Currently when Watcher starts, it says "searching" ..forever... But before I put the Lenovo device-id in its Kext/driver, it immediately said "device not found". So now it recognizes the card, but I don't know if it gets stuck in talking to device or finding the network. I am going to work on it today, got the newer 2.0.10 watcher and drivers, and also check AT command responsiveness. Will keep posted. If it ends up being power-on problem, I'll follow your two suggestions (look for linux ibm acpi-module and port it to mac, or tap pin-20). Thanks.Zender wrote:sayagain: Aside from taping pin 20, probably not. You'd need ibmacpi or how is that module for linux called, which allows to do fn-f5 enable/disable through some /proc... file. Though I think I've heard of people who got the integrated WWAN working in MacOS... does Watcher see the card properly? Can you issue AT commands to the card?
MC8775 Firmware update to support 7.2MB - does it exist ?
X300 6478-1HU Sierra HSDPA, X31, X40, X41, PowerBook
I have a thinkpad t61p and W500. I am in Australia and i believe our cards are locked to 2100mhz for one of the providers here does anyone have any info on this?
I would like to run it on telstra who are i believe 850?
Is there anyway to flash the card for this and where would i find such a firmware?
Regards
Jeremy
Regards
Jeremy
Hi,booba wrote:Hi,
Regards
Jeremy
Im in Australia and Ive got the same issue.
The Lenovo supplied MC8775 cards are referenced as a Vodafone card in the FRU.
In my previous posts you'll see that although the cards are unlocked to work with 3, Optus, Vodafone and Telstra, but they are band locked to only work with the 2100 UMTS and 900/1800 GSM bands.
You can get it working with Telstra but it will use the 3Telstra (UMTS 2100) network and not the Telstra (UMTS 850) NextG network.
Im also trying to run the card on Telstra's NextG network but haven't had any success.
Much needed Cisco firmware
Dear all,
will any of you be kind enough to send the Cisco firmware. I am using a X61. I am aware that it is missing 1 antenna wiring for 7.2 mbps. I want to upgrade to higher sensitivity for the Sierra HSDPA modem.
Much appreciate help in advance for sending the Cisco firmware
Re: Much needed Cisco firmware
for al those who want the new firmware its located hereredwind wrote:Dear all,
http://rapidshare.com/files/140112574/8 ... 3.tar.html
Hello, I have the same issue here but with my sim I get no signal at all from telstra. The modem and sim are detected but after long searching no signal is found. Could someone please be kind enough to tell me in noob speak how to apply the firmware for the sierra modem in linux. Is there no windows program to do this? I've been forced to use Vista instead of Linux because that's the only way I can be on line. I'd also be interested to know why the connector for auxiliary isn't included on the card 'cos I noticed on the Sierra site picture that the mc8775 had both connectors but the one I got from Lenovo Australia only has a connector for main.
My regards
My regards
firmware 7.2 mbit
I found new telstra firmware, CDM-882seu wireless router internal modem MC8775 Phone Module Firmware: H2_0_7_1BM.
http://www.call-direct.com.au/downloads ... pgrade.zip
working my vodafone hungary operator.
Re: firmware 7.2 mbit
Wont update my MC8775.breki196 wrote:I found new telstra firmware, CDM-882seu wireless router internal modem MC8775 Phone Module Firmware: H2_0_7_1BM.
It says something along the lines of 'you already have the latest firmware'.
Hi guys, it's good to have the firmware to try, but no good if there is no utility to do the firmware update.
I been searching/Google around for a Binary Update Tool to update MC8775, but can't find anything.
Can someone shine some light on how to update/flash the new/updated firmware onto MC8775 miniPCI card?
Thanks in advance.
Thanks in advance.
Lappy : Thinkpad T60 CTO - 2007M5M
I managed to install this firmware and still dont have 850 UMTS support.breki196 wrote:I found new telstra firmware, CDM-882seu wireless router internal modem MC8775 Phone Module Firmware: H2_0_7_1BM.
On a more important note this firmware has installed four network profiles that I cant delete.
Ive tried manually deleting these profiles in the watcher application but they seem to be installed to the flash of the card.
Ive tried to reflash the card with different firmware, but as a part of the firmware update it backs up operator settings and they are retained.
Is there a way delete these profiles?
Thinkpad X301 - C2D SU9400 - 4Gb DDR3 1066 - Samsung 128GB SSD - Intel 4500MHD - 13.3" WXGA+ - Ericsson F3507g WWAN - Intel 5300 WLAN - BT v2.1 -- Integrated Cam - Wireless USB - Ultrabay 3 Cell Battery & DVDRW - Windows 7 Professional x64 - 3 & 6 Cell Batteries
Re: MC8775 Firmware update to support 7.2MB - does it exist ?
Great Thread and thanks to the contributors.
I got a nice bump using ATT/Cingular.
I went from under 1Mbps to 1.7Mbps.
I'd like to know how my speed compares with others using ATT/Cingular in the US?
-mo
-mo
X300, X61 tablet, X61, X60 tablet & X40 tablet
I managed to clear some "Telstra" profiles which I could not delete (when I upgraded an AC875 with Telstra firmware). After un-installing the 3g watcher, try deleting the following folders & registry keys (if remaining) OR search for equivalent before re-installing the 3g Watcher Software.Rambler76 wrote:Is there a way delete these profiles?
C:\Program Files\Sierra Wireless Inc (or any Sierra Wireless folders)
C:\Documents and Settings\(Your ThinkPad account name)\Application Data\Sierra Wireless
HKEY_CURRENT_USER\Software\Sierra Wireless Inc
HKEY_CURRENT_USER\Software\ToolBoxDebug
HKEY_LOCAL_MACHINE\Software\Sierra Wireless Inc
HKEY_LOCAL_MACHINE\Software\ToolBoxDebug
HKEY_USERS\S-1-5-21-2129212323-643162992-444501231-1005\Software\Sierra Wireless Inc
HKEY_USERS\S-1-5-21-2129212323-643162992-444501231-1005\Software\ToolBoxDebug
Note: The firmware flash did not write any pre-defined profiles (ie Telstra) into the the AC875 card, as when I connected the card into a clients PC, the Telstra profiles were non-existent
With regards to the 850MHz problem, Have you tested the sim in another 3g device supporting the 850Mhz band? Could it be that the Sim will only work with the networks own supplied devices? or is there an additional setting required within the software?
bill bolton
Re:
Are you trying to use a BigPond Broaband SIM or a Telstra Mobile Broadband SIM, for NextG access?Rambler76 wrote:Im also trying to run the card on Telstra's NextG network but haven't had any success.
Bill B.
hi,
thanks for the responses.
im using a nextg prepaid sim.
i previously uninstalled the watcher application and deleted all registry entries relating to sierra and telstra.
maybe i missed a few. I'll try those listed and let you know how i go.
thanks again for the responses.
gigafloppen
I upgraded to firmware in my x300 with the mc8775 to H2_0_7_1BMCAP and it worked like a charm! Got 7.2 mbit connection speed to my ISP and according to speedtest.net 4.2mbit/0.3mbit (about double the performance from old firmware).
Great info in this thread, thank you all!
Thinkpad T60p T2500(2GHz), 3GB RAM, 100GB 7200rpm HD, 1600x1200 LCD
how do you use the files ?, I can't find the exe to update it.breki196 wrote:I found new telstra firmware, CDM-882seu wireless router internal modem MC8775 Phone Module Firmware: H2_0_7_1BM.
hi,gigafloppen wrote:I upgraded to firmware in my x300 with the mc8775 to H2_0_7_1BMCAP and it worked like a charm! Got 7.2 mbit connection speed to my ISP and according to speedtest.net 4.2mbit/0.3mbit (about double the performance from old firmware).
could you post a link to the H2_0_7_1BMCAP MC8775 firmware?
gigafloppen
The firmware H2_0_7_1BMCAP can be found in breki196:s post in this thread. If you install the Sierra wireless 3G watcher (found on sierra wireless homepage) the application used for the fw-update (binupdater.exe) can be found in the application folder.
Firmware H2_0_7_1BMCAP is also available from CallDirect's support pages.
Hi,Peak2Peak wrote:I managed to clear some "Telstra" profiles which I could not delete (when I upgraded an AC875 with Telstra firmware). After un-installing the 3g watcher, try deleting the following folders & registry keys (if remaining) OR search for equivalent before re-installing the 3g Watcher Software.
Note: The firmware flash did not write any pre-defined profiles (ie Telstra) into the the AC875 card, as when I connected the card into a clients PC, the Telstra profiles were non-existent![]()
I've uninstalled the watcher application and removed all remnants of Sierra Wireless installations but im still getting the following profiles which I cant delete.
WWAN - Telstra.Pcpack
WWAN - Telstfra.Datapack
WWAN - Telstra.Internet
Its causing issues as I cant set my provider (3) as a default profile and it doesn't allow my provider to appear in the watchers drop down list.
I've installed SIM's from two other providers (optus and vodafone) and Im able to edit and delete the auto configured profiles easily within watcher but I cant do this for the telstra profiles.
Ive tried flashing to get rid of the profiles but they seem to be retained as the flash program displays a 'backing up settings' screen during the process.
Also try deleting (after un-installing/deleting the above) C:\WINDOWS\system32\drivers [swnc8u12, swnc8u55, swumx12, swumx55...and/or additional Sierra Wireless drivers in this area!], then install this version of the Sierra Wireless MC87xx 3G Watcher Build 3.0 1822 from the FSC website typing "watcher" in the "Full text search Software" box.
EDIT: FSC has removed the Sierra Wireless MC87xx 3G Watcher Build 3.0 1822.
thanks for the response Peak2Peak.
I'll give it a go in the next night or so.
I'll go through the uninstall of the watcher and lenovo driver applications and delete all relevant registry entries again.
One thing that concerns me is that I cant edit or delete the profiles in watcher. the profile settings are greyed out and this makes me think that they are in flash.
Also something seems borked as watcher is reporting v1.93 firmware instead of the latest v2 firmware I flashed.
Is there some type of reset utility for this card?
I've found that Sierra Wireless are the most unhelpful company when it comes to service. they keep palming you off to lenovo or your wireless carrier.
I have not come across any sort of Sierra Wireless reset utility as yet, but it may be only available to OEM developers etc - Like yourself I have tried contacting Sierra Wireless directly by phone asking questions on OEM Embedded Modules only to be pointed to the OEM suppliers/carriers.
bill bolton
There aren't any free lunches in the OEM product supply business form any manufacturer, so that's part of the deal when you buy an OEM product.Rambler76 wrote:they keep palming you off to lenovo or your wireless carrier.
If you want Sierra support, buy a Sierra retail product (usually for more $$$, as there is no OEM vendor to subsidise the hardware cost through other aspects of a goods/services bundle).
Bill B.
X1 Carbon 1st gen - battery firmware upgrade fails?
by hvergelmir » Mon Mar 06, 2017 6:07 am » in ThinkPad X1/X1C - 4 Replies
- 456 Views
Last post by cfds
Mon Mar 06, 2017 4:52 pm
Hitachi 7k100 IBM firmware files/instructions needed
by EloItsMee » Wed Apr 19, 2017 12:09 pm » in ThinkPad T4x Series - 6 Replies
- 870 Views
Last post by EloItsMee
Thu Apr 20, 2017 11:50 am
BIOS update - ok to jump 11 updates in one update?
by serpico » Tue Apr 18, 2017 11:53 am » in ThinkPad T430/T530 and later Series - 6 Replies
- 486 Views
Last post by MikalE
Wed Apr 19, 2017 12:21 pm
Models that support two ultrabays
by Whitieiii » Sat Jan 21, 2017 6:49 am » in GENERAL ThinkPad News/Comments & Questions - 5 Replies
- 544 Views
Last post by Whitieiii
Sat Jan 21, 2017 4:34 pm
