SP3 Windows XP... what's the verdict?
True, true.
My line of thinking regarding these major "updates" remains unchanged:
- if your system's not broke - don't fix it
- if MS releases an "update" don't upgrade until it's proven to work as intended.
- expect to perform a clean install instead of "updating" using a SP, because it will break something.
Well, I decided to move forward and install SP3. Installed them on 2 T41s, 1 T42, and 1 T60, all without issues or problems. I fully expected my wifi to not work, but everything is working fine. So far, I don't notice anything different, things seem the same to me.
uberT, if your "Dan, is that you" question was directed to me, yes, it is me. And you are????
mattbiernat
bill bolton
At best a particular Windows XP system may be stablised, but all Windows XP systems are intrinsically and systemically broke at a whole host of levels, so your plan is also broke right out of the box.icantux wrote:- if your system's not broke - don't fix it
The risk of not applying a Microsoft distributed operating system fix usually far outweighs any risk arising from applying it.
Bill B.
^ Though in this case, if one has been good about installing updates and hotfixes through Windows Update, how much additional benefit is gained from installing SP3?
I do think waiting a little bit before installing an SP to allow kinks to be worked out is a good idea, unless there is a host of critical security fixes.
T42(p) 2379-DXU | 15" FlexView, 2.0 GHz, 2 GB, 128 MB FireGL T2 mobo, UJ-842 Multi-Burner, 100 GB 7200 RPM, Dock II
T410 2516-CTO | 2.66 GHz i7-620M, 6 GB, 512 MB NVIDIA 3100m, 160 GB SSD
does SP3 require the Genuine Advantage Validation thing to be installed? i refuse to install Genuine Advantage so i can only use Automatic Updates and not Windows Update. i received notification of SP3 via auto update but it just disappeared when i hit download. will have to get around to doing the standalone install for it but hoping that doesn't require Genuine Advantage.
now: X61, T42p
before: 600E, T23, X20, T40, X40, X31, T60
FS: Travel Bezel, 100GB drive (OEM Lenovo)
No -and you can download the whole of SP3 via the link I posted earlier in this topic.bri wrote:does SP3 require the Genuine Advantage Validation thing to be installed? i refuse to install Genuine Advantage so i can only use Automatic Updates and not Windows Update. i received notification of SP3 via auto update but it just disappeared when i hit download. will have to get around to doing the standalone install for it but hoping that doesn't require Genuine Advantage.
IBM ThinkPad T43-2668-F5G,
You could also try http://windizupdate.com/
Runs via your Firefox browser.
No crap from Micro$haft to contend with!
Re: sp3 wierded out access connections and disabled wireless
That is precisely what happened when I tried to apply SP3 to my T42.Dr. Duke wrote:I have thinkpad 42p.
When I installed sp3 it caused access connections to work wierdly, not able to turn on or off wireless networking. In fact, I could not connect to my wireless network, and received contradictory messages such as wireless connected and turn on wireless. Even thought eh wireless light was on, it was obviously not working and could not find a wlan
even though there are two 25 ft. from me.
I tried updating and reinstalling TP access connections, still no go.
I had to do a system restore to get back on the INTERNET.
Thank God that worked.
Any suggestions?
I might just have to wait for some new updates from Lenovo, or some instructions from lenovo until install sp3 again.
I called lenovo service but an Indian chap told me they don't give tech support on software.
well.......
Hm, that's wierd then that it crapped out on 3 machines from Automatic Update. Anybody else have that happen?Nick Y wrote:No -and you can download the whole of SP3 via the link I posted earlier in this topic.bri wrote:does SP3 require the Genuine Advantage Validation thing to be installed? i refuse to install Genuine Advantage so i can only use Automatic Updates and not Windows Update. i received notification of SP3 via auto update but it just disappeared when i hit download. will have to get around to doing the standalone install for it but hoping that doesn't require Genuine Advantage.
now: X61, T42p
I installed SP3 on my T60 (after a backup ofcourse) thursday morning and have had no problems yet. Nothing is broken, everything runs great. Bootup seems a little slower though and the machine is running a few degrees hotter than usual, gotta figure out why.
Rules of the road
Rules of the road
I have it on my T41 for a week now - it feels faster but I upgraded the HDD a week ago - probably it's because of the fresh XP install and the better drive. No problems so far, AC 4.52 works fine.
T430 · i7-3632QM · 12GB RAM · 512GB SSD · HD+ · NVIDIA NVS 5400M · H5321gw
T420s · i5-2520M · 12GB RAM · 480GB SSD · HD+ · HD3000 · F5521gw
T60 · T2500 · 3GB RAM · 128GB SSD · 14.1 SXGA+ · 128MB ATI X1400
Past: T400, T41, T22, 600X, 390X
That will fix itself after XP has a chance to optimize the prefetch folder; give it a few days. If you always run on battery power, however, then the cleanup task will never run but you can force the issue with this command:gator wrote:... Bootup seems a little slower though...
Rundll32.exe advapi32.dll,ProcessIdleTasksMark
My ex: X41T (2005 - 2009)
Done. It now works just as you say. I have to wonder what those two pieces of software do except for using memory. I can only guess they maintain the icon in the system area near the clock but I keep that turned off. Thanks.beGi wrote:If you have Intel's GPU use msconfig (or anything similar) to disable startup of igfxtray.exe and igfxpers.exe... No more startup flicker...HIPAR wrote: On bootup the display flickers ...then reappears and all is well.
--- CHAS
aarontring
SP3 on a 600E
I was about to add a reply that I was having no trouble after updating to SP3 on my kid's 600E, but Firefox wouldn't let me log in. It would keep kicking me back to the main forum page or be stuck in a loop of asking me to log in. I already have trouble using the UltraNav button to scroll in Firefox, both with this machine and my 390X. I haven't updated the 390x, since I've only got one power supply at the moment (one is on order for the 600E). I do have about an hour or so of battery life on the 390X, but the updates on this one have taken... Well, I started at about 2PM CDT.
That's the only thing that I've had a problem with, though. With XP on this machine, I can't right-click on the start menu items, but I can right-click everything else. That's more a mild annoyance. I also was in mid-download on Firefox when Auo update started installing SP3, so I have no real baseline. Perhaps it was going to have problems with Firefox, anyway.
I have been browsing and streaming music from one of my desktops over the network, often with multiple tabs for a couple of hours, now, and the only real lag has been when loading some of the more Flash-intensive websites.
Both of the "newer" Thinkpads just got clean installs of XP, then Firefox, then Open Office, then AVG. The 390X took it like a navy town street walker, but I'm only up to Open Office on the 600E, and I'm already seeing the idiosyncracies with Firefox. I probably should test the office software. I see why programmers and "Nerd Herders" drink Mountain Dew. Bud Light kind of dulls the analytical senses...
Off topic, the sound and keyboard on the 600E kicks the 390X in the USB port!
Daily driver: T41p 2373-GGU
When I need a serial port: 600E 2645-4AU
My toy: 365X 2625-2E9 (for old DOS games)
Just installed it on my main PC. Took all of 13 minutes.
Not a single problem so far
aarontring
I figured out the unrelated Ultranav problem, which turned out to be a driver issue. While I was doing that on my 390X, I was adding SP3 to my "family" computer (media center hooked up to 40" LCD TV). THAT got a BSOD that I have to work out, so now I'm holding off on my 390X. 600E is still running, though. I know everyone else in this thread is talking about newer machines, but I think it's interesting that my oldest machine (the 365X project is spread out all over my workbench at the moment) is the one that takes the freshest updates...
Thinkpad T40 here with XP PRO SP2.
Downloaded SP3 and tried to install it. Aside from minor issues, it was going well until I got a message that said the install had failed and that is was likely that I would be unable to revert to SP2. (Can't recall the exact message). After a couple of power reboots, XP reloaded and I used a system restore to go back. Am hesitant to try again and wonder if there are incremental updates that will do what this monster, but flawed SP3 does?
Tks for any help.
Tks for any help.
RoadHazard
SP3 showed up in Windows Update on my T40p. But once I proceeded with the installation, it did nothing and it never showed up in WU ever since. Now I'm still stuck with SP2. Because of what happened, I'm reluctant to install SP3 manually using one of the dowload links because the previous attempt seemed to give a hint that something is not right. Until it shows up again in WU, I'll keep the SP2 for now. BTW, other patches show up in WU fine, so I know my WU is not broken.
-T42p 2374-D03 with Pentium M 765 2.1GHz, 1.5GB RAM, 7k60 HDD, IBM 802.11 a/b/g II wireless, 6-cell battery, and no touchpad
-X61 Tablet 7764-CTO with 3GB RAM and 7k200 HDD
-W500 4061-CTO all stock
dr. zoidberg
For those that had problems with wireless not connecting after installing SP3, I solved it by enabling the Extensible Authentication Protocol Service. I posted this in the T4x subforum so this is just a heads up.
IBM T42 2373-3uu
Dothan 1.7Ghz @ 1.9GHz
120Gb Samsung HM121HC 5400rpm
1.5GB DDR333
14.1" SXGA+
Radeon 9600 64mb
1.5GB DDR333
14.1" SXGA+
Radeon 9600 64mb
I installed XP-3 without any problem on my T60P.
But I'm having problem installing it on my T41P.
When I try to install it on my T41P half way through I get an error 'Access denied for installing XP-3"
I tried it with the window update and CD and got the same error.
I uninstalled KIS and have more or less the same programs as I have om my T60P but no joy.
Anyone has any idea what the problem is?
Sepehr
Sepehr
You pretty much need Windows completely updated (especially .NET Framework) before installing SP3. Then download the file (sorry if I misinterpreted what you wrote) and apply the Service Pack manually. It has worked on any T30/T4x I have tried of my own or clients. ... JDH
I had the same problem.akhavan wrote:Hi,
Sepehr
Googled an came up with a solution, albeit a slightly fiddly one.
When I get back to work I can post it here.
Anyway, after this I was able to install SP3, but feed updating in IE7 stopped updating. Nothing would bring it back.
So I ended up recovering my system from a backup (made with basic system and my apps) and installed SP3 from there.
No problems, everything fine now.
T43p
- 1365 Views
Last post by ThinkPad560X
Fri May 19, 2017 1:57 am
x1 4th Generation with Windows 7 or 5th generation with Windows 10 - which to buy?
by mirc » Wed Apr 19, 2017 11:50 am » in ThinkPad X1/X1C - 5 Replies
- 562 Views
Last post by wpyh
Sat Apr 29, 2017 10:32 pm
- 583 Views
Last post by KingBubba
Sat May 13, 2017 11:26 am
x200T and Windows 7 update
by Billaboard » Sun Jan 01, 2017 2:57 pm » in ThinkPad X200/201/220 and X300/301 Series - 10 Replies
- 1726 Views
Last post by Bob_II
Wed Feb 15, 2017 7:42 pm
