16GB is not nearly large enough. I thought these things were up to 128GB. Perhaps not in the 1.8 form factor. What are they using in the iphone? Just random thoughts.Harryc wrote:proaudioguy, as I mentioned to Tims, suggest a reasonably priced SSD and we'll do it. There are no 'rules' here for these projects. We do what the members want to see. Just keep in mind that we have to sell this laptop. As an example, at the end of the day we could have around $450 invested into a laptop with a 16GB MTRON MOBI ZIF SSD. That is based on a 16MB MTRON MOBI ZIF/IDE SSD costing @$250. My question would be; Is that a sellable laptop at $450? Your thoughts? Personally I have seen a couple of SSD machines have problems selling on the Marketplace forum. I don't think most EBay buyers are technically sophisticated enough to see beyond a 16GB drive, perceive it as being small, and the machine as being expensive compared to the 60GB X41's out there for $350.
Thinkpads.com X41 Project - (Pic Warning)
proaudioguy
proaudioguy
It's likely not possible. If you get an i386 folder from another thinkpad of the same era, you might be able to make that happen. I've had no luck doing this with other OEM or retail XP media. What I've done is install the retail disc (to get the computer functional), then before activation, run the i386 setup, then input the COA on the bottom of the computer. THe i386 folder couldn't be run from a boot CD but I'm sure someone knows how to make a bootable disc that will run the installer. I'm just not qualified to do it.OldManClayton wrote:Is it not possible to just install Windows XP with the provided COA and download the drivers? I've installed XP from a generic disc on laptops with their provided COA before...
I have installed Win2K WinXP and Vista + misc. Linux distributions from fresh installs, and installed the needed drivers after install with no problems. (And I only install the important drivers and software from IBM, so I don't have all the IBM bloated software to slow the x41 down, I also use nLite to remove some default MS sofware and services). Also a little tip, try to find some alternatives to the MEGAbloated software. like Adobe Reader 150MB+ Installed vs. Foxit Reader 4MB Install and much faster, Azareuz 30MB+ Installed vs. uTorrent 500k much faster. The list goes on and on..
x412008
x412008
IBM X41 - Pentium M 1.5 - 1.5GB RAM - Mtron Mobi 3000 16GB SSD - XPSP3 Tweaked
proaudioguy
You failed to mention that you used the COA on the bottom of the computer when doing this which was the whole point. We all know you can install just about any OS on a Thinkpad and have it 100% or nearly 100%, including Linux, and Mac OS. Some just take more work than others. The question is can you use a retail installation disc and enter the COA on the bottom of the computer. I say no. What say you?x412008 wrote:I have installed Win2K WinXP and Vista + misc. Linux distributions from fresh installs, and installed the needed drivers after install with no problems. (And I only install the important drivers and software from IBM, so I don't have all the IBM bloated software to slow the x41 down, I also use nLite to remove some default MS sofware and services). Also a little tip, try to find some alternatives to the MEGAbloated software. like Adobe Reader 150MB+ Installed vs. Foxit Reader 4MB Install and much faster, Azareuz 30MB+ Installed vs. uTorrent 500k much faster. The list goes on and on..![]()
x412008
You can get a 128GB SSD in 1.8 form factor but the price is WAY above what we have to work with in this project. Even the 64GB SSD's are @ $550 for a decent one.proaudioguy wrote:16GB is not nearly large enough. I thought these things were up to 128GB. Perhaps not in the 1.8 form factor. What are they using in the iphone? Just random thoughts.
Tim S and others, can we move the OEM COA discussion to another thread please, it is not relavent here. We want X41 R&R CD's for this project. (period)
proaudioguy
The computer would be worth that much more with an SSD much like the new X300 and X200 cost more with SSD. They aren't giving those SSDs away. I'm curious what they are putting in the iPhone and iPod touch.Harryc wrote:You can get a 128GB SSD in 1.8 form factor but the price is WAY above what we have to work with in this project. Even the 64GB SSD's are @ $550 for a decent one.
I thought there were guys using 2 32GB CF cards, and perhaps some using SD cards. This is clearly a hack that needs a FAQ. Another 4200 slow drive is just a waste of time IMHO. Perhaps the SSD idea is beyond the scope of this project, but I can't imagine anyone that can't put a hard drive in, run a restore, stick in some ram, and buy a new PSU. I thought the whole point was to do something that was a challenge. Peace out, I'm going back into lurk. Good luck with whatever you guys end up with.
I am seeing a lot of talk and not too many real proposals here, despite having asked for that twice. Propose a cost effective upgrade within the remaining budget that will result in a sellable X41 at the end of the day and we'll do it. We have around $320 left. I'd also like to say that the amount of work (and the difficulty) required to install a ZIF SSD is exactly equal to the amount of work/difficulty level required to install a ZIF Hard Drive. CF cards just slide into an adapter, no? Anyway, I am looking for specifics, .e.g. this SSD or this CF card (Manufacturer/model) from a particular source at this price. Also, for the record, I disagree with another 4200rpm hard drive upgrade being a waste of time if that drive has a larger capacity than is currently available for an X41, at a fraction of the cost.
Its actually possible to use an OEM CD and the COA on the bottom of a Thinkpad to install XP. I dunno if its for all machines, but I've done it on an A31, G40, T40, T41, R51, and X24. On the R51 I had to call Microsoft to get it activated-- all other machines activated online with no problems.
My thoughts: I like the ZIF hard drive idea for a couple reasons. First, its a recent development that I think is a pretty big deal for X4 owners who don't want to deal with the expense and other limitations of the 1.8" drive (slow, expensive), SSDs (expensive), or CF (capacity). The ability to use ZIF hard drives opens up an alternative upgrade channel that seems to be a good balance between price and capacity. Second, I think there would be more buyers for this type of machine than one with an expensive SSD setup. I'm not saying its not worth the upgrade-- I just think the lower cost would have a broader appeal.Harryc wrote:I am seeing a lot of talk and not too many real proposals here, despite having asked for that twice. Propose a cost effective upgrade within the remaining budget that will result in a sellable X41 at the end of the day and we'll do it. We have around $320 left. I'd also like to say that the amount of work (and the difficulty) required to install a ZIF SSD is exactly equal to the amount of work/difficulty level required to install a ZIF Hard Drive. CF cards just slide into an adapter, no? Anyway, I am looking for specifics, .e.g. this SSD or this CF card (Manufacturer/model) from a particular source at this price. Also, for the record, I disagree with another 4200rpm hard drive upgrade being a waste of time if that drive has a larger capacity than is currently available for an X41, at a fraction of the cost.
Agreed with virge...this is definitely a challenging project, and ZIF drives would be the way to go IMO...
Now, where do we go from here? My knowledge of related technology is quite modest....
And, what are the chances of avoiding "2010 error"?
Just thinking aloud...
Digitalrhino
I also think a zif drive would be a good idea. It is the process and documentation of the hack that matters. Any individual can adapt it to their liking, such as SSD, cf card or the Samsung 120gb 5400 rpm zif drive. I found a recently finished eBay link for it, with a buy it now of $100. Search eBay for #290271306699. One of these would be a good middle ground. Larger faster drive but not as expensive as SSD's right now.
x41 Tablet running windows 7
Digitalrhino, thanks for the Ebay link. I like the 120GB Samsung HS122JC. It seems like a good sized upgrade and it is 5400rpm. We'll see if we can find one. If any member finds this drive at a reasonable price, please post here. George, as far as I can determine, the 2010 error will appear once this machine is booted. I do not know if there is an error bypass in X41 BIOS.
The cheapest source for the Samsung 120GB HS122JC is currently at Upgradebay.com for $204.93 shipped. That is a large $$ purchase, and I'd like at least (2) members to approve before making it. That expenditure would put total invested in the X41 project at $395.
That purchase would narrow down the list of parts needed to;
X41 XP Pro Recovery CD's
External CDROM (USB) drive or X4 Ultrabase with a CDROM drive
(1) rear foot, and (2) front feet
sparta.rising
I'll second what Virge said about the XP OEM CD. I've used an OEM CD with the COA on machines from T23 to T43 to Z61t without any problem with activation. After that, if you don't want to download drivers individually, just download Software Update.
Z61t - C2D 2GHz CPU - 3GB RAM - 320GB HDD - 14.1" WXGA+ - Intel 950 - Travel Bezel
sparta.rising
Dang looking at ebay completed auctions it looked like we just missed out on 4 of those Samsung drives by a week! One sold yesterday!
But I think the 160GB 4200RPM at $115 would be a better buy than the 120GB 5400RPM at $205
sparta.rising
You know, a funny project might be to try and fix a non-thinkpad machine to show how much more ridiculously complicated they are to disassemble. "Oh, there was a hidden latch under that label that revealed a nob that I had to turn exactly 270 degrees to open a compartment under the speaker panel that contains the screw that was keeping me from opening the case."
AvalonXIII
Just want to help out here. There's a new official ZIF to IDE adapter from Lenovo that's supposedly doesn't throw the 2010 error. I don't have the part number handy, but if somebody is willing to share, I think I may know where to order it. This is not a guarantee, but I'll see what I can do to help. If you guys decide on using an aftermarket ZIF to IDE adapter already, then never mind.
EDIT:
Found it guys. Go to this link for a picture of this new adapter:
http://www.laptopalkatreszek.hu/termeke ... 6/?lang=en
Official Lenovo IBM link for the adapter:
http://www-307.ibm.com/pc/support/site. ... MIGR-69154
Found a US link to buy it if you guys are interested:
http://thinlineit.com/test/renewcompute ... ve-42T4451
EDIT:
X61SXGA: L7700/3GB RAM/Toshiba mSATA SSD 64GB/Intel Wifi 5300AGN/4-cell battery/Flexview AFFS SXGA+
I was aware of these drives, but the problem is that they are of equal (low) capacity to the old drives that came with the X41, and IIRC they are expensive. If you can get just the adapter without the drive then I am all ears
. If X41 owners could get a hold of just the adapters that don't throw 2010 errors, and if they are reasonable, then they'd be home free.
AvalonXIII
Unfortunately, I don't think anybody is selling the adapter aloneHarryc wrote:I was aware of these drives, but the problem is that they are of equal (low) capacity to the old drives that came with the X41, and IIRC they are expensive. If you can get just the adapter without the drive then I am all ears.
But I did post a link for the adapter with the 40GB HDD for $225, don't know what you think about that.
proaudioguy
ZIF = Zero Insertion Force
Another way of saying that you do not have to physically put any additional pressure on the item in question, in order for it to mate with a connector of some kind. I have not personally seen this type of connection when used on a hard drive. I would assume that it's part of a mounting system where you do not have to "force" the drive's data and power pins into a matching socket. Gravity and guide pins usually provide the means necessary to align the connections (metal pads on one side and springs on the other).
proaudioguy
Yes of course I know what it means in regards to a CPU.rkawakami wrote:ZIF = Zero Insertion Force
Okay... had some time to go a'googling
ref: http://www.hometheaterhifi.com/features ... pod_2.html
ref: http://www.command-tab.com/2007/03/11/u ... rd-drives/With that in mind, Toshiba engineered a new connector on recent drives that is vastly smaller than the previous models. These new drives sport a Zero Insertion Force (ZIF) connector, which, unlike the older iPods, requires no pressure to connect the cable. Simply holding the hair-thin ribbon cable in place and folding down a clamp-like lock will secure all 40 pins in a staggeringly small, fragile connector. The connector on the 5G iPods’ logic boards is now no wider than your thumbnail, and it, too is quite delicate. Such is the way of ever-shrinking consumer electronics.
- 734 Views
Last post by exTPfan
Sat Apr 08, 2017 5:07 am
- 1550 Views
Last post by turkka80
Wed Jan 04, 2017 7:36 am
- 7 Replies
- 225 Views
Last post by oeuvre
Thu Jun 15, 2017 7:32 am
- 1244 Views
Wed May 24, 2017 8:14 am
