two-finger scrolling on T43 under XP?
MythicalForce
Excellent program, but please adding swiping options. I could not get the modded acer driver two/three finger gestures to work w/ the two finger scroll program. It seems the two finger scroll program overpowers the swiping motions so it will not complete the move.
I believe someone was able to do this. How do I get the swiping motions in the modded acer driver to work w/ the two finger scroll program? I'm using a Latitude X1 w/ a 6.3 synaptics pad.
FYI, the two finger program did not work on my HP 2133 w/ 6.5 synaptics pad.
Is it possible to get 2-finger-scrolling to work on a T400?
I currently have installed Lenovo UltraNav driver v9.1.3.6 on Windows Vista.
TwoFingerScroll.exe pops up a windows saying that "support for multiple fingers is already enabled but the driver still doesn't report multiple fingers"
Any solution to this?
Re: two-finger scrolling on T43 under XP?
anyone try this in the 64-bit version of Windows 7 Beta 1? Im planning on making it my main OS, but wont do it unless this works :/
ThinkPad T43, Vista Ultimate SP1 x86
Synaptics drivers 9.1.3.7, October 6th, 2008
When I run it, it just says this:
Synaptics kernel driver registry keys missing. Reinstall drivers.
I just installed these drivers.
ThinkPad 560X
ThinkPad T23
ThinkPad T43
ThinkPad T23
ThinkPad T43
Xenomorph, did you reboot after the driver installation? I'm using the same version on the exact same Vista version and the tool works.
ThinkPad™ X201 / AFFS-120
I've rebooted several times since they were installed.yak wrote:Xenomorph, did you reboot after the driver installation? I'm using the same version on the exact same Vista version and the tool works.
I *just* put Vista on this a few days ago, and the Synaptics drivers a little after that. The system had been rebooted a few times before I even read about the the 2-finger app.
Should I just to re-install the drivers and reboot? I was thinking maybe I missed some step or over-looked something in the thread to get it to work.
ThinkPad 560X
ThinkPad T23
ThinkPad T43
ThinkPad T23
ThinkPad T43
Weird.
The error message you got is displayed when the following registry key cannot be found:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\SynTP\Parameters
Could you please start regedit (press Start, type regedit, press Enter) and check if it's there? The SynTP key should definitely be there if the driver is installed. Maybe there's no Parameters key inside it for some reason. If you have SynTP, tell me what's inside it.
Also, try starting the tool with admin rights (right click on the exe, Run As Administrator).
Admin rights seemed to be the issue. I ran as Admin and it told me support was now added, and to reboot.yak wrote:Weird.
Ok, this seems pretty neat.
Way more accurate than the virtual scrolling junk.
Two questions:
- Why can't the virtual scrolling more emulate a real mouse wheel? The acceleration is always so..."off".
- When I have one finger down, and place another down to scroll, when I remove the second finger, the mouse cursor shoots WAY off to the side - like it was centered on the second finger and was quickly moving to the left where my first finger was.
Anyway to make the cursor "hold still" when a second finger is removed????
ThinkPad 560X
ThinkPad T23
ThinkPad T43
ThinkPad T23
ThinkPad T43
Two Finger Scrolling Program on xps m1330 with V6.3
The two-finger scrolling program looks awesome, but I'm having trouble getting it to work. I'd appreciate help if possible. =)
I'm getting the following error:
"Driver support for multiple fingers is already enabled but the driver doesn't report multiple fingers. Either you haven't restarted the system yet or your TouchPad doesn't support multiple fingers.
I'm using the following configuration:
Dell XPS m1330; Vista x32
Synaptics Touchpad V6.3
"Modded" Synaptics Driver 10.2.4
It looks like this configuration should work, given the comments in this thread.
Any suggestions? If you want more infos, let me know.
Thanks,
GS
Thanks,
GS
first message on this forum.
thanks for this program it works great !
It is really a clever feature.
THX.
THX.
I just installed Ubuntu 9.04 on my T43.
I was surprised when absolutely all functions of the UltraNav stuff worked.
Middle-click with the TrackPoint worked out-of-the-box.
And Two-Finger-Scrolling worked as well without having to do anything!
I'm so use to using TwoFingerScrolling under Windows, I did it under Ubuntu without thinking, and the window started scrolling. I realized that is the system default with Ubuntu.
ThinkPad 560X
ThinkPad T23
ThinkPad T43
ThinkPad T23
ThinkPad T43
Started a new, more genereal thread on the topic at this thread following the fact that a driver from HP unlocks multitouch on many machines (other than HP)
W530 FHD - 32GB Ram - K2000m - >1TBSSD |
Modded T61| Scarlet Saffire 6i6-Phillips IPS | Win10x64
daybreak broke me loose and brought me back...
No Trackpoint scrolling in Virtual Desktops under Windows 7
by axur-delmeria » Thu Mar 30, 2017 7:27 am » in Windows 7 - 1 Replies
- 715 Views
Thu Mar 30, 2017 10:53 am
- 3 Replies
- 1374 Views
Last post by TPFanatic
Wed Feb 22, 2017 8:13 pm
- 4 Replies
- 437 Views
Thu Mar 09, 2017 3:55 pm
remove and clean under the trackpoint mouse buttons
by louisJ » Fri Feb 10, 2017 1:51 pm » in ThinkPad T430/T530 and later Series - 4 Replies
- 450 Views
Last post by louisJ
Fri Feb 10, 2017 3:15 pm
