Which A/B/G wireless card to upgrade in my T40?
I'd like to upgrade my a/b card in my t40 to the better a/b/g wireless card and would like to get the proper version however i see different versions available on ebay.
Could someone please tell me the one i should get?
Given that the a/b card that was originally installed is Atheros and not Intel, there was no Centrino platform on that T40 to begin with...
Abused daily: T61p
Abused daily: T61p
Jim:
Maybe you will find a bit of useful information in the thread T42p: WLAN-swap (Intel to Atheros): Advantages/difficulties?... as much of that which is discussed there also applied to T40's.
Johan
Johan
Centrino was a technology/marketing bundle that Intel dreamed up to accomplish several things... not the least of it being to sell more chips. Basically it was a combination of their chipset, CPU and wireless card is supposed to deliver the nirvana of power, speed and extended battery life. So when a machine with one of those chipsets detected that it was operating with all 3 of the magic parts, you'd get a nice looking Centrino splash screen on boot-up! As far as I can tell, the least of the 3 parts in terms of contribution to their goal was the wireless card.jim_0068 wrote:Sorry but i'm more confused..i know that my computer was not a centrino but does that matter? Cant i still use the intel card?
Also i think you might have linked me to the wrong thread, something about serial port adatpors in that one. I'll try to search for the real one though.
Among many forum members, it is often replaced with an Atheros chipped WiFi card that deliver some arguable benefits, among which are: more power (meaning better range or better signal acquisition at a given distance), better speed (especially when you combine an Atheros chipped card with some Atheros chipped access point) giving the SuperG 108 speed, and they are often cheaper as well since Atheros isn't as well known of a name (at least among typical consumers).
So, many folks are willing to give up the Centrino label (and the cool splash screen), as well as some battery life for the better performance. Hope that clear things up some. I have both in my house and honestly can't really detect all that much of a difference although, I'll probably replace the Intel card in my wife's R52 with an Atheros one.
Family Daily Drivers- T430s, T530, X220
Work- Sadly, the ThinkPads have gone away...... and replaced by HP ProDesk SFF drone machines
Other Projects- Edge 15, Z61m (Titanium)
Historic Retired ThinkPads- T42p, X20, A31p, 701c, 760XD, WorkPad C505
underclocker
- moderator
I think this came up once before. I recall the answer was that nearly 100% of T4x machines have antennas, even when they did not have wireless adapters from the factory. However, I do think there may be a very rare exception that they are missing or were removed.indicium wrote:Do all T40's have the antennas installed? I also was thinking about installing a card. What is the part number for a Atheros card compatible with the T40's?
It is easy to check for them, just pop off the keyboard (4 screws for a T40) and look, you'd see them running right down the middle - a gray and black cable next to each other.
underclocker
- moderator
By the way, unless you know you'll be attaching to an "a" wifi network, the Atheros (or Intel) b/g adapters work just as well in the T4x machines and may even use less power because they are only looking for bg networks.
There are seven adapter models that will work (are compatible with the T4x BIOS) for T4x machines (from IBM), they all work pretty well, but some people have preferences;
-Cisco b
-Intel 2100 b
-Intel 2200 b/g
-Intel 2915 a/b/g
-IBM Atheros b/g
-IBM Atheros a/b/g
-IBM Atheros a/b/g II
I believe each adpater has more than one part number (some have several part numbers).
-Cisco b
-Intel 2100 b
-Intel 2200 b/g
-Intel 2915 a/b/g
-IBM Atheros b/g
-IBM Atheros a/b/g
There's also the T43 a/b/g card (the last PCMCIA card made for the T series - 39T0355). It works in the T40 but Fn-F5 doesn't work with it. Otherwise, it's fine.
Edit: Yes, sorry, I meant mini-PCI (internal).
Keith
(Formerly 600E 2645, T30 2366, X31 2673, T40 2373, T41 2379, T42 2373, T42 2379, T60 1952, T61p 8889, T61p 8891
Currently T420 4177-CTO, T430 2347-A54, T430 2347-UN9, T430 2349-L64, T430 2342-CTO, H520S 2561-1LU, Ideapad K1)
underclocker
- moderator
That part number is just an IBM Atheros 802.11a/b/g II wireless adapter.
The Fn-F5 key combination should work.
I'm sure you did, but did you try to uninstall and then reinstall the keyboard / hotkey driver package? I've seen the issue of Fn-F5 not working after a wireless adapter upgrade, but after upgrading/reinstalling various related drivers, it worked.
underclocker
- moderator
It's available in many places. Harryc was kind enough to post a link for it in the first reply in this thread.
http://www-307.ibm.com/pc/support/site. ... 46474.html
Please note, there are actually several part numbers for each adapter. I do not believe a comprehensive list exists on this planet. You'll have to review the description of any item you are buying very carefully if it's not one of the exact part numbers that do happen to be listed.
Yep, tried updating everything - BIOS, controller, hotkey driver, OSD driver, power management, etc. Could never get Fn-F5 to work in the T40.underclocker wrote:That part number is just an IBM Atheros 802.11a/b/g II wireless adapter.
Keith
Which Ultrabay Slim batteries fit which ThinkPads?
by bakery2k » Fri Apr 14, 2017 8:45 am » in Thinkpad - General HARDWARE/SOFTWARE questions - 3 Replies
- 752 Views
Fri Apr 14, 2017 9:38 pm
Replacement Wifi card for T40 Model 2374
by HighPingDrifter » Thu Feb 16, 2017 1:49 pm » in ThinkPad T4x Series - 4 Replies
- 1271 Views
Last post by jaspen-meyer
Fri Feb 17, 2017 3:04 pm
- 14 Replies
- 2307 Views
Last post by dandreye
Sun Jan 29, 2017 1:29 pm
WTB W701 Parts Express Card or CF/Express Card Board
by MisterB » Mon Jun 19, 2017 4:43 pm » in Marketplace - Forum Members only - 1 Replies
- 126 Views
Last post by MisterB
Mon Jun 26, 2017 9:57 pm
