Sounds interesting.Superego wrote:VirtualBox is my preferred piece of software for VMs. It's free and runs pretty fast. There are 2 versions of VirtualBox - an open-source version and binary version. The biggest difference is that the open-source version does not have usb support, the binary version does. You can either google it or Ubuntu probably has it in Synaptic.
A warning about games: In general, VMs won't be able to run games that us OpenGL/3D acceleration. I say in general because there are some projects out there working on it but I don't know the status of them. The VM sees a virtual graphics card and not the actual hardware, and so it only provides VESA/VGA support.
"Distro" suggestion for new Linux user
crashnburn
Re:
Re: "Distro" suggestion for new Linux user
I would like to recommend ArchLinux as a good linux for learning linux, because it starts with barebones command-line utilities, but it still has a package manager, so you don't have to constantly go through the process of compiling which seems to fail like 10 or 15% of the time. you still do for some things, but that helps you learn. Also it's really fast and configurable.
note that it also helps to have a friend who knows what he's doing with linux to point out the fact that startx won't work unless you actually have xorg installed. lol
Frankenpad X31.5 (X31 casing, X32 motherboard) 1.8ghz Pentium M processor, 1gb RAM,
60gb HDD dual booting Arch GNU/Linux && Windows XP
I think it's worthwhile to share some experience...
This is was about my 4th attempt to get a TP up and running on Linux. I've experimented with Fedora, Mint and some others before... this time I got serious. It took me about 2 hours to have my Windos environment largely replicated with Ubuntu on a TP 60 from scratch.
Please keep in mind: you don't need to become a Linux nerd - in fact I don't have a clue how this really works... anyhow I have EAC up and running in WINE and my Squezebox works just fine.
Hope this helps.
-Michael
- download the ISO image and burn to CD
- start the TP with the burned CD and follow the installation dialog (I did not intend to use a dual boot setup. I felt it's not necessary since I don't play games on my TP)
- adjust the language settings to fit your needs
- 8.10 comes with OpenOffice 2.4 - use Synaptic to upgrade in any case:
- make yourself familiar with the package support using Synaptic (do not get hooked up on fancy Linux code lines to install software!)
- make sure you scan the forums and ask questions before you start installing anything - I got first class support for any of my questions (watch out for language support like in http://www.ubuntu-forum.de/ otherwise http://ubuntuforums.org/ works best)
- "manual" intervention (i.e. open a terminal and put some lines of code in a "configuration file" using an editor is necessary only if WiFi doesn't reconnect after suspend and to enable correct trackpoint support (still haven't figured out how to adjust it's sensitivity)
Hope this helps.
-Michael
Cheers, Michael
Linux distro for Thinkpad T23 in 2017
by gnutemberg » Thu Mar 30, 2017 10:23 am » in Linux Questions - 6 Replies
- 728 Views
Last post by jaspen-meyer
Tue Jun 20, 2017 2:33 pm
Thinkpad W520 screen replacement. Suggestion on after market screens.
by LoneTraveler » Thu Jun 22, 2017 3:56 pm » in ThinkPad W500/510/520 and W7x0 Series - 10 Replies
- 341 Views
Last post by LoneTraveler
Sun Jun 25, 2017 5:38 am
- 2 Replies
- 1218 Views
Last post by upgrades
Wed Feb 15, 2017 3:42 pm
Any X220 or X230 user with Panasonic battery?
by skrble » Fri Mar 31, 2017 2:09 pm » in ThinkPad X200/201/220 and X300/301 Series - 4 Replies
- 1033 Views
Last post by skrble
Sat Apr 01, 2017 2:05 pm
