T60 vs T61
crazyfrog
#31 Post by crazyfrog » Tue Sep 02, 2008 9:15 am
ajkula66 wrote:I'd take 1GB less in RAM capacity in exchange for a FlexView LCD any day of the week...
Take a look at the front, left side and right side views of a T61 with 14.1-inch standard screen.
Technically, it is possible to have a hybrid T60p with 8GB RAM, 256(128?)MB nVIDIA Quadro FX 570M and more importantly a FlexView LCD.
Core 2 Duo T7600, 3GB DDR2-667 RAM, Main 7K320 320GB 7200RPM + Ultrabay 320GB 5400RPM, ATI FireGL V5250, 15" IPS UXGA, DVDRW, Bluetooth, Atheros ABGN, NMB Keyboard, Fingerprint, Win7 Pro X86 + Vista 64-bit SP2, Advanced Dock.
YeOldeStonecat
#32 Post by YeOldeStonecat » Tue Sep 02, 2008 1:33 pm
Still shopping....just the t60p w/flex that I find on eBay are too pricey.
I found a decent T61 on Lenovo's factory outlet...
http://stores.channeladvisor.com/Lenovo ... efurbished
14.1" screen, states 1440x900 resolution.
May jump on it.
#33 Post by dr_st » Tue Sep 02, 2008 2:46 pm
YeOldeStonecat wrote:Still shopping....just the t60p w/flex that I find on eBay are too pricey.
What about T60 non-P with 15" SXGA+ Flexview?
#34 Post by ajkula66 » Tue Sep 02, 2008 5:32 pm
@crazyfrog:
Yep, you're absolutely correct and it's already been done by a forum member here...T61p mobo in a T60p frame. The only thing which would stop me from doing it if I still had a T60p would be nVidia card that I'm really not keen on...
This is a very sound piece of advice. I've owned several of these machines and they are nice units that can sometimes be sourced cheap on fleabay, with all the usual risks involved.
YeOldeStonecat
#35 Post by YeOldeStonecat » Wed Sep 03, 2008 6:08 am
Been looking hard...I just cannot seem to find them for under a grand. :(
#36 Post by ajkula66 » Wed Sep 03, 2008 6:12 am
Then you're not looking properly, or setting up the correct filters...agreed, it's not like there's 50 of these on offer, but they can be sourced.
FYI, here in the Marketplace they change hands for way less than that, and forum is usually more expensive than eBay because of the comfort zone and safety net it provides...
YeOldeStonecat
#37 Post by YeOldeStonecat » Thu Sep 04, 2008 1:54 pm
ajkula66 wrote:agreed, it's not like there's 50 of these on offer, but they can be sourced.
Just won an auction on one.
200787U
T60p
2.16 C2D
14.1" sxga+ tft
ATI FireGL Mobile 256
100 gig SATA 7,200rpm
Now to get PayPal squared away, so I can get it on my way.
crazyfrog
#38 Post by crazyfrog » Fri Sep 05, 2008 6:02 am
Here is a T60p with UXGA IPS screen on ebay UK.
Unfortunately, it seems the screen has two blue pressure marks right above the Windows logo, though the seller was reluctant to admit (It much be touched by an alien who can leave blue finger prints on screen). Besides, the original 100GB 7200rpm seems to be replaced with a 120GB 5400rpm one. Otherwise, it is a good machine.
#39 Post by ajkula66 » Fri Sep 05, 2008 11:37 am
@ YeOldeStonecat:
Sounds like a fine machine, but no FlexView there...
YeOldeStonecat
#40 Post by YeOldeStonecat » Mon Sep 08, 2008 11:15 am
ajkula66 wrote:@ YeOldeStonecat:
Yeah, research on the boards here..seems the FlexView only comes 15". I really do like the 14" chassis...so it was a close call.
Side by side with my old T42...she's much thinner, and lighter.
I found the model I listed above on fleabay..won the auction for 670 dollars, US. Pretty good price I think.
Laptop arrived today, appearance is like it's brand spanking new, even smells new.
Pleasant surprise.
Only thing I don't like is the battery sticks out in the back.
Very pleased with it so far. Sitting here now wiping the hard drive clean, installing the dreaded Vista (must learn Vista)...will dual boot with PCLinux or Ubuntu, and possibly triple boot with Server 2008.
Davemci
#41 Post by Davemci » Tue Sep 09, 2008 10:06 am
YeOldeStonecat wrote: I found the model I listed above on fleabay..won the auction for 670 dollars, US. Pretty good price I think.
Pleasant surprise.
I don't like the battery sticking out the back either. I'm thinking about buying a 6 cell battery. I don't think they stick out and I really don't use the battery much. I have a DC adapter and along with the AC adapter I can usually find a power source.
Nice price for a like new laptop. I was surprised at how fast the keys get shinny.
X220, 600X, Edge 13, T22, T23, 701C, 560Z, T60p, T43, 240Z,....
rbena
#42 Post by rbena » Tue Sep 09, 2008 6:05 pm
YeOldeStonecat wrote:Side by side with my old T42...she's much thinner, and lighter.
... now wiping the hard drive clean, installing the dreaded Vista (must learn Vista)...will dual boot with PCLinux or Ubuntu, and possibly triple boot with Server 2008.
Would a 32 or 64 bit version of XP be an option for your system?
T42__1.8 / 160GB-5400 / 1GB / ATI7500
T42__1.5 / 160GB-5400 / 1.2GB / ATI7500
600e__PII-400 / 40G-5400 /0.5GB
YeOldeStonecat
#43 Post by YeOldeStonecat » Tue Sep 09, 2008 6:15 pm
rbena wrote: Would a 32 or 64 bit version of XP be an option for your system?
It would be. Came with the deployed Lenovo version of XPp. But I have to start getting familiar with Vista....like it or not. So I wiped the drive, clean install of Vista 32 Ultimate. I toyed with putting on Vista 64 (MSDN subscription)...but the slight chance of some lack of driver support of it..on top of, the T60s RAM limitations..I had no reason to go 64.
pae77
#44 Post by pae77 » Wed Sep 10, 2008 4:50 pm
Just a fyi re driver support. There are x64 versions of most drivers. I haven't found that to be a problem. The problem I have found is with Vista x64's insistence on "signed" drivers. This a real pain in the butt and there is no good reason for it, imo. Fortunately, there is a simple work around if you want to use unsigned drivers on Vista x64 and that is a freeware program called ReadyDriverPlus which makes the machine automatically boot into a mode that disables the signed driver requirement. So with that I'm able to run programs like RMClock which don't have a signed driver on Vx64.
YeOldeStonecat
#45 Post by YeOldeStonecat » Mon Sep 22, 2008 2:26 pm
Finally ordered RAM in for the T60p 2007 87U I received a few weeks ago. Machine has been running wonderfully. It arrived with 2 gigs (pair of 1 gigers)...I ordered a pair of Crucial 2 gig sticks.
Aware of the T60p limited 3 gigs to the OS, and aware of 32 bit Vista.
Upon bootup, Vista showed 4 gigs in System properties. A full 4.00GB.
Task Manager showing 3069 avail to the OS. But I wasn't expecting Vista system properties to show 4. Does some IBM driver I install tweak that?
msb0b
#46 Post by msb0b » Mon Sep 22, 2008 6:16 pm
Vista SP1 reports the installed memory on the system properties page. Task manager's performance tab reports the usable memory available to Windows. Both are right.
Microsoft made this change in SP1 because many people complained because their 32-bit windows don't show 4 gigs.
See KB946003 for more details.
YeOldeStonecat
#47 Post by YeOldeStonecat » Tue Sep 23, 2008 5:53 am
msb0b wrote: Microsoft made this change in SP1 because many people complained because their 32-bit windows don't show 4 gigs.
Ahh...didn't know Veeesta SP1 was supposed to do that. Although, on one of my homebuilt rigs on a Gibabyte 965 motherboard, it shows the expected 3.2something gigs. (also has a pair of 2 gig chips). I'll have to try to take note as I SP1 some computers over time.
