Lessons learned, Win-2000 on T61
Pascal_TTH
Also Windows 3.11 because of his extended network features !
Windows 2000 can also handle AHCI like Windows XP. Windows 2000 is not really limited with hardware support if you compare with Windows XP. The biggest downside of Windows 2000 are boot time and missing system restaure. So I prefer Windows XP using Windows 2000 interface. nLite is really nice to have a fine tuned Windows XP. It allows to start with Windows 2000 interface, have the detail view in explorer, get all the *blinkblink features* away, turn off most warnings, remove useless features, and so on. It take about 12 minutes to install Windows XP with all driver using custom i386 and unattend.txt without any manuel intervention.
Apple MacBook Pro MB133
crashnburn
Interesting. It would be interesting to do a compare of XP Tuned like this and 2000 tuned for performance as well as stability... Try to BSOD the OSes.
Somehow I literally remember that no matter what task it was I could END it and terminate without the system going down. I remember not rebooting for months on end (desktop with dual 17" or 19" monitors).
Pascal_TTH
After 10 years of Thinkpads and six years with Windows XP, I know all the driver, software and any middleware from IBM/Lenovo. Thus, custom Windows XP with fully unattend (including app auto install) and .reg files *injections* allow me to install quickly fine tuned Windows XP. System are very stable and free from any bloatware or useless software. I use fine tuned Windows XP from years on my Thinkpads and I never see a BSOD. BTW, I never use an IBM or Lenovo installation.
mattbiernat
Pascal_TTH
Only preset for applications. I don't use any reg to boost or speedup Windows. To tell the true, when I start to test some, I never noticed any performances improve even if I'am very common with benchmarks. Also, the best way to have a fine and fast system is not to install useless applications.mattbiernat wrote:Pascal_TTH wrote:Note from Admin: Removed excessive, nested quoting.
I double beg to differ. In fact XP will crash for way more than just a hardware reason in my experience. I have, on a regular basis seen XP hang because of an unresponsive program and many times get to the point where Task Manager is unable to kill the process. I have always, ALWAYS been able to kill a hanging program or process with Win2k. That is the most annoying change I have noticed in XP, second being that it is bloated and requires too much hardware performance,... by default.ajkula66 wrote:crazyfrog wrote:
crashnburn
I agree on that about XP & 2000. 2000 was in Controlt20user wrote:ajkula66 wrote:crazyfrog wrote:
thormdac
ok, i spent the last two days getting w2k onto my x60, 1706-86u!
-- blazingly fast out he box- hibernation in about 6 seconds!!!!
-- unfortunately the system temp. is constantly at 64 degrees, while my xp config is at 48 degrees
-- processor is displayed as "genuine intel cpu" obviously not core duo, even though all applicable w2k and lenovo update are installed!
is there a correlation between system temperature and set-up pocessor?
if only i could sort that out, i would stick with it!
X300 / 6478-15G
| X60s | 1702-5PG | 2GB | 100GB Hitachi 7K200, 3. Generation | XP prof |
/ T60 / 2007-FVG / 2GB / 100GB / XP prof
tylerwylie
Currently using VMWare Workstation to run Windows on my Thinkpad, and I have to say this is really only useful if you have applications that you need to run that don't work on your current OS. He could probably get everything up and running with XP, use a virtualization solution, and be all fine and dandy but that's not really efficient here.o1001010 wrote: because you can run multi os in the same environment? because it does not matter later if you need to upgrade your pc you can have your desktop back in 30 seconds? because it makes the full backup that easy?
as i have already said, if you using win2k you must have a valid reason. virtual pc is not for the overclokers or the gamers, but for enterprise admins like me and domain controllers its heck of a thing. on top of that vm is a perfect solution to address application compatibility.
and guides to install os from scratch can be found on this forum.
Now I'm tempted to grab my old HD and see if I can get W2k working(Currently has factory image). Hehe.
*Edit* removed quoting for mods.
Samuel Adams wrote:The natural liberty of man is to be free from any superior power on Earth, and not to be under the will or legislative authority of man, but only to have the law of nature for his rule.
Pascal_TTH
Windows 2000 does not handle speedstep. It's amazing people don't even know what their *top favorite* OS can and can't do...thormdac wrote:ok, i spent the last two days getting w2k onto my x60, 1706-86u!
Intel speedstep applet is required like with Windows 98.
thormdac
i honestly dont mind being lectured on, but could you than enlighten me why lenovo programmed a speedstep applet for win2000?Pascal_TTH wrote: Windows 2000 does not handle speedstep. It's amazing people don't even know what their *top favorite* OS can and can't do...![]()
see: http://www-307.ibm.com/pc/support/site. ... R-62938#pm
X300 / 6478-15G
Speedstep works...
Or at least it seems to. I did find that I had to manually enable it (it did not go enabled by default).
I don't recall exactly what I did, but I do recall having to tick a checkbox in the app itself to enable its functionality.
Happy tweaking.
Happy tweaking.
Bruce Lane, Owner & Head Hardware Heavy,
Blue Feather Technologies
T500 with Windows 7 Pro x64, Webcam, Atheros/IBM a/b/g Wireless card. Thinkstation E31, Intellistations M Pro and Z Pro.
"Quid Malmborg in Plano" (Firesign Theater)
WIP DIY x320, what I learned so far
by boutch55555 » Mon Feb 13, 2017 7:51 pm » in ThinkPad X200/201/220 and X300/301 Series - 38 Replies
- 3402 Views
Last post by chx1975
Sun Jun 25, 2017 3:35 am
windows 98/2000 on Pentium 4 M
by Whitieiii » Sat Jan 21, 2017 4:45 am » in GENERAL ThinkPad News/Comments & Questions - 4 Replies
- 539 Views
Last post by rkawakami
Sat Jan 21, 2017 11:30 pm
FS: NEC Versa VXi laptop from the year 2000
by RealBlackStuff » Sat Jan 21, 2017 11:59 am » in Marketplace - Forum Members only - 2 Replies
- 301 Views
Sat Jan 21, 2017 4:52 pm
LF: (Physical or ISO/image) A31p Windows 2000 Recovery CD Set
by jeffbaichina » Tue Mar 21, 2017 12:57 am » in Marketplace - Forum Members only - 1 Replies
- 255 Views
Last post by jronald
Sun Mar 26, 2017 5:41 am
