two-finger scrolling on T43 under XP?
Combining the hacked asus drivers and the program works really well. (I turned down the max distance allowed on the double finger tap and now it works a little better).
Here is my trackpad gesture setup:
Double-finger down\up : scroll down up
Double-finger left\right: go back\forward in firefox, my computer, etc
Triple finger swipe down: switch to next virtual desktop (spaces-like)
Triple finger swipe up: expose-like window manager (called switcher)
Tap top left of the trackpad: cycles through tabs of firefox, pidgin, or digsby
Tap top-right: refreshes current page
Tap bottom-left: closes current tab
Tap bottom-right: opens new tab
Double tap with two fingers: right-button
Triple tap with three fingers: middle-button
Makes navigation without a mouse A LOT easier. Thanks again yak and all others that put support in this thread.
I tryed uninstalling my current drivers and installing these ones it worked great! And now your program works as well. Thank you so much Yak and everyone in involved in this.yak wrote:If it still doesn't work, try installing the modded driver from this page (uninstall previous drivers first):
http://www.laptopvideo2go.com/forum/ind ... 17890&st=0
Cheers
Nice to know you guys got it working.
Next release is coming soon with more fine tunning options and a three finger tapping support.
I see on the google code page that we got quite a lot downloads, almost 200 of the last version, 290 in total. The word is being spread I presume...
ThinkPad™ X201 / AFFS-120
usernotabuser
Version 1.0.4 released. Download
* scroll acceleration can now be disabled
* scroll speed setting has been added
* three finger tap support has been added
* detection of driver support for multiple fingers improved
@usernotabuser
Currently I'm not using Vista at all so I don't have a way to test it. It's hard to help you if you didn't event take the time to tell us what kind of error you get. Remember, if you report a bug, always provide as much relevant information as you can.
@Zender
Good job. Let me know when you're done, I'll add the horizontal scrolling then.
@usernotabuser
@Zender
im currently using vista x86 (32 bit) and, on my dell m1330, it works flawlessly. Must be the 64 bit thats causing problems
awesome job on the triple tap. Is it possible to differentiate between holding a finger down and then tapping with a 2nd finger vs tapping with two at once? My trackpad is really small so its somewhat difficult to triple tap- I was thinking about 1+1finger tap for right click and double finger tap for middle mouse button.
usernotabuser
Yea, I didn't report information because I didn't know that it even had ANY chance at all of it working in vista. Don't get me wrong, I wasn't complaining, just curious if I could also enjoy the wonderfulness of your awesome work.
Anyway FYI, error I get instantly with the newest version is as follows:
Class not registered, Class ID:
{9C042297-D1CD-4F0D-B1AB-9F48AD6A6DFF}.
Simple is as simple does.
@usernotabuser
Sorry if I sounded a bit harsh. The error indicates that the Synaptics COM library is not installed/registered in your system. This is normally done by the Synaptics driver installer. You may want to try to uninstall your current one and install the moded driver linked to some posts above.
@renova
Since there was a flaw in the tapping code I fixed shortly after releasing 1.0.4, there is another release already (1.0.5) which fixes this and adds what you've requested:
* separate one + one tapping
* separate two + one tapping
There are totally 4 different tap gestures now, each can be configured separately.
Download
@renova
Download
haha yak, youre a godly coder!
Is it possible to stop jumping? Lets say I have my index finger down and then try to tap with my middle finger, a lot of the times it wants to jump to the location of the last finger that was just placed.
It seems like it might not be fixable - is there a string that doesnt allow mouse movement after the first finger is set down (doesnt move the pointer to the position of the second or third finger that is put down later), but still detects multiple fingers for tapping or swiping?
Pulling off flawless one + one finger tapping is somewhat difficult and two + one is almost impossible for me. Might be my trackpad, so let me know if yours works with ease.
Also, another request\question: is it possible to add a per-program configure setting that lets you set specific settings in specific programs? Such as scroll mode (you already have this implemented, just a little hidden), what tapping does, etc. OS X has a similar program to do this, called multi-clutch:
http://blog.thebartels.de/2008/04/20/mu ... ther-apps/
And in the future will you implement features such as: two or three finger swipe gestures (two\three back and forward allows you to go back and forward in the browser, etc). I know these can be done with the hacked driver, but I guess what I am ultimately asking is if, one day, you will create a full blown package that will not need any synaptics drivers at all?
With all the fuss and news about macbooks getting multitouch gestures and firefox 3.1 adding multitouch gestures for macbooks, I think you came up with a pretty significant creation here, yak.
I can (with the hacked driver and your tool) basically do all of the gestures the macbook can do (not pinching, yet, but doesn't seem all that useful anyways). Although the twisting to switch tabs sounds pretty sexy.
I currently have two finger swipes left\right to go back and forth, although it can be tricky at times (might scroll down\up first) and is probably best suited for three finger swipes and horizontal scrolling left for two finger swipes. Could you enable three finger swipes for left\right to switch tabs or go back\forward perhaps? - there isn't an option to do triple finger left and right swipes in the hacked drivers
http://mozillalinks.org/wp/2008/10/expe ... -mac-os-x/
I know I have a lot of requests\suggestions, let me know if I am becoming an annoyance!
Thanks again, Yak
If you want to go widely public when you feel your program is finished with all the features you have planned, let me know. I am good at writing up detailed instructions and spreading the news to large tech blogging sites, although they may not be needed if you do an all-in-one
Here's a guide I wrote up on getting double-finger\single finger scrolling to work in a hackintosh on any pc laptop (I couldn't get double-finger to work on my trackpad, but I got single finger scrolling to work - using the flat part of my single finger to scroll and the tip of it to move the mouse):
http://forum.insanelymac.com/index.php?showtopic=88811
Three-finger swipes left and right go back a page and forward, respectively, while up and down go to the top and bottom of the current page; twists switch tabs, in the direction you spin; and pinches zoom in and out.
Thanks again, Yak
One thing I noticed is the difference between my ThinkPad T41 and the T60 I have now. On a T41, when I placed one finger on the pad and then the other, the cursor moved significantly. This doesn't happen on a T60. The cursor moves only slightly if at all. This was mentioned earlier by Zender I think. Both machines were using the same driver version so the difference lies in the TouchPad itself. At the same time the old TouchPad reported a lot larger pressure values when multiple fingers were on it (which allowed the first version of the Python script to work) while this one does not.
With the T60, tapping both 1+1 and 2+1 is fairly easy and works almost always. It would probably be much harder on a T41 like TouchPad, which you (renova) may have. You could increase the max distance setting maybe?
Making all the settings application specific and doing a proper configuration dialogs for this is definitely a good idea. Yes, something like this MultiClutch for macs. I would also like to add new functions that can be assigned to a tap, especially running an external program. Not sure how to go about switching tabs in Firefox for example. Hmm.
Swipes are actually quite easy to implement. I may add it some day, the ones from the driver do a fairly good job for me thou. Looking at the TouchPad in my T60 I know why there aren't 3-finger left/right swipes, there's just no space for them.
For going back/forward I use the dedicated keys that ThinkPads have near the cursor keys. If you want to mix two finger scrolling and two finger swipes I might add some code not to trigger the scroll if the fingers are moved horizontally.
I'll keep in mind your notes about spreading the news. Thanks. I think we still need to do some work before we go there.
The keyboard shortcut to go to the next tab is CTRL+PG Down and previous is CTRL+PG Up:yak wrote:One thing I noticed is the difference between my ThinkPad T41 and the T60 I have now. On a T41, when I placed one finger on the pad and then the other, the cursor moved significantly. This doesn't happen on a T60. The cursor moves only slightly if at all. This was mentioned earlier by Zender I think. Both machines were using the same driver version so the difference lies in the TouchPad itself. At the same time the old TouchPad reported a lot larger pressure values when multiple fingers were on it (which allowed the first version of the Python script to work) while this one does not.
http://support.mozilla.com/en-US/kb/Keyboard+shortcuts
You could also allow the user to input their own keyboard presses per gesture action
Yea there isnt much room on my trackpad for three finger left and right but it is doable for smaller tasks like back\forward or next\previous tab.
Ill try to increase distance and see how it plays out.
Hey guys,
I am new here and first of all I want to thank you all for putting the effort in, its really amazing what you have accomplished so far.
Anyways, now to my technical problems. I have to admit that I don't have a Thinkpad but rather an Acer 5920g, but I also have a synaptics touchpad and I would love to get this application to work.
So at first I tried that python code, but I i think I knew too little to get it to work and didnt understand what i was doing or how to follow the instructions. So I downloaded yak's exe file and installed the modified driver 10.2.4. So the application told me that it enabled the software after a restart. So I did that but when I now start the application I get the error message that the driver support is enabled, but the driver doesnt report multiple fingers.
I really dont know what to do. I tried the 10.1.8 drivers and now the modified ones, restarted 20 times and reinstalled the drivers a couple times too. The modified driver also doesnt allow me to use the reported 2-3 finger gestures which are now implemented, the only feature i get is that circlemotion scroll thing, which i dont find very helpful after all.
Is that a lost cause or does anybody has any advise for me?
thanks in advance,
keep up the awesome work
thanks in advance,
If you open the mouse control panel and go to the synaptics tab, what TouchPad version is displayed there?
@forg1vr
No no, the 10.2.4 is the driver version. I was asking for the TouchPad firmware version. Look at this screenshot. I've found it using google so don't pay attention to the markings. You see two versions there. At the top, the driver version and below in the list another one. This is the version of the firmware found inside the TouchPad itself.
Mine is listed there as 6.2 on PS/2 port. It is possible that if this is too low, detecting multiple fingers is not possible. For me (and renova and others I think) it was sufficient to install the modded drivers to make it work.
You should also try to make the driver's 2-3 finger gestures work before giving up. Go to the window from the screenshot and select the TouchPad settings. In the new window that appears, click on the "2 finger swipes" (or whatever it's called in English) in the tree on the left. It is important that you click on the root tree node. You should get one checkbox on the right allowing you to activate the swipes function. Then use the subnodes to configure all the swipes.
Let us know how it goes.
FYI, ranova is using Vista AFAIK, he mentioned it earlier in this thread. I'm using XP Pro SP3.
Hey
so, my version is 6.5. I added a screen shot.
Furthermore, I cannot activate the swipe motions in my menu, since they dont appear. I made a screenshot of that as well, so you can see what only options I got.
But in the registry, there is definitely a file-tree that would make me think it can be activated somehow in the menu...
http://img514.imageshack.us/my.php?imag ... icskg3.jpg
Acer Aspire 5920g; 2GB Ram; Geforce 8600GT; Win Vista Ultimate 32 bit
For me, the swipe options showed up after I added the
DisplayGestures
value to
HKLM\Software\Synaptics\SynTPCpl\
registry key and set it to DWORD:1.
It should be automatically set by the modded driver thou. I guess there's something else to it that prevents both these swipe settings from showing up and my tool from working.
I'm not sure yet what that could be. You have v6.5, newer than mine, maybe they locked this in newer versions. ranova, what's your TouchPad version?
DisplayGestures
value to
Yea mines 6.3yak wrote:For me, the swipe options showed up after I added the
DisplayGestures
value to
All of you that use TwoFingerScroll and like it, please consider donating to keep the project alive.
In EUR
or USD
Or use the same button at the project website:
http://code.google.com/p/two-finger-scroll/
@forg1vr
Right now I don't know how to help you. I don't know of a way to upgrade/downgrade the TouchPad's firmware.
In EUR
or USD
@forg1vr
For information...
Dell XPS M1330 is equiped with hardware 6.3 and the "patched Acer" drivers can be installed
ChiraMotion and pinch are working (when application support pinch).
Dell Mini9 (aka Inspiron 910) is equiped with hardware 7.0 and the "patched Acer" drivers can not be installed (driver claims it wants to replace the keyboard controler then fails).
Nothing is working.
TwoFingerScroll says "Driver support for multiple fingers is already enabled but the driver still doesn't report multiple fingers. Either you haven't restarted the system yet or your TouchPad doesn't support multiple fingers".
Nothing is working.
@ranova
Thanks. There are now two Paypal buttons in the post above. Both should be in English. With one you donate in EUR, in the other in USD.
I'm working on a new version with completely reworked configuration and swipes added.
@Klug
That's interesting since ranova also has 6.3 and it's working for him. Can you activate ChiralMotion using two fingers or do the two/free finger swipes work (you have to enable them in patched driver configuration).
@Klug
It's working for me with 6.3 hardware (Dell XPS M1330), running Vista Business and the "patched drivers".yak wrote:That's interesting since ranova also has 6.3 and it's working for him. Can you activate ChiralMotion using two fingers or do the two/free finger swipes work (you have to enable them in patched driver configuration).
But I was not able to install the "patched drivers" under XP Pro on 7.0 hardware on the Mini9. The problem seems to be in the hardware version, not OS.
No Trackpoint scrolling in Virtual Desktops under Windows 7
by axur-delmeria » Thu Mar 30, 2017 7:27 am » in Windows 7 - 1 Replies
- 715 Views
Thu Mar 30, 2017 10:53 am
- 3 Replies
- 1374 Views
Last post by TPFanatic
Wed Feb 22, 2017 8:13 pm
- 4 Replies
- 437 Views
Thu Mar 09, 2017 3:55 pm
remove and clean under the trackpoint mouse buttons
by louisJ » Fri Feb 10, 2017 1:51 pm » in ThinkPad T430/T530 and later Series - 4 Replies
- 450 Views
Last post by louisJ
Fri Feb 10, 2017 3:15 pm
