSD drive and are really s-l-o-w (4200RPM). Not to mention that the largest drive made in that form factor was a measly 60Gb.
H Fawaz
DHL Enterprises, Inc.
"Solutions On The Cutting Edge"
Re: WWAN
Was this a difficult process? Can you post the part number of the card or the Thinkpad model/type you took it out of? No bios or connecting issues? Any info would be appreciated-I am considering doing the same thing.moore101 wrote:The X300 didn't come with a WWAN card built in. I took a internal Verizon WWAN card from a T61 and it works great in the X300.
H Fawaz
X300 Blue Light Specialk3davis wrote:if the blue LED in the thinkvantage button can be turned off (if photos seen on Flickr were accurate).
Jane
I'm on Twitter
I'm on Twitter
- 3037 Views
Last post by malmso
Sun May 28, 2017 11:49 am
- 733 Views
Last post by exTPfan
Sat Apr 08, 2017 5:07 am
GONE: ThinkPad X300 (TYPE 6478-1VU) +shipping
by cds.helpdesk » Tue Jan 17, 2017 11:31 pm » in Marketplace - Forum Members only - 3 Replies
- 705 Views
Last post by cds.helpdesk
Mon Jan 30, 2017 2:41 pm
ThinkPad T43 ATI X300 video-driver for Win98
by jinfeixibi888 » Tue May 02, 2017 9:35 am » in ThinkPad T4x Series - 5 Replies
- 622 Views
Last post by malch
Fri Jun 16, 2017 3:29 pm
