#35
Post
by j2k » Fri Jun 27, 2008 12:47 am
Rotter, wow, this is huge. You have given me renewed hope that my t30 board can be salvaged!
So, using the image t30bottomg6fr6_2.jpg, I have determined the following:
At point 1 --- 2.0V
After unit 2 --- .7V
At terminal b on unit 4 --- .1V
At point 5 (aka terminal c on unit 4) --- 1.6V
At post after unit 7 (you labeled it <-3.3V) --- 3.3V
At point 8 --- 0.0V
On the top side, using image t30topj5im4.jpg, I found the incoming voltage to the 10 Ohm to be 16.6V, which is what my AC adapter is providing.
I'm not sure how to check resistance of the top and bottom side 10 Ohm resistors without taking them off of the board (which I am loathe to do, unless it appears necessary). I don't have a lot of experience with this sort of thing.
What does this all mean??!
Just to recap from earlier posts: t30 runs perfectly on charged battery, but will not even attempt to boot if dead battery is installed and AC adapter are plugged in, and will attempt to boot with only AC adapter plugged in but will shut down after ~10 seconds and report "error 190 Critical low battery..."
Thank you so much for all of your help! Wow, you are a genie!
