T43p-Fan died - IBM replaced 3xFan, 1xSytemboard; 1xCPU
tomkit66
#31 Post by tomkit66 » Sat Apr 05, 2008 3:58 am
Hi all!
Just to keep you updated about my never ending story ...
Now they replaced the fan the 3rd time and the CPU ... still the same ... temps are lower but fan runs between 4000 and 4300 rpm and drives me crazy.
Tech guy said that he has no idea what else he could do and I should call Lenovo.
What should I tell them?
T43p [2668G2G] | 2.13GHz | WXPP | 1GB RAM | 60GB (7200rpm) | 14.1"(1400x1050) | Mobility FireGL V3200 | Intel 802.11a/b/g | Bluetooth | Fingerprint Reader | Ultrabay Multiburner | 9 Cell LiIon | 6 Cell LiIon | Ultrabay Li-Polymer 1.5 Ah | MiniDock II
FTC
#32 Post by FTC » Sat Apr 05, 2008 4:20 am
Hi, what are all the temps now ? It is my understanding that the firmware sets the fan speed according to what it measures in all the temp sensors... so it may be that it is the GPU or other sensor that is still indicating heat and shooting the fan high. Failing this, I'm affraid your motherboard may have a problem.
760CD -> 770X -> 600E -> T23 -> T40 -> T42 -> T400 -> T430
Thinkpad T430 i5 3320M 320GB HD, 8GB Mem
Nick Y
#33 Post by Nick Y » Sat Apr 05, 2008 4:21 am
Just noticed that your are using Fan Control 0.18 whereas I am using 0.25svc on my T43. If I set my fan control to Bios, the fan speeds up to over 4000 and then drops back to just over 3000. (I am only running Firefox at present.) Set to Smart mode and fan speed drops to 0 until temp goes over 55 deg C. (GPU is at 54 deg C)
IBM ThinkPad T43-2668-F5G,
tomkit66
#34 Post by tomkit66 » Sat Apr 05, 2008 5:06 am
FTC wrote:Hi, what are all the temps now ? It is my understanding that the firmware sets the fan speed according to what it measures in all the temp sensors... so it may be that it is the GPU or other sensor that is still indicating heat and shooting the fan high. Failing this, I'm affraid your motherboard may have a problem.
Hi!
Here are the current temps:
CPU 58
APS 50
PCM 37
GPU 64
BAT 37
BAT 34
BUS 51
PCI 54
PWR 50
Fan State 0x80 BIOS Controlled
Fan speed 4059 RPM
Log
[05.04.2008 12:06:22] Current Config:
[05.04.2008 12:06:22] Active= 0, Cycle= 5, FanBeep= 1200 30, MaxReadErrors= 10
[05.04.2008 12:06:22] IconLevels= 50 55 60, IgnoreSensors= XXX,YYY,ZZZ
[05.04.2008 12:06:22] Levels= 47°C -> 0, 50°C -> 3, 55°C -> 4, 60°C -> 7, 70°C -> 0x80
They replaced the motherboard 2 weeks ago....
Tom
tomkit66
#35 Post by tomkit66 » Sat Apr 05, 2008 5:08 am
Nick Y wrote:Just noticed that your are using Fan Control 0.18 whereas I am using 0.25svc on my T43. If I set my fan control to Bios, the fan speeds up to over 4000 and then drops back to just over 3000. (I am only running Firefox at present.) Set to Smart mode and fan speed drops to 0 until temp goes over 55 deg C. (GPU is at 54 deg C)
When I right click the FanControl icon and activate "Smart Mode" the software strats beeping and I get error warning in the Log window.
Do you know why?
MangoGT
#36 Post by MangoGT » Sun Apr 06, 2008 10:54 am
tomkit66 wrote: They replaced the motherboard 2 weeks ago....
Tom
If you continue to have problems after a Lenovo authorized repair, you should call Lenovo customer service and discuss the issue with them. If you recall, I mentioned that I've had fan/MB issues with my machine. They replaced the system board a third time recently and said that next time they will just replace the machine.
PM me and I can give you more info.
FTC
#37 Post by FTC » Mon Apr 07, 2008 1:44 am
Lookig at your temps and fan levels now it can be seen why your fan is spinning at 4000 RPMs. You have set the level to switch to 4K RPM at 60ºC and the GPU is running at 64ºC, so this is normal behavior. Your temps are however normal. The GPU could still be a bit coulder, but it is OK. So my suggestion is to change the threshold levels. To give you an idea I have the following settings :
Off->Level 3 (low) : 57ºC
3 (low)->4 (middle) : 67ºC
4 (middle) -> 7 (high) : 75ºC (this is 4K RPM)
7 (high) -> 0x80 (max) : 87ºC
tomkit66
#38 Post by tomkit66 » Mon Apr 07, 2008 12:17 pm
MangoGT wrote: If you continue to have problems after a Lenovo authorized repair, you should call Lenovo customer service and discuss the issue with them. If you recall, I mentioned that I've had fan/MB issues with my machine. They replaced the system board a third time recently and said that next time they will just replace the machine.
Thanks, I will call Lenovo tomorrow and will see what they offer to do. I´ll come back to you!
tomkit66
#39 Post by tomkit66 » Mon Apr 07, 2008 12:21 pm
FTC wrote:Hi,
Thanks for the help!
How can I change the temp levels?
I told the tech guy the last time that it is no wonder why the fan runs at level 7 all the time because the temp levels are set to those levels.
He didn´t seem to know how to change the levels so he said nothing....
CZOLG
#40 Post by CZOLG » Mon Apr 07, 2008 2:48 pm
It is not possible to change them if you're not using TP Fan Control or NHC with ACPI profile.
That is why technician could not help in this matter.
T43p
