How to disable Win XP Firewall
Truthfinder
#1 Post by Truthfinder » Wed Nov 19, 2008 5:56 pm
Hi gang:
Anyone have the instructions that will keep XP from turning the firewall on? If I turn it off and re-boot, XP turns it back on.
I had instructions that were set up using the DOS Prompt, but had to Ghost restore and lost them.
Thanks ONE and ALL
Steve :-)
ThinkPad T-60 2623D7U, 4GB Kingston HyperX / ThinkPad T-60P 2008-83U , 4GB Kingston HyperX.
Running Windows 7 on both units. Dedicated ThinkPad user for about 18 years.
#2 Post by RealBlackStuff » Wed Nov 19, 2008 10:23 pm
Go to Settings/Control Panel/Security Center where you can switch it on/off.
Truthfinder
XP Firewall issue
#3 Post by Truthfinder » Wed Nov 19, 2008 10:27 pm
I began to notice that once I installed NIS 2009, the Windows Firewall would turn itself back on after each reboot. There was no way around this issue.
Anyhow, I just found a fix and it works great...... See the following for instructions should anyone else need this fix:
Best to all, Steve
To permanently prevent Windows Firewall from starting with Windows, run the following commands in a command prompt: NOTE:: You can use command prompt while in Windows.
SC CONFIG SharedAccess Start= disabled [ENTER]
See: ChangeSerViceconfig SUCCESS
NET STOP SharedAccess [ENTER]
see: The Windows Firewall/Internet Connection Charing <ICS> was stopped successfully.
Restart the computer. If you try to check the firewall it will tell you that the service is disabled! Don't enable it
