^.^ Got my T22 ^.^ Got some questions.
#31 Post by RealBlackStuff » Sat Aug 09, 2008 9:43 pm
Have you upgraded to 2x 256MB RAM as suggested earlier?
Leedsboi86
#32 Post by Leedsboi86 » Sat Aug 09, 2008 11:23 pm
Not yet I haven't had the chance to do it.
Not even sure what boards to buy I know it has 256mb already
sarbin
#33 Post by sarbin » Sun Aug 10, 2008 4:14 am
the original ibm part number is: 33L3069. it is pc100 memory in sodimm format. you *may* be able to use a pc133 sodimm, but i don't know that for certain so someone else will need to confirm.
here's an appropriate part on ebay, for reference:
http://cgi.ebay.com/256MB-PC100-SO-DIMM ... 0268374500
adding the extra ram will help xp to swap-to-disk less, in turn that will help to reduce the heat you're feeling. the hard disk is under your left wrist in the t22. and, it will speed up the system overall.
Current: X1CT-G3 / Helix-G1 / X220 / T61p / T60p / X301 / X200T / Yoga 3 Pro
Support: T520 / T510 / T420 / T400 / R400 / T61 / Yoga 2 Pro / Yoga 13
Hall of Fame: A31p --- Retired: T43 / T30 / T22 / 600X / 380XD
Leedsboi86
#34 Post by Leedsboi86 » Sun Aug 10, 2008 5:34 am
Hiya
Yea thats where I'm feeling the Heat.
left side top corner basically near the power cord bit
sarbin
#35 Post by sarbin » Sun Aug 10, 2008 5:45 am
left upper corner is where the cpu assembly resides. under the left palm rest is the hdd. in between is the pcmcia bay.
the hardware maintenance manual is a wealth of info:
ftp://ftp.software.ibm.com/pc/pccbbs/mo ... 2p9631.pdf
:wink:
#36 Post by RealBlackStuff » Sun Aug 10, 2008 8:19 am
What is the exact TYPE of your laptop?
On the bottom is a big IBM label. It has a 7-character code, followed by the serial number.
It looks like TYPE 2647-4CS
It may have had a smaller CPU originally, and they did not put in the larger CPU fan when they souped up the CPU.
I'd still say your T22 is overheating at the CPU.
Take the keyboard off and show us a picture of the CPU cooler.
sarbin
#37 Post by sarbin » Sun Aug 10, 2008 8:32 am
the max cpu in the t22 was a 1ghz, i believe. the fan unit was different for the 900 vs 1000?
when i had temperature issues with my 1ghz t22, it was determined to be related to hdd heat production. the original 32gb hdd in it was 12.7mm height, which left no room above the drive for airflow. a design flaw, imho. after the hdd began to fail, i replaced it with a newer, 9.5mm drive and that little 3mm of empty space above the drive was plenty to maintain a much better cooling airflow. the machine is now my mother's and we've never had issues since.
i wonder if the op's 20gb hdd is the original and if it's a 12.7mm unit. and if so, if that is contributing to his heat issue.
Leedsboi86
#38 Post by Leedsboi86 » Sun Aug 10, 2008 8:34 am
So good thing I ordered a cooling station then?
sarbin
#39 Post by sarbin » Sun Aug 10, 2008 10:17 am
possibly.
without knowing whether your hdd is 12.7mm height, i wouldn't discount the fan and dust accumulation, as RBS mentioned, as sources of extra heat. i consider opening up my t'pads twice a year to check things out just part of regular maintenance. all pcs get dusty inside, but it's more problematic in laptops just because there's far less room for airflow to begin with.
Leedsboi86
#40 Post by Leedsboi86 » Sun Aug 10, 2008 10:20 am
I have someone coming out to clean the fan next week
sarbin
#41 Post by sarbin » Sun Aug 10, 2008 10:31 am
just so you know, a pretty good job of dust-cleanout can be done with only the keyboard removed. have a look at the hmm link i posted if you want to see how to remove the keyboard. it's pretty simple.
Purcy
#42 Post by Purcy » Sun Aug 10, 2008 2:59 pm
I ran the original 20GB HD in my T22 for 5 months before upgrading to an 80GB and it never once got really hot, not above 60c at least. It is good the fan area is being cleaned, you never know about the previous conditions of use sometimes.
sarbin
#43 Post by sarbin » Sun Aug 10, 2008 3:06 pm
your 80gb was a 9.5mm drive, right? that 3mm makes a big difference.
60*C is ok for the cpu, but most hdd's specify less for the operating range. i'm sure that heat played a major role in the premature failure of my 32gb hdd.
Purcy
#44 Post by Purcy » Sun Aug 10, 2008 5:39 pm
sarbin wrote:your 80gb was a 9.5mm drive, right? that 3mm makes a big difference.
Well, I was actually speaking about my original 20GB HD that came stock in the T22, I ran that for many months doing video editing and the HD would get up to 57-58c, until the fan kicked in and brought it down.
