RAID 0 is destructive in both setup and recovery. data cannot be migrated from a primary drive into a striped array. and, the failure of either drive results in data loss on both drives, even if the non-failed drive is still healthy.muol wrote:In addition I have one question about switching from a single HDD to RAID 0. If I install a second identical drive and change BIOS settings from AHCI to RAID 0, will the data on the former single drive be erased, or is it automatically expanded to the 2nd HDD without any data loss?
for those reasons, i don't recommend using RAID 0 in a production environment. if you're in that much of a hurry, buy a fast SSD instead.
