A similar T43 (with X300 and 512MB, 1.86GHZ, 2687-D7U) is 2079$ (List price) so calculate with your current discount and you will see...danny_isr wrote: i was looking till now into T42 14" 1.7Ghz Radeon 9600- 64M . 40G, 256M. i can get it for $1400 now , using IBM discount. how much a T43 with similar specs will be?
T43 Discussion!!
Re: trying to understand
"tribal-sunrise" <---- and some humans are really rude !tribal-sunrise wrote:some humans seem to be blind - there are countless posts about this in this thread - t43 with x300 exist - look here for example (incl. prices)
http://www.ibm.com/common/ssi/rep_ca/5/ ... 05-025.PDF
i'm at work on a work station machine without PDF reader .
IR0NMAN wrote:A similar T43 (with X300 and 512MB, 1.86GHZ, 2687-D7U) is 2079$ (List price) so calculate with your current discount and you will see...danny_isr wrote: i was looking till now into T42 14" 1.7Ghz Radeon 9600- 64M . 40G, 256M. i can get it for $1400 now , using IBM discount. how much a T43 with similar specs will be?
thanks IR0NMAN.
no problem
thanks Leon , appreciate that !
Now, back to the exciting new ThinkPad shopping here
I believe if you go to IBM's website, you can get the exact weight of the 6-Cell and the 9-Cell batteries to get the exact difference.
As to the graphics, that's EXACTLY what I want to know. Will the X300 be enough better than the M9600 to be worth the loss of nearly a half hour of battery life??
http://www.rojakpot.com/default.aspx?lo ... =88&var2=0
This link details the differences in specs, and the X300 looks to be a higher clocked M9600 on paper. However, I'd like to see some real-world benchmarks to determine if there is any noticeable difference in real-life. Most of the benchmarks out now are on the X800/X700/X600.
Rob
Rob
tribal-sunrise
excuse me but you were at least the 20th who asks the question - that was the cause I made my state - I had the opinion that someone who can write a post is also able to read the thread before writing a question (btw. the pdf was only one example of 10 links or more - there are also links like this:danny_isr wrote: "tribal-sunrise" <---- and some humans are really rude !
http://www5.pc.ibm.com/de/products.nsf/ ... d+T+Series
there you can see the same informations about the existing x300 models without a pdf reader ...)
ThinkPadX40
K. Eng
- Moderator Emeritus
Just a minor quibble, but it's Lenovo, not "Lenova."
The deal won't be finalized until April or May, and I'm sure the ThinkPad designers aren't simply twiddling their thumbs waiting for IBM and Lenovo to sort out the details. There are probably designs in the works that will reflect IBM specific work.
Even after the merger this may hold true if the design team people stay on board.
ThinkPadX40 wrote:T43 last product/Model for IBM ThinkPad before Lenova product ?
Folks,ehd wrote:flame war wheee, anyways the radeon 9600 is compatible but it was made for direct x 8.1 i believe... so like it doesnt have like all of directx 9's goodies.. it just runs it.
Both the desktop Radeon 9600 and MR9600/FireGL T2 in ThinkPads are Direct X 9.0 parts, made to support Direct X 9.0a features like PixelShader 2.0, full floating point precision rendering, etc. Subsequent additions to the DX9.0c include PixelShader 2.1, and a few other enhancements. But don't be fooled: the MR9600 is both Direct X 9.0 compliant and compatible, meaning it has all the necessary hardware to support DX9. The older MR9000/MR9200/MR7500 and FireGL 9000 are Direct X 8.1, with no support for PixelShader 2.0/VertexShader 2.0.
Here's Tom's Hardware's article on MR9600 with links to DirectX9 articles as well... http://www.tomshardware.com/mobile/2003 ... ia-01.html
Daniel.
Features of the MR9600:
DirectX9
Chip clock 300 MHz (MR9600 per 350 MHz)
Max. memory clock 300 MHz (MR9600 per GDDR-2M with 350 MHz max)
Theoretical pixel fillrate 1400 MPixel/s
Memory bandwidth 9600 MB/s
4 pixel pipelines (each with 3 pixel shader operations per clock signal, or a total of 12 pixel shader operations per clock signal)
2 vertex shader units
0.13-micron fabrication process
PixelShader 2.0 support, full floating point precision
VertexShader 2.0 support
6 FSAA (MultiSampling with gamma correction)
16x anisotropic filtering
HyperZ III (8:1 Z-compression)
Powerplay4 with Power-On-Demand:
Power management for the chip, which can be manually controlled by the user, or which can be defined according to the performance requirements of the application running.
Overdrive: automatic, dynamic "overclocking" of the chip (on-the-fly)
HDTV-Out
Support for Wide Aspect LCDs
Just FYI:
Since someone mentioned Lenovo, I will also add that IBM employees who were in PCD cannot look for other assignments or jobs at IBM for a period of two years from the time the deal is finalized (actually, they can't come back as of now for two years, technically speaking, but it will be 24 months from the time the sale is finalized in April).
Daniel.
Daniel.
hundesau,
Maybe I'm wrong, but I read Conmee's message as meaning that people who were part of the Personal Computing Division are not allowed to get re-assigned from that division to another part of IBM for two years.
My guess would be that this would keep everyone from jumping ship. After all, IBM did say that the employees were part of the deal, too. They, of course, have the option to quite *entirely*, but then that would jeopardize their chances of getting a position elsewhere within IBM in the future (they'd have to be re-hired), so there is an incentive to suck it up and stick around to work for Lenovo for 2 years.
-- Nathan
-- Nathan
There was an interesting article in CRM (Computer Reseller Mag) that implies that a number of IBM R&D people may get lucrative offers from HP or Dell and this may be what undermines the IBM Lenovo deal. Without the same R&D effort, the Thinkpad line will lose it's lustre.Conmee wrote:Just FYI:
Daniel.
CRM article
could you pls provide us with the article?
scan?
thx
scan?
thx
anyone here NOT really all that excited about the T43? upon looking at specs, while it does look impressive, i can still upgrade a lot on my T42 which would make it pretty [censored] close to the performance of the T43s, i can still upgrade my processor to the highest PM765 when the price comes down enough, i can expand mem to 2GB if i wanted to, i just dont seem to have the excitement for it
T42 Owner (2374-3VU)
I was excited...until I heard about the battery life taking a dive because of the Sonoma PCI-E Bus. IBM's quoted times (tabook) on the "p" models are down about 0.6-0.7 hours from the T42ps (from 5.9 to 5.2 on the 14.1" models). Now, is the additional performance worth the drop in battery life? I believe that depends on each person.
Anyone find it odd that the current top of the line 14.1" T42p still has a list of $4249, while the top of the line 14.1" T43p will go for around $3800? Of course, you can't get the T43p until April....
Rob
Rob
I have been following this thread, and it seems that the T43 is just an incremental improvement (not a quantum leap) from the T42. The ExpressCard slot, faster FSB and CPU chipset sound all like good things, while the supposedly lower battery life seems like a small setback.
Also, the graphics card sounds like a nice improvement, unless we are stuck with system graphics on the T43 (vs the T43p).
I guess that for me the biggest question is: Are the little flaws regarding the construction of the T42 going to be gone with the T43, the same as the T23 ironed out some of the problems with the T2x series (stress cracks for example). Some people might consider this a stupid consideration
Ruben
Ruben
T-23 (2647-2MU)
1.13 Ghz
1Gb RAM
60 Gb 5400 HD
1.13 Ghz
1Gb RAM
60 Gb 5400 HD
T42 vs. T43
Having read many posts...I am starting to wonder if it's worth it to wait for the T43. While I'd like to be "future-proofed" as much as possible...do the improvements to the T43 really make it that much better a machine than the T42?
Any help/insights will be appreciated & used in my buying decision.
Thanks.
Thanks.
I get Taurens
ready for some pics?
Japanese T43 was photoed:
all pictures are from e800.com.cn, not great picture quality, but you get the idea
http://www.e800.com.cn/articles/images/ ... 477498.jpg-T43 and T42, band of brothers : )
http://www.e800.com.cn/articles/images/ ... 461390.jpg-T43
http://www.e800.com.cn/articles/images/ ... 493489.jpg-suprisingly, I believe the T43 is actually slightly thinker than T42(if I am not mistaken T43 is the machine that's turned on)
Where are you finding the models and prices? When I go to the ibm site I only see 2 T43 models, both having intel graphics.
Taurens - it appears that both the T42 and T43 use the exact same chassis. They are both the same thickness.
dr72 - See the document at http://www.ibm.com/common/ssi/rep_ca/5/ ... 05-035.PDF and scroll to the bottom for prices.
I haven't been following this thread and haven't read all 14 pages of posts, so if this has been posted before, I apologize.
Found some additional links on the IBM site today with more T43/p info and thought some of you might be interested.
Overview - ThinkPad T43/p: http://www-307.ibm.com/pc/support/site. ... MIGR-58315
Detailed specifications - ThinkPad T43/p: http://www-307.ibm.com/pc/support/site. ... MIGR-58317
Regards,
James
Regards,
James
James at thinkpads dot com
X220 thinks that the hardware wifi switch is off (help and discussion)
by axur-delmeria » Mon Apr 03, 2017 12:42 pm » in ThinkPad X200/201/220 and X300/301 Series - 4 Replies
- 1004 Views
Tue Apr 04, 2017 11:08 pm
Where does Miix products go for discussion? Miix 320
by TonyJZX » Tue May 16, 2017 4:02 am » in ThinkPad/Ideapad Tablets & Convertibles - 0 Replies
- 139 Views
Last post by TonyJZX
FS/FT: T43 Missing some parts
by ncovert » Wed Dec 28, 2016 1:07 pm » in Marketplace - Forum Members only - 1 Replies
- 230 Views
Wed Dec 28, 2016 5:11 pm
Fellow T43/p owners, looking for a new LCD? Come inside..
by Kaervak » Wed Dec 28, 2016 10:23 pm » in ThinkPad T4x Series - 6 Replies
- 1917 Views
Last post by wujstefan
Mon Jan 23, 2017 9:18 am
