Looks like my new W500 has a cooling problem.
I'd be happy to try and replicate the problem on my W500. Could you let me know what games/utils (and versions) you used to push the cores as well as the software used to log the temperature, as well as any other considerations that you think are important in replicating your results.awolfe63 wrote:<snip!>
I'm hoping that someone else will get a machine and run some tests for comparison. Then I can decide what to do next.
The only caveat is that I don't have a compatible dock at the moment.
jms
ex-600x ex-T40 W500 SL500
I use MOBmeter to track frequency and temperature. I'm pretty sure it only works under XP. There must be other tools (CPU-Z?) that will work under vista.
I ran one copy of Prime95 and one of cpu burn-in v1.01 to get the load to 100%. Then I ran a game (Civilization IV) or 3Dmark06 to get the graphics going. That now peaks at about 86C stand alone and 91C in the dock.
Andrew Wolfe
Now just to refresh my memory ..... Is the discrete ATI 3650 256Mb GPU found in the T500 faster and better for 3D gaming than the ATI FireGL 5700 512 Mb GPU found in the W500 (with all other things being equal)?
They should be the same. It used to be that the Radeon chips used a "performance" driver that was 5-15% faster than the "ISV" driver that would be more stable that shipped with FireGL. The XP drivers are exactly the same for both chips right now. Probably the drivers have simply become stable enough that it is not worth doing two versions.
My 3dMark scores on the 5700 are about 5% slower than the published numbers on the 3650. I think that is because I used XP and they used Vista. The Vista drivers must be better tuned.
Andrew Wolfe
Screen Looks Weird After Upgrading
by NikkoCharger » Wed Dec 28, 2016 10:42 am » in ThinkPad T400/410/420 and T500/510/520 Series - 2 Replies
- 843 Views
Last post by NikkoCharger
Wed Dec 28, 2016 11:48 am
Just a new Cooling Mod for the T43 type 2668
by cluca_alex » Tue Feb 28, 2017 6:31 am » in ThinkPad T4x Series - 6 Replies
- 1323 Views
Mon Mar 06, 2017 5:47 pm
- 2 Replies
- 1396 Views
Tue Feb 28, 2017 4:30 pm
High efficiency GRAPHENE assisted cooling
by PurpleMelbourne » Thu Apr 06, 2017 11:09 pm » in ThinkPad T6x Series - 17 Replies
- 1429 Views
Last post by PurpleMelbourne
Fri May 05, 2017 2:07 am
