SXGA+ on a X60s (non tablet)
sirarchy
Re: SXGA+ on a X60s (non tablet)
#271 Post by sirarchy » Wed Oct 05, 2011 4:16 pm
papamix wrote:Bad one was from: http://www.aliexpress.com/snapshot/101563707.html (includes cable adapter)
Good one was from: http://www.aliexpress.com/snapshot/101726969.html (does not include cable adapter)
I am pretty sure that they both came from the same pool of refurbished screens. It's just a matter of luck.
Avoid from buying LCD from this seller (I mean "good one" URL). He sended for me broken HV121P01-100 twice for $420.
kai
#272 Post by kai » Mon Nov 14, 2011 7:22 pm
I need some help..
After asking around for a modified harness cable and being directed to a seller on eBay - i.Thinkpad, I duly ordered one over the weekend. Service was prompt and reading the description - it states that cables are tested before sending out. I received it and finally got round to doing my swap today.
I laid everything out and to try a test run to make sure it would power up and display correctly. On initial power up, it worked! A picture displayed quite cleanly. All was well. I had another laptop set up next to me with various guides (and this thread) to go through the next steps(s). Whilst I was glancing through (both laptop were on the same desk), I smelt something funny - it was smoke! It seemed to be coming from behind the panel somewhere - I couldn't quite see. Without thinking, I just pulled to power cable. The screen was black at this point I seem to remember.
Anyway, I was a little afraid to retry in case I caused further damage. However, I did grab my original panel and tried that instead without the modified harness cable. The machine powers up but there's no display. :( I can't see any obvious signs of damage - I'm praying that it's just the video cable (and maybe the LCD) that's gone and nothing more serious.
I inspected the modified cable - when I got it, the soldered end was taped up with some masking tape. When I took this off I saw that pins 2 and 3 seemed to be bridged or badly soldered? It's only a single wire. I've looked at the pinout diagrams and it seems that both pins 2 and 3 are +3.3v. Would this be what might've caused the problem?
I've since contacted the seller - and to his credit has replied but insists that pins 2 and 3 are meant to be bridged soldered? Apparently to give a more stable power source to the LCD? Can this be right? He states that to date no one else has ever reported any problems with his cables.
It's taken me ages to source a panel and the prospect of killing it when I had everything in place is gutting.
#273 Post by RealBlackStuff » Mon Nov 14, 2011 10:13 pm
Our Moderator erik is the person to ask about this.
smugiri
#274 Post by smugiri » Thu Nov 17, 2011 2:56 am
kai wrote:I need some help..
I also bought my cable from from i.thinkpad and found that those pins were bridged.
This should not be a problem. I think that the problem may have been somewhere else.
Drop me an email and I will see if I can help. forum dot thinkpads dot com at ntwiga dot net
Steve
xphinx
#275 Post by xphinx » Mon Nov 21, 2011 3:58 am
Hello everyone.
For few days I've decided to buy an used X60s and yesterday I found this thread.
After reading it (most of posts) I'm undecided if I want to buy an X60 or X60s, because I don't know what model is most suitable for this mod.
If someone changed the display on both models (X60 & X60s) and could tell on which one is more easy to change the display.
As I readed it seems that on X60 is more easy because is thicker.
Could someone confirm me that ?
Thanks a lot.
Proud owner of:
Ibm X22 , cpu: P3 800Mhz , ram: 640MB , hdd: 40GB
Ibm R51 not working... work in progress :)
Eudoxus
#276 Post by Eudoxus » Mon Nov 21, 2011 4:26 pm
As far as the lid goes there is no difference between X60 and X60s unless it is UltraLight display on some X60s and X61s models.
ThinkPad T500 (2242-CTO) P8600 / RAM 4GB / WSXGA+ / HDD Hitachi 7K320 320GB / 6 Cell Sony / Windows 8.1 Pro 64-bit
ThinkPad X61s (7669-3KG) / RAM 3GB/ HDD Fujitsu 7200rpm 160GB/ Windows 7 Home Premium 32-bit
ThinkPad Tablet 2 (3679-25G) / Windows 8.1 Pro
Past: T61 / R61 / R52 / 760E
smugiri
#277 Post by smugiri » Mon Jan 16, 2012 7:50 pm
xphinx wrote:Hello everyone.
Thanks a lot.
Another set of factors to consider. The X61s is Core2Duo while X60 is CoreDuo: this means that the X61s can take a 64bit OS while the X60 cannot. memory limit on the X60 is 3GB (4GB installed with 3GB only available and usable) while the X61 will take 8GB of RAM.
Steve
Raceboy
#278 Post by Raceboy » Tue Jan 17, 2012 6:17 am
X60-s are also available with Core 2 Duo CPUs (1.66 GHz, 1.83 GHz and 2.0 GHz ones).
X61s:L7500,4GB,128GB SSD,IPS
smugiri
#279 Post by smugiri » Tue Jan 31, 2012 4:17 pm
Raceboy wrote:X60-s are also available with Core 2 Duo CPUs (1.66 GHz, 1.83 GHz and 2.0 GHz ones).
You are right, does this mean the Core2Duo X60 have the newer GM965/PM965 chipsets rather than the GM945/PM945?
More important, are there X60 units that can take 8GB?
Steve
#280 Post by RealBlackStuff » Tue Jan 31, 2012 5:07 pm
No X60 can take more than 4GB RAM, of which only 3GB is usable.
Raceboy
#281 Post by Raceboy » Wed Feb 01, 2012 2:30 am
smugiri wrote:[You are right, does this mean the Core2Duo X60 have the newer GM965/PM965 chipsets rather than the GM945/PM945?
No, they have the same GM945 chipset (Napa platform).
lecterek
#282 Post by lecterek » Thu Oct 25, 2012 3:38 pm
On my X61s (XGA) I have successfully flashed Middelton's BIOS v.2.22 which removed whitelist and enabled SATA II. Everything works perfect since almost one year. Now I would like to do SXGA+ mod (I have already SXGA+ LCD from X60t as well as special cable). Concernig this I have two questions:
1. Since I am a linux user I don't really need the BIOS patched for SXGA+ (I already checked it) however I would like to have clear view during boot stage and at bios setup. Is it possible to flash SXGA+ BIOS over XGA BIOS but both at the same version? Both for x61s and v.2.22. Or do I need to perform downgrade first? If downgrade is needed how should I proceed?
2. After flashing SXGA+ BIOS would it be possible to use XGA LCD without problems during boot stage and at bios setup? Or the situation would be the same as for XGA BIOS and SXGA+ LCD?
I would be grateful for information based on your experience.
Raceboy
#283 Post by Raceboy » Fri Oct 26, 2012 12:23 am
XGA LCD works perfectly with SXGA+ BIOS.
boilerplate
#284 Post by boilerplate » Fri Dec 28, 2012 12:05 pm
Apologies for reviving a somewhat stale thread
My stock x61 screen has been going out over the past year - hot spots, burn-in, etc. Having read through this thread, I'm considering a replacement with a 1400x1050 screen, but haven't been able to find an active link to the modified bios. Could anyone possibly re-upload in the name of keeping this wonderful laptop kicking?
dmdsoftware
#285 Post by dmdsoftware » Fri Dec 28, 2012 6:54 pm
boilerplate wrote:Apologies for reviving a somewhat stale thread
links still work for me:
http://www.mediafire.com/?d13q173jhtb3f ... -1.03).rar
source:
http://forum.notebookreview.com/lenovo/ ... ost6501443
X62 SXGA+ i7 5600u
Carbon X1 i5 UHD
W520 quad-i7
X131e AMD
"Think" Ultrabook i7
in storage:
X61T Touch L7500
X61T SXGA+ 8GB
X60/X60s, X61, T61, T420, X30
past:
X24, X23, X22, X21, X20, 390X
Yakumo
#286 Post by Yakumo » Mon Apr 21, 2014 10:04 am
Hi, I have an x61t with the bubble problem, and I believe the glass has cracked because of the weakness this left.
Can anyone advise on which screens would be compatible, and if I buy a plain screen, will it be possible to just swap that out, and keep the digitiser from the old setup to get everything working again?
The only alternative seems to be to remove the glass and try remove all the glue :(
