#35
Post
by fje » Sat Nov 29, 2008 4:17 am
Keyhole:
1.- My laptop is Thinkpad 600E 2645-550 (one of the earlier models of the series)
2.- BIOS is IHET47WW 09/11/99. Pay attention to the difference in the second character. mine is "H", yours is "N", this implies your laptop is able to have a better BIOS (mine isn't), that needs less mods to upgrade the laptop.
3.- I already upgraded the processor. In fact I installed a Pentium III 600MHZ. My mainboard/BIOS is not able to automatically change the clock speed, so I had to do a small hardware mod. to have the clock running at 100Mhz, and with it, the processor is running at 500Mhz.
4.- That is the maximum speed I can have without further hardware changes. One of the ones I could do is the one seen in the forum/thread/post you refer to in wimsbios, for having the FSB running at 108Mhz, but it is not easy to do the soldings that have to be done. The same is applicable for having the mainboard able to support processors running at even 800MHz, so I decided to stay at 100MHz and the processor running at 500MHz.
5.- Powerleap CPU Control Panel is needed for having the processor using its L2 cache. Once the new processor is put in place, there is a need to disable the L2 cache in the BIOS to avoid an error 127 in bootup time. So, after boot is done, we have to enable again the L2 cache, and this can be done with PowerLeap CPU Control Panel (aditionally it gives similar info to the one Belarc Advisor seems to give to you)
6.- Prefetch: I disabled it, but didn't find much difference, so, I enabled it again to the original value "3".
7.- Finally, wimsbios forum you refer to is a very, very, very valuable info forum. it was the starting point for me (and it seems that for many other people too) to decide to go on with this upgrade of my laptop. It is a loooong thread but the time you need for reading it pays for with a very valuable info and avoid of possible errors or frustations when you feel that you (or your computer) are not able to do the upgrade. It is a very recomendable thread to be read by anyone that plans to do an IBM Thinkpad 600E or 600X upgrade.
Regards.
