To Lenovo: Still unfixed common and reproducable X300 proble
You must really be completely insane to prefer that.
Gentlemen, I am all for disagreement on Thinkpad design, etc.. it is healthy discussion, but the above comments are dangerously close to forum rules violation. Please keep the tone of this thread low key going forward, or it will be locked and you will both be warned....or worse. "Criticize the ideas, not the people".... And no, I am not insane. You obviously, true.
Ah thanks for your support (where is it?).Harryc wrote:Gentlemen, I am all for disagreement on Thinkpad design, etc.. it is healthy discussion, but the above comments are dangerously close to forum rules violation. Please keep the tone of this thread low key going forward, or it will be locked and you will both be warned....or worse. "Criticize the ideas, not the people".
Maybe I should stop posting GOOD, INTERESTING AND HELPFUL threads in this forum and go on only at Lenovos forum then.
wanker vs helpful-guy
1 : 0
X300 (6478-15G) with 3GB of RAM and builtin 3G/UMTS, running Vista Business x86-32
What's obvious is that you don't know what you're talking about. Fn and Ctrl have been in the same position on ThinkPads since the mid-90's. Nothing has changed about that.mmm wrote:- The Fn (Function blue) and Ctrl key should be the other way around. Really annoying if you're used to normal IBM-layout. It's obvious this isn't IBM design.
Jane
I'm on Twitter
I'm on Twitter
Right back at 'ya:nonny wrote:What's obvious is that you don't know what you're talking about.
http://www-01.ibm.com/software/globaliz ... ysical.jsp
sorry to have bought the x300
Ah... Selective quoting at its best.mmm wrote:Right back at 'ya:nonny wrote:What's obvious is that you don't know what you're talking about.
Here's the actual exchange:
Buh-bye!nonny wrote:What's obvious is that you don't know what you're talking about. Fn and Ctrl have been in the same position on ThinkPads since the mid-90's. Nothing has changed about that.mmm wrote:- The Fn (Function blue) and Ctrl key should be the other way around. Really annoying if you're used to normal IBM-layout. It's obvious this isn't IBM design.
Jane
I'm on Twitter
I'm on Twitter
No. The Lenovo tried to cut on costs and built a [censored] cheap ALPS Touchpad in the X300 instead of the good Synaptic. Its also a lot less responsive compared to the Synaptic Ultranavs used on the other models.bebzif wrote:Issue #2 (reset of number of scrolling lines) is due to Synaptic driver. It can be solved by installing a newer one from Synaptics website directly.
X1 Carbon Gen 2 (X1C2) what are common problems?
by dhenry » Tue May 16, 2017 6:21 pm » in ThinkPad X1/X1C - 6 Replies
- 300 Views
Last post by w0qj
Thu May 18, 2017 2:13 am
- 28 Replies
- 4684 Views
Last post by nforce4max
Sat Jun 10, 2017 10:52 pm
T60 BAD Bios flash (Still in Windows, havent rebooted)
by Sokre2000 » Mon Feb 06, 2017 5:25 am » in ThinkPad T6x Series - 8 Replies
- 1245 Views
Last post by Sokre2000
Sat Feb 11, 2017 2:16 pm
Still get a "Fan error" after replacing fan
by thinkpac » Sun Apr 02, 2017 12:44 am » in ThinkPad T6x Series - 7 Replies
- 1216 Views
Last post by thinkpac
Sun Apr 02, 2017 11:17 am
