Thinkpad T400/T500 available August 5th
mrichichdrew
well do you want 2 30" LCDs or just one? Monitors that big need a dual-link DVI which basically uses up all the bandwdith. To get another 30" LCD you'd need the advanced dock with a PCI-E card inside supporting dual link also.
In You have space for 2, 30" LCDS though? :O
SHoTTa35 wrote:well do you want 2 30" LCDs or just one? Monitors that big need a dual-link DVI which basically uses up all the bandwdith. To get another 30" LCD you'd need the advanced dock with a PCI-E card inside supporting dual link also.
I would love 2 30" screens but I don't want to hassle with a Advanced dock and PCI-E card at home and at work. So I want to be able to use the biggest monitors possible with the Advanced MIni Dock. Currently I have the 24" connected to the DVI and the 20" connected to the VGA. I wonder with the T400 if it will be different?
well probably not. You can use 1 30" with the T60 now but not even with a desktop can you turn 2 30" with just 1 video card. EVen though some PCI-E cards have 2 DVI ports on them you can't run 2 dual link LCDs simulataneously. Not even with the latest nVidia cards can you do that and that's a $400 card. There just enough enough bandwidth to manage 2 LCDs at those resolutions at the sametime.
As i said though, even a T60 today can run a 30" LCD with the advanced MINI dock. NO extra card needed.
I count 11 different Nvidia cards that support 2 dual-link DVI ports.SHoTTa35 wrote:well probably not. You can use 1 30" with the T60 now but not even with a desktop can you turn 2 30" with just 1 video card. EVen though some PCI-E cards have 2 DVI ports on them you can't run 2 dual link LCDs simulataneously. Not even with the latest nVidia cards can you do that and that's a $400 card. There just enough enough bandwidth to manage 2 LCDs at those resolutions at the sametime.
http://www.nvidia.com/object/IO_11761.html
They start under $200.
Andrew Wolfe
When using an advanced dock with a seperate video card do you have to reboot everytime you dock and undock or can you just hibernate to dock and undock? Are the advanced docks with seperate video cards a hassle?awolfe63 wrote:I count 11 different Nvidia cards that support 2 dual-link DVI ports.SHoTTa35 wrote:well probably not. You can use 1 30" with the T60 now but not even with a desktop can you turn 2 30" with just 1 video card. EVen though some PCI-E cards have 2 DVI ports on them you can't run 2 dual link LCDs simulataneously. Not even with the latest nVidia cards can you do that and that's a $400 card. There just enough enough bandwidth to manage 2 LCDs at those resolutions at the sametime.
yea sounds like a hassle. I will stick with my mini dock. does anyone know the size of 2 external monitors I can use. 1 dvi and 1 vga.awolfe63 wrote:When I tried it with my T42 (ATI internal graphics), I had to reboot if I used an Nvidia graphics card and not if I used an ATI card - but I'm not sure I ever got it quite figured out right. I assume the answer is OS specific as well.
What size monitor in inches works best with native 1920 x 1200 resolution? I really appreciate the help. I prefer Dell monitors if that makes any difference.awolfe63 wrote:You can use 1920x1200 on each. The VGA one needs a good cable and works better with newer (T6x) thinkpads than older ones. Probably will be fine with T400/T500.
Sadly, if it was not a mistake, I could *almost* justify going to widescreen. This is one of those confusing things going on, there was once a trend of higher and higher resolution, now it's reversing and no one seems to notice or care. It the industry is determined that "widescreen is the path to enlightenment", then at least give me the same vertical resolution so I'm not losing pixels.mrichichdrew wrote:The demo we've seen is a 14.1", 1440x900, LED backlit screen. I assume 1680x1050 is a mistake.
computerpro3
This is incorrect. Even my $100 used ATI x1900xtx has my 2 30in monitors running at full 2560x1600 resolution.SHoTTa35 wrote:well probably not. You can use 1 30" with the T60 now but not even with a desktop can you turn 2 30" with just 1 video card. EVen though some PCI-E cards have 2 DVI ports on them you can't run 2 dual link LCDs simulataneously. Not even with the latest nVidia cards can you do that and that's a $400 card. There just enough enough bandwidth to manage 2 LCDs at those resolutions at the sametime.
dickeywang
I understand how you feel, and I am no fan of the wide screen either. Technically though, it is more difficult to provide the same vertical resolution on a 14.1" wide screen than to do so on a 14.1" 4:3 screen. The wide screen format is smaller in area as well as in height, so unless the manufacturer put into a higher dpi, which is likely to cost more and usually manufacturers would like to avoid, you will see a lower vertical resolution on the wide screen.laowai wrote:Sadly, if it was not a mistake, I could *almost* justify going to widescreen. This is one of those confusing things going on, there was once a trend of higher and higher resolution, now it's reversing and no one seems to notice or care. It the industry is determined that "widescreen is the path to enlightenment", then at least give me the same vertical resolution so I'm not losing pixels.mrichichdrew wrote:The demo we've seen is a 14.1", 1440x900, LED backlit screen. I assume 1680x1050 is a mistake.
It's all about the cost.
T60 (2007-66U): upgraded to C2D T7400, 2GB DDR2-667, Hitachi Travelstar 5k250, 14" SXGA+, ATI Mobility Radeon X1400 (sold).
T61 (8891-CTO): C2D T7300, 4GB DDR2-667, Hitachi Travelstar 5k250, 14" SXGA+, Nvidia Quadro FX 570M (128MB).
ThinkPad X1 Carbon (5th GEN) i5 7200U vs i7 7500U which to buy?
by HouseSoul » Wed Jun 14, 2017 1:37 am » in ThinkPad X1/X1C - 3 Replies
- 253 Views
Last post by w0qj
Fri Jun 16, 2017 3:19 am
x1 4th Generation with Windows 7 or 5th generation with Windows 10 - which to buy?
by mirc » Wed Apr 19, 2017 11:50 am » in ThinkPad X1/X1C - 5 Replies
- 553 Views
Last post by wpyh
Sat Apr 29, 2017 10:32 pm
X1 Carbon (5th gen, 2017) : 8gb Ram or 16gb Ram , i5 or i7
by asterinex » Tue Apr 25, 2017 4:12 am » in ThinkPad X1/X1C - 26 Replies
- 1956 Views
Last post by w0qj
Sat Apr 29, 2017 11:22 am
WTB X1 Carbon 5th Gen (Silver)
by micrex22 » Wed Jun 14, 2017 2:00 pm » in Marketplace - Forum Members only - 1 Replies
- 123 Views
Fri Jun 16, 2017 6:18 pm
Users browsing this forum: BigT0ny and 2 guests
