Oh and lastly, you would be crazy to consider ANY of those other makes, take it from a sceptic and realist when i say that IBMs are built to be used!
J
I've got a Skandinavian keyboard made in Thailand, atleast it says so in the bottom (:)), also when compared to pictures of Chinese, it really does have less airholes, none the less it still flexes without some foam.James314 wrote:I would just like to add that the keyboard flexing is a non-issue. If it flexes it is most likely the Chinese keyboard, call up IBM and have them send you the Thai version (you can tell which version you have by looking underneath the arrow keys for blueish green bumpers, which would mean you have the thai version).
J
