What is wrong with my T41p DVD-playback?!?
schoefer
#1 Post by schoefer » Wed Jan 05, 2005 7:03 am
I know that some people allready had a similar problem but I found no solution for me problem.
The Problem:
when I put in any burned DVD or CD in my T41p the work place is not responding anymore. Also WinDVD and PowerDVD do not respond until I get the DVD or CD of the drive. I use the T41p for 10 Month now and it worked always fine (also with the mentioned DVDs and CDs) but few days ago, when I was watching a burned DVD it stuck and after that nearly no burned DVD or CD worked anymore.
what I have done so far:
Changed the DVD-drive (no difference)
made complet reinstallation of the system (no effect)
deinstalled the DLA-software (no difference)
updates Bios etc. (no difference)
The IBM hotline has also no further ideas.
What makes me crazy is that it worked always fine until Sunday but I did not installed anything or droped the notebook.
Please help !!!
JaimitoBond
#2 Post by JaimitoBond » Fri Jan 07, 2005 2:02 am
Got similar prob with my T41p, on burned DVDs only. During playback, it can freeze up. I wonder if the DVD+R disc is the prob. I haven't tried DVD-R to see if it also has this problem.
schoefer
#3 Post by schoefer » Fri Jan 07, 2005 3:01 am
Funny, in my case the problems were only with DVD-R and I thougt DVD+R would be better!?!?
I think it depends more on the type of DVD. Currently I use "Platinum DVD+R", and these work fine. Before I used "Princo DVD-R" witch were bad.
