Changing Battery Charge Thresholds in IBM X32
proaudioguy
#31 Post by proaudioguy » Sun Aug 10, 2008 12:50 am
What is odd to me is that the OLDER of the 2 batteries has the menu item. I don't know what to think of that. Is there a way to update the firmware of the BATTERY?
X32UseR
#32 Post by X32UseR » Sun Aug 10, 2008 2:27 am
festerbybike... what is Your Battery FRu number?
___________________________________
X32 (1,8Ghz 1,5Gb), X41 (1,5 2Gb), R60 (sxga, 1,83Ghz, X1400
Past: T23 X40 T40 T41 T42 T43p
fasterbybike
#33 Post by fasterbybike » Sun Aug 10, 2008 6:16 am
X32UseR wrote:what is Your Battery FRu number?
FRU 92P1096 P/N 92P1095
W520, X301, T500, (past X61( SXGA+),T42P,SL500, A31, R52, T42,X32(SXGA+), T40P,A31P, A21P, 770Z)
Democracy is not something we have, Democracy is something we DO.
X32UseR
#34 Post by X32UseR » Sun Aug 10, 2008 10:25 am
hmm.. FRU 92P1096 the same as mine.. and the same problem..
proaudioguy... If I understand You properly You have 2 batteries for x32.. and one of them working with custom battery charge Threshold and the other not?
Yes?
proaudioguy
#35 Post by proaudioguy » Sun Aug 10, 2008 12:33 pm
X32UseR wrote:hmm.. FRU 92P1096 the same as mine.. and the same problem..
Yes?
Yes, CORRECT, as I've said twice.
X32UseR
#36 Post by X32UseR » Sun Aug 10, 2008 1:40 pm
so.. we know now that the reason of this situation is the version of the battery...
what FRU working properly?
X32UseR
fasterbybike
#37 Post by fasterbybike » Wed Aug 13, 2008 6:25 pm
Here's some more information - which confuses the picture even more :o
I removed the Battery Maximiser utility and installed the Thinkpad Power Manager software on my T42P. Surprisingly it works so the firmware must be compatible, even though it is not listed on the download page.
The Power Manager let me adjust the charging thresholds on my battery (genuine IBM FRU 92P1087). I then swapped batteries, to a generic non OEM one manufactured by BND, and the charging threshholds still work.
So, at least for the T42P, the functionality does not seem to be tied to battery as it is unlikely that BND would have access to any Thinkpad specific battery firmware.
HTH
