is Vista worth it?
K0LO
#31 Post by K0LO » Sun Nov 16, 2008 12:07 pm
This is the first explanation that I've heard about this issue that makes sense: http://thevistaforums.com/index.php?aut ... rticle=138. I applied the fix to both of my Vista PCs a couple of months ago and have not had any problems whatsoever with folder view settings ever since.
Mark
My ex: X41T (2005 - 2009)
jdhurst
#32 Post by jdhurst » Sun Nov 16, 2008 12:42 pm
Mark - that is the patch they sent me. I just looked at my registry fix from Microsoft and it is the same as the link you provided.
... JDH
