Thinkpads.com T61 Project - (Pic Warning)
basketb
#31 Post by basketb » Sun Nov 16, 2008 4:52 am
Harryc wrote:...
Now, with that said, I do have a 40GB 5400rpm hard drive left over from the previous build, and also a 10GB hard drive, both donated. So, we may be able to pull this off with a sale of those, but we need this refund from superior reball.
Not sure what you intend to do with the A31p donor machine but selling its LCD should bring in some money, no?
Harryc
#32 Post by Harryc » Sun Nov 16, 2008 5:26 am
The donor machine is for sale, but the original donor is going to get the proceeds from the sale. That is the only fair way to do this since we didn't actually use it for a project build.
Harryc
#33 Post by Harryc » Sun Nov 16, 2008 7:31 am
Continuing on with getting Vista on the T61 project machine. I did some research on this machine. The EBay auction stated that the machine type is 7659-1QU. The machine we actually received is 7659-1LU. The later takes Win Vista Business 64bit as part of it's standard config, the prior runs Win Vista Business 32bit. So, in order to stay true to the config we'd need Win Vista Business 64bit recovery media. I am not sure how R&R works at that level. Can we use either successfully or only what is on the COA?
mgo
thinkpads.com customer
#34 Post by mgo » Sun Nov 16, 2008 7:46 am
Harryc wrote:Continuing on with getting Vista on the T61 project machine. I did some research on this machine. The EBay auction stated that the machine type is 7659-1QU. The machine we actually received is 7659-1LU. The later takes Win Vista Business 64bit as part of it's standard config, the prior runs Win Vista Business 32bit. So, in order to stay true to the config we'd need Win Vista Business 64bit recovery media. I am not sure how R&R works at that level. Can we use either successfully or only what is on the COA?
If anybody is a Tech Net subscriber, perhaps they could provide a 64 bit biz DVD. I think that would be legal as long as the OS was offered no charge. I might be mistaken. My 64 bit T60 works well with all of my apps. (I don't use anything exotic - Just Office 2007 I a couple other things)
Harryc
#35 Post by Harryc » Sun Nov 16, 2008 7:57 am
mgo, good idea. If anyone out there is a Technet subscriber or who can send/lend/borrow a set of Win Vista Bus., 64bit RR discs for a T61...we need a set please. I will mention your member ID (or name if you prefer) with the utmost respect & admiration in this thread :).
carbon_unit
#36 Post by carbon_unit » Sun Nov 16, 2008 9:48 am
Does the COA sticker specify 32 or 64bit?
I can probably find a 32bit set for an R61 if it is close enough to work. I'll have to check my stash of R&R disc sets at work.
T60 2623-D7U, 3 GB Ram.
Dual boot XP and Linux Mint.
Registered linux user #160145
Harryc
#37 Post by Harryc » Sun Nov 16, 2008 10:03 am
carbon_unit, good question. I can't make out the top part of the COA sticker because it is worn. The COA # is perfectly legible though. If the Lenovo support site were up, I could check history. Its a 7659-1LU.
richk
Moderator
Moderator
#38 Post by richk » Sun Nov 16, 2008 11:38 am
I used 64-bit for a short time. Many "normal" things don't work right. Windows update failed with 4GB of memory. Many little applications I use just didn't work. I only suggest it for people who absolutely need it to get more than 4GB memory for things like huge pictures with photoshop or video editing.
Harryc
#39 Post by Harryc » Sun Nov 16, 2008 12:10 pm
richk, for the purposes of this project, I absolutely have no preference for a 64Bit Vista install. My earlier statement about staying true to the config was simply leading to this. If the COA on the bottom of the machine is for Vista Business 64bit, would a Vista 32bit R&R disc set recover the machine, and if it did, is that action against any Microsoft Software License terms? For the purposes of general sale, I would agree with the argument that a 32bit OS might sell better. I can't comment about Vista 64bit operation issues because I have never run it.
Harryc
#40 Post by Harryc » Sun Nov 16, 2008 12:33 pm
Well, the Lenovo support site finially came back up. I did a waranty/parts lookup and it does not mention the OS. The machine type/model description says;
Product: ThinkPad T61 7659-1LU [change]
Operating system: Windows Vista [change]
Original description: T7100(1.8GHz), 1GB RAM, 80GB 5400rpm HD, 14.1in 1280x800, Intel X3100, CDRW/DVD, Intel 802.11abg wireless, Modem, 1Gb Ethernet, UltraNav, Secure chip, 4c Li-Ion, WinVista Business
What made me believe it was a Vista Business 64bit model is this;
http://www.superwarehouse.com/Lenovo_Th ... /p/1504114
... and this
http://shopper.cnet.com/notebooks/lenov ... iew#info-1
Thoughts? I will also ask a Lenovo Rep to do a lookup.
underclocker
moderator
moderator
#41 Post by underclocker » Sun Nov 16, 2008 3:56 pm
Harry, if you do a "warranty status", then a "parts lookup" at lenovo.com, you'll probably see the Vista type, my T61 shows;
VISTA BUSINESS 32 BIT ALL WW:LABELS
Harryc
#42 Post by Harryc » Sun Nov 16, 2008 4:34 pm
underclocker, it shows the below;
LABELS; MS WINDOWS VISTA PREMIUM LOGO:LA
So, that would contradict what is listed when you look-up the machine type/serial;
The sticker on the palm rest just says 'Windows Vista'.
Mfg part #	 FRU part #	      Description	    Serviceable?
	28L3133	12R7469	LABEL:LABELS	YES
	39T0494	0000000	ADONIS MDC-1.5 ADAPTER:WIRELESS COMBO AD	NO
	39T2733	39T2685	24/24/8/24X CD-RW/DVD COMBO II DRIVE FRU	YES
	39T7209	0000000	TOUCHPAD PLATE:PADS	NO
	41R0593	40Y8402	512MBPC25300NP FRU	YES
	41U5400	42W7654	MICROASSEMBLIES; FRU CPU ASM INTEL CORE	YES
	41V9757	41V9756	RUBBER SHEET FRU	YES
	41W4528	0000000	HDD BRACKET:BRACKETS/STIFFENERS	NO
	42T0340	42T0341	14.1 INCH LCD DISPLAY FRU	YES
	42T0852	0000000	GOLAN WLAN ADAPTER CARD:802.11 ADAPTERS	NO
	42T1003	0000000	80GB HARD DRIVE, SEAGATE, M5400.3S-80, 5	NO
	42T1304	42T1305	80GB HARD DRIVE ASSEMBLY FRU, SEAGATE	YES
	42T3241	42T3273	KEYBOARD FRU	YES
	42T5008	0000000	LINE CORD:LINE CORDS	NO
	42T5226	42T4667	PANASONIC 4 CELL BATTERY FRU	YES
	42V9501	0000000	BOMS, NOT SHIPPABLE ACROSS BORDERS; MICR	NO
	42V9635	0000000	BOMS, NOT SHIPPABLE ACROSS BORDERS; 14.1	NO
	42W2427	0000000	LABELS; FCC LABEL FOR WLAN:LABELS	NO
	42W2739	0000000	LABELS; MS WINDOWS VISTA PREMIUM LOGO:LA	NO
	42W2794	0000000	LABELS; PRODUCT LABEL 7659 CTO:LABELS	NO
	42W2973	0000000	LABELS; HOMOLOGATION LABEL (NA/LA/AP) LI	NO
	42W3782	41W1487	PLANAR ASSEMBLY FRU	YES
	42W3824	0000000	SCREWS, METRIC; SECURITY SCREW:SCREWS, M	NO
	42W9386	0000000	MALIBU-1 MALIBU-1 MS PLANAR ELABW (INTEG	NO
	42W9760	0000000	T61(MALIBU1):PUBLICATIONS MISC	NO
	42Y6651	87H4776	RECOVERY DVD KIT	NO
	91P8421	44M4361	TRACKPOINT CAP KIT:MECHANICAL ASSEMBLIES	NO
	92P1160	92P1159	LITEON 65W 2PRONG MODEL	YES
Brad
**SENIOR** Member
**SENIOR** Member
#43 Post by Brad » Sun Nov 16, 2008 6:04 pm
A search for the DVD recovery set 87H4776 listed in your parts lookup reveals Windows Vista Business 32bit here.
Brad
Long Island New York
Harryc
#44 Post by Harryc » Sun Nov 16, 2008 6:28 pm
Brad, that was a stroke of genious, thanks!. So if anyone (carbon_unit ?) has a Vista Business 32 bit R&R set and you are willing to send a copy, please let me know.
Update - I opened a repair ticket with Lenovo for the keyboard.
carbon_unit
#45 Post by carbon_unit » Sun Nov 16, 2008 8:29 pm
I'll look when I get to work tomorrow. I know I have R61 Vista Ultimate 32bit (it belongs to the machine I am typing on) and I am pretty sure I have R61 Vista Business 32bit.
Harryc
#46 Post by Harryc » Mon Nov 17, 2008 1:54 pm
Project Fund Update -
We did receive a refund from Superior Reball today in the amount of $33.
Carry-over balance $29.12
Payment from SR $33.00
Current Balance $61.12
Since it is fairly apparent at this point that we will not be receiving a donated or substantially price reduced LCD offer, I will purchase an LCD using the current balance $63.12 and the rest of the LCD cost will be out of my pocket. I will report the total amount here, and upon sale of the laptop I will recoup my personal expenditure. Hopefully that plan meets with approval from the membership. I would flat out donate the money under normal circumstances, but I have already donated well over $100 into these projects.
usernotabuser
#47 Post by usernotabuser » Mon Nov 17, 2008 2:24 pm
I feel like the Puerto Rico Representative to the US Congress (able to speak, but with no vote/power).
In that capacity, Harryc: you have my go ahead to proceed as you stated.
On a lighter note, I'm running Vista Ultimate SP1, 64bit.. My 4 GB of RAM and I have seen no problems whatsoever. Just saw some mention of this above and thought I'd chime in.
Simple is as simple does.
Harryc
#48 Post by Harryc » Mon Nov 17, 2008 2:24 pm
Cut and paste this search into EBay -
(42T0339,42T0341,42T0425,13N7102,42T0410)
As you can see, the lowest priced LCD is now $131 shipped. That is $33 higher than a couple of days ago...perhaps we'll wait for a better deal, unless someone has a source?
Edit: Disregard - I found one -
LCD on EBay
Harryc
#49 Post by Harryc » Mon Nov 17, 2008 2:37 pm
usernotabuser, thanks.
Done, we've now purchased this LCD -
LCD on EBay
They do standard flat rate shipping, so now we wait. Current project fund accounting looks like this -
Old Balance $61.12
LCD Purchase $ 97.98
Current Balance - $36.86 (Negative)
Amount owed to Harryc on sale of laptop - $36.86
Amount invested to date on T61 Project -
Laptop $263.78
Battery/AC Adapter $25.00
LCD $97.98
Total $ 386.76
As far as investment in the project, I think that is an outstanding value, and we're basicallly done as far as getting needed parts etc. So, we've accomplished getting a T61 with 2 years warranty for under $400. I still have yet to post pics. I will make it a point to do that tonight.
syedj
#50 Post by syedj » Mon Nov 17, 2008 6:09 pm
Harry, do you have another T61(p) or even T60(p) hanging around? If so, can you try using the Vista Business 32b R&R DVDs in that machine with the hard drive from the project T61? I have use this method before and it works just as good. This way at least you can get the R&R partition on the project hard drive. Then run R&R after putting back the hard drive in the project T61.
“Long you live and high you'll fly and smiles you'll give and tears you'll cry and all you touch and all you see is all your life will ever be.”
Harryc
#51 Post by Harryc » Mon Nov 17, 2008 6:56 pm
Syed, thanks . I do not have any T6X machines. Well there's my work T60, but if I hose that machine I am in a world of hurt :).
Harryc
#52 Post by Harryc » Mon Nov 17, 2008 7:25 pm
LCD Tech must have changed shipping policies at some point. The LCD is already enroute via 2 day FEDEX. It will be here on Wednesday from Texas. Now THAT is what I call service. Coincidentally, the keyboard will be here the same day.
underclocker
moderator
moderator
#53 Post by underclocker » Mon Nov 17, 2008 7:58 pm
It's coming together nicely! Please post a picture link when you get a chance. It'd be good to see the before and after (LCD swap).
Harryc
#54 Post by Harryc » Mon Nov 17, 2008 8:31 pm
#55 Post by rkawakami » Mon Nov 17, 2008 8:53 pm
Harryc wrote:Anyone have any ideas on how to remove the rest of the sticker residue on the lid?
What I use, in increasing amounts of "toxicity":
- clear Scotch tape, pressed onto the sticky parts and then pulled straight up. Repeat as fast you can, moving the clear tape to unused sections when the tape loses tackiness.
- Windex
- Isopropyl alcohol
- Goo Gone
#56 Post by ajkula66 » Mon Nov 17, 2008 8:54 pm
Mr. Clean Magic Eraser (extra strength) did wonders (with patience and warm water) on the lid of my T43...
Harryc
#57 Post by Harryc » Mon Nov 17, 2008 8:59 pm
Ray, the first (3) items have already been used to remove most of it, the remaining residue is tough. I do have a can of Goo Gone. That stuff is nasty :). Do you think it would discolor the lid? George, Mr. Clean Magic eraser was the first thing I used. I didn't try the extra strength though.
#58 Post by rkawakami » Mon Nov 17, 2008 9:03 pm
Haven't had to resort to the Goo Gone yet so I don't know how/if it will attack the lid. Try some along the back edge and see if it starts eating the plastic :) .
Harryc
#59 Post by Harryc » Mon Nov 17, 2008 9:05 pm
Yeah, Ray that stuff would eat rust off of nails. I think it would be a last resort. I will try to locate an extra strength MC Magic eraser first.
carbon_unit
#60 Post by carbon_unit » Mon Nov 17, 2008 9:14 pm
Have you tried WD-40 yet?
